TIRE questions,sizes, mounting,pressures ANY tire questions
Old Apr 23, 2007 | 09:42 PM
  #581
TomiGunz's Avatar
Frequent FitFreak Poster
I saw them Azenis tires at discount tires today. There's a whole lot of rubber on them treads..
Anyway,, I ended up going for the Konig CounterSteer wheels. 16x7, +40 offset. And as usual, black.
Gotta save money first!!!
Old Apr 24, 2007 | 12:19 PM
  #582
Jap 07 Fit's Avatar
Any one running a 15x6.5 +32 ???
i wanna know if anyone is running that offset if so what size tires you running???
Old Apr 24, 2007 | 03:09 PM
  #583
mugenfit79's Avatar
Stock tires....
I want to get a set of 15" Rota Auto X wheels for my wife's fit sport. Could I use our stock 15" tire on these wheels? I have the Dunlops on there. Thanks.
Old Apr 24, 2007 | 03:17 PM
  #584
milano sol's Avatar
as long as the rims are 15's they should fit most aftermarket 15 inch rims.....the 195/55 is a common tire used, that and the 205 width
Old Apr 24, 2007 | 03:26 PM
  #585
mugenfit79's Avatar
Thanks for the quick response. The Rota rims are 15X6.5.
Old Apr 24, 2007 | 08:18 PM
  #586
Jap 07 Fit's Avatar
bump some one help me out plz..
Old Apr 24, 2007 | 09:16 PM
  #587
JDMchris.com's Avatar
I run THIS
i ran them for awhile running 195/45/16. You will rub. mine didnt rub, but i ran my coilovers on the stiffest setting so they wouldnt.
Old Apr 25, 2007 | 12:18 AM
  #588
milano sol's Avatar
agree with Chris here.
you can run a 195 or 205 width tire with that width of the rim. sidewall can be anything from 55 (stock....wouldnt go higher than that) to 45 (more ideal considering the tire will be on the fender lips anyways.
but yeah prepare for rub with that offset.
Old Apr 25, 2007 | 07:11 PM
  #589
YeeFit's Avatar
how bad is the rubbing at that offset? can you live with it? and how damaging is it? will it just rub the inner fender well plastic til its worn? then it'll stop rubbing right?
Old Apr 25, 2007 | 08:15 PM
  #590
I run THIS
with that offset youll be rubbing on the fender itself. Might bend out the shape of the fender a bit.
Here it is on my car, you can notice it sticks out a bit farther than the fender
Old Apr 25, 2007 | 08:20 PM
  #591
YeeFit's Avatar
I see what you mean! thanks for the help... what if i went with a +35mm offset instead? would that be enough? or do you pretty much have to go with a +40 and up?
Old Apr 25, 2007 | 08:57 PM
  #592
I run THIS
35 wont be as bad. I would reccomend +38to+45
Old Apr 26, 2007 | 09:57 AM
  #593
tonejunkie's Avatar
Question Tire mounting? (another noob question)
I looked around and didn't find a thread on this so here it goes...
I bought some tires off the internet, does anyone have suggestions as to where to get them mounted on the rims? It may sound stupid, but I was just wondering because some businesses may not take it very kindly that I ordered tires from the net but others might be totally cool with it... and maybe this varies from location to location. Any thoughts? Thanks...
Old Apr 26, 2007 | 10:21 AM
  #594
Nuwin's Avatar
My only suggestion is to dig out the phone book and simply call some places. I bet most will do it because money is money. Just try to find the best deal.
Old Apr 26, 2007 | 10:27 AM
  #595
joe d's Avatar
When you buy tires from a shop, the mounting and balancing is free (part of the price).
But pretty much any place will mount tires you bring them... they'll just charge you for it. $15-25 per wheel is average.
Old Apr 27, 2007 | 11:32 AM
  #596
spreadhead's Avatar
Go to Find a Recommended Installer and see if they have a recommended installer in your area. They will probably do it for you.
Old Apr 27, 2007 | 02:31 PM
  #597
tonejunkie's Avatar
Thumbs up Thanks!
Thanks. It does look like $20 per tire, but that's not bad. The only place I could find tires for my wifes car at a decent price was online. The first name to come up on the recommended tire installers was the one I was thinking about going to. Thanks again!
Old Apr 27, 2007 | 08:40 PM
  #598
fit4kris's Avatar
These wheels/tires on the Fit...
Will the work? Memoryfab - Used JDM Wheels
I really really really hope they work. Any idea if they will? I know the offset is nuts and so is the tire size...HELP!!
Kris
Old Apr 28, 2007 | 03:03 PM
  #599
sortanewinatl's Avatar
Not likely. Between the extra 1/2'' in width, plus the 14mm difference in offset, they will almost certainly rub if it's lowered at all...and probably at stock heiht too.
Old Apr 28, 2007 | 03:40 PM
  #600
edorwart's Avatar
yeah, that looks like a recipe for rub-a-dub-dub! My 16 x 7 are +43, and If I put 12 mm spacers on I think I would be in trouble, If you rolled your fenders and left at stock height you can probably do it.
