Old Apr 12, 2016 | 07:20 AM
  #8441
07FitSprt's Avatar
Originally Posted by cnordt24
Oh ok, well we are also heading to a meet at Warwick Aiport in Warwick, NY which can't be too far from you. It's on Sunday May 22nd, let me know if you are interested and I'll send you the details!
I will definitely let you know if its something I can make. Thanks for the info.
Old Apr 12, 2016 | 12:02 PM
  #8442
Fitguy07's Avatar
Did a little engine bay spring cleaning and some dress up. Cleaned the battery terminals, wiped down what I could, and installed some red and black fender washers and new oil cap. I have to address the rust eventually.
Attached Thumbnails What did you do to the GD Fit today?-20160410_174926.jpg   What did you do to the GD Fit today?-20160410_174550.jpg
Old Apr 18, 2016 | 10:10 PM
  #8443
DWils's Avatar
Last week I went to the emissions place. And failed. Turns out that the EGR was blocked off when the turbo went in and turned off when it was tuned. Unbeknownst to me, had I just checked the OBD2 Bluetooth sensor that I have I would have known that I was going to fail emissions. I came back home and later figured everything out with Previc's help and got the block off. The low-speed jittering that my car used to suffer from went away almost completely. I went back to emissions the next day and almost had a heart attack when I got to the front of the line. In Arizona there are two lines: OBD2 only, and the full-blown OBD2 and sniffer on a dyno line. I went to the OBD2 only line since I knew that I would instantly fail in the sniffer line since I might not exactly have a catalytic converter anymore. I almost got moved into the sniffer line, but thankfully I was able to stay in the OBD2 only line. The guy testing my car really liked it and kept on complimenting me on my car. I passed, and was extremely happy. Then later I filled up and checked my oil level and fuel efficiency. Somehow I'm up to a little over 32mpg (8.8L/100kms). It's back up to pre-turbo levels and hopefully it stays up there.
Old Apr 19, 2016 | 07:20 AM
  #8444
07FitSprt's Avatar
Very cool! There's nothing better than when its back to feeling like stock... Until you punch it!! Enjoy.
Old Apr 19, 2016 | 07:47 PM
  #8445
dwtaylorpdx's Avatar
And this is proof that disconnecting the EGR is a bad idea.. Cool to see it kinda prove out.
I run a random technology cat on my non daily toy, all the power and it passes with room to spare on gas content.. Gotta like that..
Old Apr 21, 2016 | 10:49 PM
  #8446
F-it good's Avatar
Installed one 1.25" wheel spacer. Only one today because I need to cut the rest of the fiber glass and metal fenders.
Clean above shot
Will install my drilled rotors on later, repaint my calipers back to a glossy black and get new excel g or tokico blue shocks.
Love how it sits flush with the fender.
Exposed tires, who cares I like the look
Attached Thumbnails What did you do to the GD Fit today?-80-image_4ada408632c1d9173ebf6366a37915dd9f306ace.jpeg   What did you do to the GD Fit today?-80-image_3e4b6915e388e8dcca894dc5616b23e034f51219.jpeg   What did you do to the GD Fit today?-80-image_c07dd6a251f5352228ffbb70d2b87eada5f54f81.jpeg   What did you do to the GD Fit today?-80-image_5430597ebeb7b2ca00247ccc44ce83b986839832.jpeg   What did you do to the GD Fit today?-80-image_5e03059915e3275d11743be103cea170498711d6.jpeg
What did you do to the GD Fit today?-80-image_cf7de3484e6e659b8e2f2c03698f868e5e6eb323.jpeg
Old Apr 21, 2016 | 11:42 PM
  #8447
jmsplitfyre's Avatar
Removed the front coilovers and gave it a little bit of cleaning and adjustment. The Function & Form Type II's don't go real low up front so I decided to push the preload a tiny bit more than advised.
Also today I received my parts to delete the CDV on my GD, which I will do on the weekend.
Attached Thumbnails What did you do to the GD Fit today?-1461207151171.jpg   What did you do to the GD Fit today?-dsc_0021-201.jpg
Old Apr 24, 2016 | 02:52 PM
  #8448
JDM dome light installed.
Attached Thumbnails What did you do to the GD Fit today?-80-jdmdomelight_a28bdde72cf07cf67cf19e17cf0a225ee661aae5.jpg
Old Apr 24, 2016 | 05:41 PM
  #8449
gd3david's Avatar
What's the difference between "fancy" and "room"? Lol
Old Apr 24, 2016 | 09:01 PM
  #8450
JJorda's Avatar
Today was general maintenance for me. New front pads/rotors. The old ones were factory original and lasted 113k+ miles. What a pain - so much rust keeping everything stuck together.
