KTuner ECU Reflash
Old Feb 17, 2015 | 01:28 AM
  #161
07fit916's Avatar
Just to update everyone.. Vit finished my tune and im just trying to find a place to let me do a couple dyno pulls for cheap lol.
Old Feb 17, 2015 | 07:07 PM
  #162
KTuner's Avatar
Vit's going to tune an 09 while he's in SoCal and then I'll list 09-10 on the site.
Old Feb 18, 2015 | 03:53 PM
  #163
cl juice's Avatar
did Vit give you an e-dyno?
what were the numbers (hp/tq)?
Old Feb 19, 2015 | 10:05 AM
  #164
DWils's Avatar
Don't forget to post your e-dyno sheet in the "What did you dyno at?" thread!
Old Feb 21, 2015 | 10:12 AM
  #165
KTuner's Avatar
Wow... I'm impressed. Vit picked up 17 ponies on the 2009 Fit! I'll try to find out what mods it had.
Old Feb 21, 2015 | 03:58 PM
  #166
Myxalplyx's Avatar
Holy Cow! This is FANTASTIC! Once you get some of the details (even dyno info), I'll post it up on the first post so newcomers to the thread can see it first hand.
Congrats to the owner!
Old Feb 21, 2015 | 07:15 PM
  #167
KTuner's Avatar
Intake and exhaust, looks like. Tuned on 91. Vit may jump in to post the dyno sheet or I will once he sends it.
Old Feb 24, 2015 | 02:39 AM
  #168
hotkey's Avatar
Ah, very good! So +20whp should be attainable on premium fuel?
I'm still looking for an used ECU; this is getting me really excited!
Old Feb 25, 2015 | 09:14 AM
  #169
KTuner's Avatar
Here's the graph.
Hotkey, hold off on the ECU search. It may come to a point where I build in the option to dump the ECU contents via CAN Bus in a situation like yours.
Old Feb 25, 2015 | 07:25 PM
  #170
555sexydrive's Avatar
That's quite the nice improvement with just some tuning.
Old Feb 25, 2015 | 09:19 PM
  #171
1SickVeilsideZ's Avatar
The results are looking pretty good! We need to get some FI support going here!
Old Feb 26, 2015 | 12:15 AM
  #172
Desmond Lamar MacRae's Avatar
Thats a HUGE gain for a 1.5liter SOHC motor.
Old Feb 26, 2015 | 05:41 AM
  #173
hotkey's Avatar
Dude! Sweeeet!
My wallet thanks you!
Old Feb 26, 2015 | 11:02 AM
  #174
BMW ALPINA's Avatar
I hope KTuner will soon add the support for Sprintex Supercharger application.
Almost every Sprintex user here had experience with "HICCUP" with the piggy back that came with the kit (or the wiring)...
that one of the reason that make me keep on holding on buying the Sprintex.
The current solution that I see will fix this are:
1. Using Larger Fuel Pump (Evo X or deatschwerks equivalent) (around $150)
2. Using Larger Injector (RDX Injector) (around $450)
and to control all the above addition you need to use
AEM F/IC 30-1910 and Boomslang Harness (around $900).
and if you want to do the data logging you need AEM UEGO
which I already have (another $150 )
So all the above will significantly add the cost on top of the Sprintex kit.
(around $1,650 extra on top of the $3,000 the Sprintex kit cost).
I mean this is what I think would make sure the Sprintex kit will
have good realibility and NO HICCUP anymore...
The most significant cost is of course the AEM F/IC and the Boomslang Harness.
so if KTuner support Sprintex Supercharger tuning,
then there surely will be many new customer for KTuner from the people currently already have Sprintex on their car.
Most of Current Sprintex user had not optimize their car tune with a custom dyno tune, so most of them are not using their Sprintex at
the most optimize/ideal tuning.
Some maybe reluctant due to the high cost and the time it take to do dyno tune,
whatever the reason is,
if KTuner offer a tuning solution for Sprintex and if the dyno result from just one happy customer
show GAIN (before KTuner and after KTuner with Sprintex equipped car)
and better DRIVEABILITY with no more sudden limping mode,
I am sure many current sprintex user will line up to order KTuner and tuned by VitViper
or
for future Sprintex user like me who know they can have reliable Tuning solution with KTuner that is not as expensive as the AEM route.
plus the work needed to install the Boomslang harness and ROUTE it in into the cabin (so the AEM F/IC is more protected then living it in the engine compartment) will be a pain and not as simple
as KTuner plug in to the car and reflash...
not to mention the ability to be tuned remotely with VitTuner,
vs.
if I get the AEM, I have to do my own "emergency" tune just so I can drive my car to the nearest tuner risking my engine during the drive there or of course put my car on a flat back truck and pay more cost to get my car to the nearest tuner.
(yeah, I already think about all the pain I had to gone through to install Sprintex and make sure it will run well)...
so clearly there are plenty of advantage to use KTuner solution compare to AEM...
Hopefully I will be ready to get my Sprintex kit by next month or 2,
and when that finally happened,
I wish KTuner already offer the tuning solution for Honda Fit GE equipped with Supercharger (and larger INJECTOR)...
otherwise,
I will be forced to pay much more for AEM F/IC and Boomslang harness and deal with all the extra work needed with using AEM...
Old Feb 26, 2015 | 08:11 PM
  #175
Myxalplyx's Avatar
So much potential! OOohhhh
You 2009-2010 guys aree using the same maf sensor as a 2010 Honda Civic LX. The diameter of the Civic LX maf housing may be slightly larger than the stock Fit housing. You could get the air cleaner cover for about $22.00, have your throttle body bored by Maxbore and go for an even larger intake tubing than you have now and re-tune.
Same for the 2012-2013 Fits. You have the same maf sensor number as the 2014 Civic LX. I tested this myself in a Civic maf housing and it works but I can't recalibrate my ECU to make it read like it should. So many combos...
Then there's cams like Deltcams...etc. etc.
I so would be doing this myself but my KTuner ECU is still a work in progress. Man...I'd be all over this stuff if I where the 2009's through 2013's.
Old Feb 26, 2015 | 08:19 PM
  #176
yovtecjustkickedin's Avatar
Would you like to tune a 2010 vicariously?
Old Feb 26, 2015 | 08:22 PM
  #177
Myxalplyx's Avatar
I'm just pumped to see the potential with just an intake an exhaust. I can't tune but Vit Viper can. It just seems like there's a good deal of untapped potential. YoVtec...I'm waiting to see what you do with your 2010.
Old Feb 26, 2015 | 08:53 PM
  #178
Yeah, me too!
Old Mar 8, 2015 | 10:13 PM
  #179
bunz559's Avatar
Idk what happened... but i disappeared for awhile and never did anything to my fit. I come back and see that theres this product!? Awesome. The after market support is minimal but something like this is the beginning of changes to our market.
Kool beans.
Old Mar 9, 2015 | 01:34 AM
  #180
Still waiting for the FI update. Cash in hand ready to go.
