TIRE questions,sizes, mounting,pressures ANY tire questions
Old Jun 30, 2007 | 05:17 PM
  #721
Misha's Avatar
Originally Posted by kimo
What is the diffrence between 195x50x16 and 205x45x16. I think they are almost the same.
With 205/45x16 you will have slightly lower top speed ( 2% ) but proportionaly quicker acceleration, compered with 195/50x16 .
205/45x16 205-tire width in mm 45- sidewall hight in percentage of tire width ( 45% of 205 = 92.25mm ) 16- wheel diameter in inches (16")
Tire/wheel calculator - tire wheels n discount car at wheels-n-tires.com
N.B. As per Japanese "Hyper Rev" catalogue, for 16" wheels recomended tire size : 195/45x16
Old Jul 1, 2007 | 09:23 PM
  #722
surfchiro's Avatar
i just bought a fit and was under the impression that 18's would fit.. so im sure 17's will..
Old Jul 1, 2007 | 10:36 PM
  #723
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Done it. Hehee
Not a fan of beeech tire sizes. I had 225/50/15's on GSR Fat5's. Yes they rubbed but who cares. It'll rub away eventually. Also have 215/50/15's and currently running 205/60/14's. I wanted 215/55/14's but its a hard tire size to find. Im still planning on finding some sexy 13's, I want to be the first to run them.
I like aggressive stances; so I use tire sizes.
215/50/15's. 15x6.5in with a 42mm offset. Love this stance, probably the best tire size IMO.
225/50/15's. Should have been 45series but the tires were pulled from my Mx6's BBS wheels. 15x6in 45mm offset. Looked SICK but the rims sucked; too simple.
Current wheels. 205/60/14's. Sidewalls a little thick but stance is nice. 14x6in with a 35mm offset. I think?
Old Jul 2, 2007 | 04:56 PM
  #724
B( * Y * )BIES's Avatar
Lightbulb Subscribed
I too am interested in rollin on 17's but would also like to figure out (however possible) the widest tire width I could use without a widebody.
225/40/17, 17x7.5, ?? offset, would be sweet but looks like 215 is the widest without having to alter too much inner fender lip.
Old Jul 3, 2007 | 07:52 AM
  #725
lilcat's Avatar
17*7 +50 what tires?
just got my new wheels. thinking what tires on it. anyone knows the size good for those wheels? rubs or not. my car with S-tech on it. thanks for helping me......
Old Jul 3, 2007 | 08:30 AM
  #726
TeamEMC's Avatar
It;s not the inner fender lip that seems to be the problem. it looks like it's the black bracket that holds the rear bumber cover on. I've roled my fenders and ground out as much of the black plastic as i could, but Still rubbed even eith just myself in the car. I installed spring spacers in the rear which actually leveled out the car more. Ride height is about the same but no rubbing unless i;m in extreme conditions, new york pot holes etc....
Old Jul 3, 2007 | 09:02 AM
  #727
SPON FIT's Avatar
you ca stretch a 195/40 on it or go 205/40 and it probably wont rub with that high of an offset
Old Jul 3, 2007 | 09:24 AM
  #728
Illusive's Avatar
205/40 will not rub with that offset...heck you can probably go a bit wider with that offset
Old Jul 3, 2007 | 08:41 PM
  #729
norseofcourse's Avatar
when is size overkill?
I'm thinking of putting some new tires on my base model.
I have 15" rims and was thinking of either-
BF Goodrich g force sports, or the T/A KDW-2
or Nitto Neo Gens
in 195/55-15 or 205/50-15's
Any feed back especially if you think that going to 205's is overkill, would be appreciated.
Old Jul 3, 2007 | 09:45 PM
  #730
Posts in the NUUDE
Hehee... I had 225/50/15's on my Fit.
205's aint ish. Im running 205's on my 14in wheels right now. I wish I could have found wider tires.
Old Jul 4, 2007 | 12:32 AM
  #731
Thanks.... what do you think of the tire selection...?
What is your fav for grip?
Old Jul 4, 2007 | 12:59 AM
  #732
Sugarphreak's Avatar
Push My Button
I tried running 205/40/17's with a +42 offset... it rubbed with extra people or big bumps... and not just on the bracket! My rear fender lip was getting rubbed like crazy too! But important to note; almost no rubbing when I ran solo using that config.
I got fed up and switched to 17" rims with a +45 offset instead, shaved the bracket more (and even the fender a bit) and now I have no issues at all. If I had to do it all over again I would probably go with 16's to avoid the hassle.
Old Jul 4, 2007 | 04:04 PM
  #733
NatFit's Avatar
Flat tire at 1,500 miles? Grrr...
I've had my Fit (Milano Red sport m/t) for just over 2 months now, and have put only about 1,500 miles on it -- and it's already got a flat tire! What the hell? It's not like I'm doing off-road driving or anything... Can I complain to the dealer, or do I just have to suck it up?
Old Jul 4, 2007 | 04:15 PM
  #734
Cat's Avatar
Cat
I would have the tire checked for any possible reason that would explain a flat - nail, screw or unusual wear. If anything looks abnormal about the way the tire blew then I would get with my salesperson and have Honda double check it. A brand new tire with that few miles on it should not be flat unless something on the road was ran over, or if someone sliced it.
Cat :x
Old Jul 4, 2007 | 04:30 PM
  #735
dank24's Avatar
Psi in tires rapidly going down?
Well yesterday I put 41psi in the front tires and 39 in the back. I check it today and the front tires are down to 38psi. What would cause this to happen? I doubt I have a slow leak the car is only 5k miles old.
Old Jul 4, 2007 | 04:36 PM
  #736
kps's Avatar
kps
Honda Fit Forums Moderator
Temperature change, probably.
Old Jul 4, 2007 | 04:37 PM
  #737
JDMchris.com's Avatar
I run THIS
i was about to say this as well.
Old Jul 4, 2007 | 04:43 PM
  #738
dank24's Avatar
yea, I guess it could be. It was around 72 yesterday , and cold and rainy today. But it seems this has been goin on for a little while now. before i left for a 400mile trip this past weekend I put had 40psi in the fronts, and when i got to where i was I had 33. I dunno , just thought it was weird.
Old Jul 4, 2007 | 05:09 PM
  #739
Fit of RAGE's Avatar
just because there's only 5K miles on it, it doesn't mean that you can't have a leak. Maybe you ran over something. I'd check for a tire leak first.
Old Jul 4, 2007 | 05:15 PM
  #740
Illusive's Avatar
Isn't the recommended tire pressure for the Fit 30psi?
