Mileage reports: Manual transmission (5MT)
Old Sep 25, 2017 | 08:31 PM
  #1461
Sono's Avatar
Originally Posted by rjm161
I'm curious as to how you arrived at that number. I'm not trying to say I don't believe you...if it is correct, I will be thrilled!
The reason I ask...the tank should last longer than 300 miles so I'm wondering how you calculated.
My (albeit very unscientific) method is to fill the tank all the way, until it won't take any more and reset the trip odometer. I then wait until I get really close to empty and refill all the way again. I then divide the trip odometer number by the exact amount it took to fill the tank.
I am not expecting gas mileage miracles, but it would be nice to average 35 mpg. I do about 70% highway and 30% city. I am wondering how much the high revs at 80 mph will hurt my highway numbers. That will be a seperate test down the line, once the car has about 5000 or 6000 miles on it.
This is how I figure mine as well or by taking the last receipt and current to calculate exactly how many gallons were used divided by the mileage. I am averaging between 35-40mpg mostly highway driving at speed limits (sometimes a little over on highways ) Lately I noticed a little less power to get up and go which I assume is spark plugs as all maintenance, new tires and shocks were done. I tried to change the spark plugs but the screw holding the tower on, #1 was tight all the way out, #2 snapped the head off and I had to drill it out and use a bigger screw with a nut so I didn't attempt #3 and #4 and just left it like it was. So I bet the plugs are original to 2008.
Old Apr 30, 2018 | 05:56 PM
  #1462
evilchargerfan's Avatar
Originally Posted by Fit Charlie
After:
After a few months the sides got pushed back, but I'm still pulling down better than 50 mpg. I'll reinforce and reseal the thing before the cold hits.
any more details/a how-to on that grille mod?
Old Jun 11, 2018 | 02:26 PM
  #1463
Jared592's Avatar
Seconded, I'm curious too.
Old Jul 2, 2018 | 01:37 PM
  #1464
san diego to vegas - 333+ miles
about 42 mpg
vegas back to san diego - 333+ miles
about 41 mpg
Old Aug 13, 2018 | 01:53 PM
  #1465
MontrealFit2012's Avatar
Gas consumption
Hi
just got a 2012 Fit Sport manual
it says I’m averaging 10.5 per 1/100 km per city driving. Witn AC on
is that the typical consumption?
im reving the engine here and there enjoying the MT
Old Aug 14, 2018 | 11:58 AM
  #1466
JonStewartMill's Avatar
10.5 liters per 100 km ? According to this calculator, that comes out to 27mpg. Pretty bad, in other words. My 2011 MT Fit Sport gets about 36mpg (7.8 liters per 100km) in combined driving.
Old Aug 14, 2018 | 12:34 PM
  #1467
MPG read out
Hi
just getting used to the gas consumption read out
how does it re adjust itself?
apparently my average is not so good 27 mpg (city driving and a bit of high reving fun)
Dan
Old Aug 14, 2018 | 01:20 PM
  #1468
I stand corrected. My 36mpg is an outlier according to fueleconomy.gov -- the 2011 Fit is rated at 29 mpg in combined driving.
Old Aug 14, 2018 | 07:54 PM
  #1469
GolNat's Avatar
Originally Posted by MontrealFit2012
Hi
Dan
This is what I have been averaging lately. AC on, spirited back road driving along with idling at work before I start. Went on a highway trip and reset the gauge and it was up around 32 with AC on. I don’t track my MPG I just drive the car but when I wasn’t using the AC my average was above 30 when I would think about looking at it.
Old Jun 18, 2019 | 11:13 AM
  #1470
after a little over 1 yr of ownership, and over 30k miles tracked/101 fill ups, I am averaging 40.2 mpg
Old Nov 28, 2020 | 06:53 PM
  #1471
Pierre Coutu's Avatar
Average fuel economy 2009 Base MT with 215 000 miles
Originally Posted by GoFits
i think 30-32 would be a close average for me.
lowest tank was 25mpg
highest was 40mpg
My average fuel economy over the last 56 609 miles is 36.8 mpg and my best was 46.8 mpg.
Old Dec 22, 2020 | 09:16 PM
  #1472
redsky's Avatar
mpg w/6-spd
31k on the clock. So far 42-45mpg combined driving
Old Jan 7, 2021 | 08:06 AM
  #1473
mobby_6kl's Avatar
Just had my first fillup in the 2004 1.3. It's around 7l/100km or 33.6 mpg or so. It's winter but that still seems pretty bad. I kept it under 120km/h (75mph) on the highway but might be giving it too much gas around town, we'll see. Hopefully it'Il get better as I get used to it because I could do just a bit worse (7.5-8l) in a Miata with double the power if i babied it.
Old Aug 13, 2021 | 10:34 AM
  #1474
mobby_6kl's Avatar
Much better results on big summer trip. mostly highway, maybe 15% country roads and 5% city. Some stop and go traffic on the highways, otherwise kept it at around 120-130km/h and 100 off the highway. No AC because it's broken
The average over 700km was 5.5l or around 42mpg, which seems pretty damn good considering I didn't hypermile at all.
Old Aug 14, 2021 | 02:23 AM
  #1475
Breezer's Avatar
I'm getting about 29 mpg, which makes me very happy.
My previous 3 vehicles got much worse gas mileage.
Old Sep 26, 2021 | 08:01 PM
  #1476
Plasmid's Avatar
my 2007 fit sport -- i get around 27-28 mpg. not as good as I expected
Old Nov 5, 2021 | 05:25 PM
  #1477
mobby_6kl's Avatar
Whoa, just did 5.2/100km aka 45.2mpg over 535km. Mostly country roads going through small towns, so either 50/100km/h. A bit of highway where I kept it around 110km/h. Highway is definitely killer since on the way there I went like 140km/h and got 6.2 or something like that.
Probably won't be able to do any better since winter is approaching. But it should be definitely possible with better tires, fixed EGR valve (apparently up to 5% reduction in BSFC) and driving a bit more carefully. Might be possible to get under 5l, haven't seen that yet.
Old May 21, 2022 | 04:55 PM
  #1478
GohanPoptart's Avatar
My 09 fit with ~180,000 averaged around 40 miles per gallon. Love these cars.
Old May 21, 2022 | 08:09 PM
  #1479
dave brown's Avatar
Did you calculate using the Fit’s built in calculator or did you track fuel at fill-ups and odometer?
Old Sep 21, 2022 | 05:03 PM
  #1480
mkchiu's Avatar
36.6 MPG
2.73gal/100mi
2721.071gal, 99682mi
MPG, partial
G/100mi, partial
