devmail's 2007 SSM GD3 build - The Grey Goose
Old Sep 21, 2018 | 09:20 AM
  #421
GAFIT's Avatar
Definitely sounds like it want to rev in your new video. For the N/A run you may want to play with a higher rpm limiter. Would let you rev first gear higher to try to get past some of the second gear bog.
Old Sep 21, 2018 | 05:34 PM
  #422
vtecfit1's Avatar
Originally Posted by devmail
removed muffler silencer
nankang ns2 195 45 15 to simulate a final drive increase to 4.6ish. Tires don't look as far as i thought they would on a 5.5" wide ge8 wheel. Next time i'm definitely going for a 205 50 15.
changed spark plugs, cleaned air filter, fluids checked...still waiting for that nitrous fill.
k20 310 cc injectors installed and working...
trying 3500 to 6700 rpm for nitrous activation. At 3500 rpm that will equal a kick of 132 ft-lbs. (88 up shot x 5252 / 3500 rpm). Will raise that point if too much wheel spin. Shift light activates at 6500 rpm, red line is 6900 rpm.
#engineporn
badass!!!!! Waitin for a vid
Old Sep 21, 2018 | 07:56 PM
  #423
devmail's Avatar
Thanks! Bottle was filled today! Truck and trailer are in the yard. Only thing to do is test the direct port for leaks and even flow. 😁
Old Sep 22, 2018 | 10:25 PM
  #424
devmail's Avatar
Heres my only 2 runs of the day. Due to late start (rain) and damage to my plugs after the 2nd run....man I need a tune next! All in all, it was a fun day, had an electrical issue that eventually got fixed, met lots of helpful people. Video soon!
14.55 at 95 mph...a new personal best but I let off near the end due to seeing smoke from under the hood. Probably the first damage I did to the plugs.
Second run was a 15.2 at 85...with misfires on 3 cylinders as a result. Now me and the mad scientist have to check out the piston rings I fried. 🤣 Hopefully not, but I was eager to tear this engine apart if so, so no disappointment here. Pumped I got a new PB, but a tune is definitely in order.
Old Sep 22, 2018 | 10:44 PM
  #425
GAFIT's Avatar
Nice! Sounds like a fun night!
Did you take a few degrees of timing out of the tune? I'm betting the Hondata tune is quite a bit hotter than factory to start with so you'd definitely want some timing pulled on nitrous.
What heat range are you running for plugs? I run IK22's regularly, but also have a set of IK24's for when I get around to boosting the thing.
I would think that -4 or -5 on the timing, IK24's gapped to around .40 and a bigger hit of nitrous would get that thing moving even better.
Old Sep 22, 2018 | 10:58 PM
  #426
devmail's Avatar
Yup, wish I had time to do some all motor runs first, but it was a good day. You are probably right about the tune and I didn't get a chance to figure out how to reduce timing. I Was up til 2am chasing electrical gremlins last night, and a few today too. I was not overly concerned because i had the trailer incase it broke. I am running 1 step colder NGK copper plugs, as it dissipates heat faster than iridiums, just don't last as long. Running the gap like they come from the factory. Lots of room for improvement, learning as I go...Now not afraid to break things since she's a trailer queen haha.
Old Sep 23, 2018 | 11:15 PM
  #427
devmail's Avatar
Finally here is the track video of my one decent run, enjoy!
Old Sep 28, 2018 | 04:19 PM
  #428
devmail's Avatar
Oh damn, check out the spark plugs!
Old Oct 1, 2018 | 08:39 AM
  #429
devmail's Avatar
Old Oct 1, 2018 | 10:57 PM
  #430
devmail's Avatar
Old Oct 1, 2018 | 10:59 PM
  #431
devmail's Avatar
Since the wind tore off one fender liner, I removed the other one...plus the rest of the ram air duct. Saved 6 lbs hahaha...going to rethink where the air filter gets its air.
Old Oct 6, 2018 | 07:56 PM
  #432
devmail's Avatar
Compression Test results...
Engine removal part 1 ...
Old Oct 8, 2018 | 11:46 AM
  #433
devmail's Avatar
No luck yet borrowing an engine hoist and leveler...need that stuff soon. The L15A looks so tiny in the engine bay without the intake manifold on. Lol
Old Oct 18, 2018 | 05:28 PM
  #434
devmail's Avatar
Old Oct 18, 2018 | 05:29 PM
  #435
devmail's Avatar
Old Oct 18, 2018 | 05:31 PM
  #436
devmail's Avatar
Old Oct 19, 2018 | 08:51 AM
  #437
devmail's Avatar
Old Oct 21, 2018 | 09:58 AM
  #438
devmail's Avatar
And now, what waits inside? 😆
Old Oct 21, 2018 | 12:52 PM
  #439
idrivemyself's Avatar
That'll buff out. A little JB Weld and you're back in business. Pitter-patter!
Old Oct 24, 2018 | 08:22 AM
  #440
devmail's Avatar
Just an update, I'm in the process of parting out my engine bolt ons. Still going back and forth over J series choices while accumulating money for the block.