What kind of meet is there going on in Warwick? I may have to stop by if I'm free on that weekend. Either my '08 Fit or my '79 Civic.
Old Apr 24, 2016 | 10:11 PM
  #8451
Did the valve adjustment on the GD today with my friend's guidance. Only #2 & #3 intake were out of spec, the rest were ok.
Gonna do an oil change tomorrow and buy a new oem battery then the Fit will come out of hibernation after a year. Yay!
Old Apr 25, 2016 | 05:35 AM
  #8452
F-it good's Avatar
Finished cutting the other fiber glass fenders, still needs metal fenders cut but this will do for now. Installed all four wheel spacers, cleaned the fit up and brought it to a monthly car meet on Sunday's presented by prestige alliance off of i10 and blalock I think, not sure but was not far from memorial. Would love to see more Fits but like always, I'm the only one still.
That DA
Clean and simple
Was cool to see these hondas
Booty shot of flares with wheel spacers, planning adding 2pc black air diversion diffusers.
Made friends with this guy with the civic
Attached Thumbnails What did you do to the GD Fit today?-80-image_efd651439d7402ec32a6fd9efe9d8bc30b4fc079.jpeg   What did you do to the GD Fit today?-80-image_769c0f21488469817c38099ad94ad09f8514063c.jpeg   What did you do to the GD Fit today?-80-image_0f57899230b2a93192751a8504d21abe273e578c.jpeg   What did you do to the GD Fit today?-80-image_919028f1887199923d61482d28af148ef4e1ab6b.jpeg   What did you do to the GD Fit today?-80-image_95fbe1a906e1d6d942a8aaa99e6f0380ba23b1aa.jpeg
What did you do to the GD Fit today?-80-image_46c7b627e32f081b871a1351cd4b58814f05d4fa.jpeg   What did you do to the GD Fit today?-80-image_d494a242d3a7e2717b297434cbf00471ca1b9134.jpeg   What did you do to the GD Fit today?-80-image_ec41743bbf90f1fd95c59cb3ae2f9df210a41674.jpeg   What did you do to the GD Fit today?-80-image_4c6137a9e31449cbc4e056f1580f47ee62131776.jpeg
Old Apr 25, 2016 | 12:11 PM
  #8453
Room is the LED dome light. Fancy is a blue backlight. The center button is also a spot light.
Old Apr 25, 2016 | 03:26 PM
  #8454
ARC Magic type B oil cap with custom burnt titanium bolts.
Old Apr 25, 2016 | 08:26 PM
  #8455
That may be the worst car meet I've ever seen pictures of.
Old Apr 25, 2016 | 09:41 PM
  #8456
gd3david's Avatar
Oh I see. That's a neat part!
Old Apr 25, 2016 | 11:44 PM
  #8457
Hootie's Avatar
@F-it good: I THINK I may have been to that location before a couple of years ago. If I remember right there is a Freebird's World Burrito near that Academy in the background.
Anyway... Not too much action going on here for the GD3. Just the usual autocross, wash (every other week, sits in garage mostly), and occasionally taking it out to play Ingress.
I still need to raise it up on a lift at work and snap pictures of the rear disc conversion. May just do that when I rotate tires...
Old Apr 26, 2016 | 05:57 PM
  #8458
mangosmoody's Avatar
Painted the grille matte black and added the oem jdm ctr emblem. Also painted the lower grille matte black as well.
Attached Thumbnails What did you do to the GD Fit today?-80-20160425_232710_30fcde24575ed1249255bf2fb08ebf10b2415449.jpg   What did you do to the GD Fit today?-80-20160426_000634_a7dbba4ade56a57355c5b9646db6e7214ae1aa4f.jpg
Old Apr 27, 2016 | 01:33 AM
  #8459
F-it good's Avatar
There were so many cars at the meet, I didn't take photos of all of them, I just liked a few. There were lots of fancy bagged out cars but I preferred the little guys with cars that expressed them.
Old Apr 27, 2016 | 01:41 AM
  #8460
F-it good's Avatar
Yeah your correct on the location, I've been there just a few times. I did not know they were having a meet, was going home from work and seen these guys heading some where, so , I followed them and they led me to the meet which are the guys I am parked by. Yeah, I don't see many Fits out there but I try to represent the Fit community which is small �� I love attending these meets, gives me something to do and make friends, the guy with the black civic was cool. Hope to see you are any other Fits out there on there monthly prestige alliance meets. Was planning on making a decal that said either counterFIT or look Ma, dem hoes FIT. Hahah since everyone at the meet be having group decals on there windshields
