KWSC Kit Release Ramblings
Old May 19, 2008 | 07:24 PM
  #241
leonine's Avatar
number 3 here signing in
Old May 19, 2008 | 11:48 PM
  #242
kmdebit's Avatar
Yay! Thanks Chris So who's actually rockin' the license plate frame and decals? I was thinking subtle placement, either under a wiper or low on a door or quarter panel.
Old May 20, 2008 | 12:11 AM
  #243
DynamicFit's Avatar
Numero Cuarto checking in. I'm rocking the plate frames.
Old May 20, 2008 | 12:17 AM
  #244
Illusive's Avatar
Everyone with aftermarket headers, is the header extremely close to the intake piping? The T1R headers are very close and I'm getting some header wrap to reduce the amount of heat in that area.
Old May 20, 2008 | 12:27 AM
  #245
gotfitted's Avatar
i hope i can make it in time to be top ten...
Old May 20, 2008 | 12:30 AM
  #246
JDMchris.com's Avatar
I run THIS
I have had the plates on my car for awhile I have the Powered by one, not the got boost.
Old May 20, 2008 | 12:56 AM
  #247
kmdebit's Avatar
I almost regret getting the "got boost" plate over the "powered by" but I like the lack of subtlety and the catch phrase. I was so flustered when Oscar called. He caught me off guard, even though I knew he'd be calling. All I could think was "omg this is him, this is the man that's made this possible!" (of course with a lot of other ppl's help, like you, Chris).
Just a note...I pre-ordered my KWSC in Iraq, from a run-down internet cafe, last March, before I even was in the states to test drive a Fit. That's how set I was on getting this ^_^
Old May 20, 2008 | 01:32 AM
  #248
xorbe's Avatar
Cool, so you have the T1R + kit installed. You installed the T1R header before the kit, right? Or should I wait until the kit is installed, I don't want to take things back apart when I start wrenching! (And man I wish that exhaust header was a little cheaper.)
Old May 20, 2008 | 08:31 AM
  #249
Mr_ET's Avatar
I'm helping Illusive with his car so I can answer this one. Install the header at the same time as your supercharger. If you read the instructions, to get the supercharger in it's spot you either need to remove the header or the passenger side axle. In your case just remove the header and install the new one once the SC is in
Old May 20, 2008 | 09:51 AM
  #250
Illusive's Avatar
Originally Posted by DynamicFit
Congrats on getting your kit in, Illusive. How did the install come out. I think the only reason the brake lines were such a pain for me was the fact that I'm a perfectionist when it comes to these things and literally spent a couple hourse getting everything straightened out and perfect (I don't know if everyone went to the same extent, but I tried to make sure that nothing touches). Who else is waiting for the Hondata BTW?
Yeah I still gotta do some touch ups on those lines. They are a royal pain. Are your headers very close to the SC intake?
Old May 20, 2008 | 09:59 AM
  #251
DynamicFit's Avatar
Headers have about a 3/4 inch clearance. I adjusted the piping multiple times to get the maximum amount of distance between the two. Also I think the J's header or T1R have larger primaries than the Mugen header. You might have to correct me on that one if I'm wrong.
Old May 20, 2008 | 10:57 AM
  #252
jsensk's Avatar
Is there some secret that leonine got an advanced AT kit or something? I mean, there's no "s-mode" on the manual. It's cool man-- we are just wondering cause it sounds like you have the AT and us AT guys are of course just as anxious as everyone else was. No reply to 2 inquiries about it.
And now it's going to be "a couple more weeks" for the AT kit? I am very patient but damn... the story changes everyday.
Old May 20, 2008 | 11:52 AM
  #253
I run THIS
He installed the MT kit on his AT. The AT kit IS different, and Installing a MT kit on your AT could void the warranty on the kit.
Old May 20, 2008 | 12:09 PM
  #254
leonine's Avatar
But yeah, Leonine, I know you have the Mugen headers, how close are they to the intake inlet to the SC? The T1R headers are only a few mm away and will definitely need a heat wrap to protect the piping and connectors...
The Mugen is the same
Old May 20, 2008 | 12:12 PM
  #255
leonine's Avatar
i got the mt kit because i preordered a manual fit. but then it fell through so i have it on my at until i either get a mt or convert my at to mt.
Old May 20, 2008 | 01:19 PM
  #256
Illusive's Avatar
ok coo coo, just got a little worried there! Will definitely be using the header wrap tho just to make sure I don't burninate a hole in anything haha! Doing gauges tonight with 3 other Fitfreaks, wish us luck!
And stupid UPS won't let me pick up my package tonight...which is stupid...but I yelled a bit and they said they will try to have it for pickup tonight
Old May 20, 2008 | 01:25 PM
  #257
jsensk's Avatar
leonine-- OH I see. That makes sense. Now I vaguely remember that story.
Not to digress too much, but how hard/$$ is the AT to MT conversion? I might be interested in that! I would willingly spring for the 10# kit with Hondata in a second if I had an MT.
Old May 20, 2008 | 02:58 PM
  #258
ldweng's Avatar
I have been trying to decide whether to get my T1R header coated before the SC installation. You just made up my mind.
Thanks
Old May 20, 2008 | 03:01 PM
  #259
Illusive's Avatar
No problem. I don't know if coating them will keep it cool enough. Definitely recommend some header wrap on the right pipe on the header that is closest to the SC.
Old May 20, 2008 | 03:23 PM
  #260
Illusive's Avatar
Originally Posted by eldaino
congrats!
justin: i've heard wrapping headers actually isn't the best thing for them...do aftermarket headers (like mugen) run that hot?
I'm actually only wrapping the pipe closest to the supercharger. I don't want the heat from the header to melt the hoses connected to the SC. Wrapping will insulate the header and keep the heat inside. The other pipes I will leave as is, but the 1/4" or less space between the two doesn't give me that warm fuzzy feeling...
