TIRE questions,sizes, mounting,pressures ANY tire questions
Old Jul 4, 2007 | 05:52 PM
  #741
NineHotel's Avatar
It's obviously the dealer's fault. Take it back and demand they fix it.
Old Jul 4, 2007 | 06:57 PM
  #742
SPON FIT's Avatar
yeah id check for nails,screws,ect.
Old Jul 4, 2007 | 11:57 PM
  #743
Chikubi's Avatar
Originally Posted by Illusive
Isn't the recommended tire pressure for the Fit 30psi?
32psi F & R, cold pressure. Listed on the sticker inside the driver's side door frame.
Old Jul 5, 2007 | 12:08 AM
  #744
Illusive's Avatar
Yeah 32psi...I was thinking of my parents C Class haha. And I recall you should only take tire pressures when the tires are cold as the heat built up will increase the pressure as you drive, so there will never be a consistent value. Over inflation of your tires isn't good either...
Old Jul 6, 2007 | 01:36 AM
  #745
dank24's Avatar
g
I am going to rotate and check the tires tomorrow. Just weird though, all of the sudden I am getting horrible mpg, was getting 38-42avg, now I am getting 29-33avg. Out of nowhere too, same driving habits and all. All i can think of is the tires. It also started after i had the car to the dealership for an oil change.
Old Jul 6, 2007 | 05:00 PM
  #746
xorbe's Avatar
Originally Posted by dank24
IIt also started after i had the car to the dealership for an oil change.
After having mysterious items fault right after my Jetta would visit VW stealerships, definitely my Fit will never see one even for warranty work. I will fix everything myself, thankyouverymuch. (Yeah I've turned paranoid.)
Old Jul 9, 2007 | 01:37 PM
  #747
petren's Avatar
tires
Has anyone tried installing 205/55r15 tires on FitSport? What all season tires do people pick for the Sport version?
Old Jul 12, 2007 | 11:44 AM
  #748
squareback's Avatar
Probably, since it's a crappy size.
Honestly, since the size is so strange, I think you'll have a tough time finding it, and when you do, it may be expensive.
What caused the flat? Can it be repaired?
Old Jul 12, 2007 | 12:19 PM
  #749
petren's Avatar
Fit OEM Sport tires
It took me a while to read throughout this forum and I think I've got an idea what works and not on the OEM 15inch rims but what I didn't see was a clear answer to why some sizes were not considered. For example, FitSport OEM's are clearly 195/55r15 not 185/ 55r15 and not 195/50r15 as I noticed in other posts.
Most people were wondering whether 205/55r15 or 205/50r15 or even 215/50r15 were OK to use without rubbing or other issues and most said that 205/50r15 is what they tried although the 215/50r15 is the best fit for 0.08% speedo issues and looks in my opinion.
I think those who are considering upgrading, are thinking of:
1. speedo issues (best match is 215/50r15 with 0.08% difference in circumference according to this site:Car Bibles : The Wheel and Tyre Bible)
2. performance (best match would be 205/50r15)
3. looks 205/55r15 and/or 215/50r15
4. Rubbing (guessing best against rubbing would be 205/50r15)
I'd really like to get someone lile Jim @tirerack best bet on which of these sizes would be the best compromise for the OEM Fit sport.
I really tend to go with #3 and especially with the 215/50r15 as it would not throw off the speedo and looks good but have no idea how that will influence performance and whether I will have rubbing issues with the standard suspension. Comments? Jim@tirerack, please help
Nick
Old Jul 19, 2007 | 02:43 PM
  #750
setinstone31's Avatar
Unhappy Problems
I got an 07 fit, put 15" gsr hammers 4X100 ~38 offset 195/55 15 (front) 195/60 15 (back), but the ride is horrible, Fits right and flush, looks good but ride sucks steering is shaky, and leans to a side.
So I put stock 14s back on.
any help why this happening? Balancing? Tires?
Old Jul 19, 2007 | 07:54 PM
  #751
Raimondas's Avatar
Why do you want a tire on the back that is 3/4 inch taller then the front?
Old Aug 6, 2007 | 02:09 PM
  #752
the wheels had them on it, not by choice, lol. If anything I'd rather have the back shorter.
Old Aug 6, 2007 | 02:20 PM
  #753
mugenfit79's Avatar
Hello all, I purchased a set of 15X7 wheels and I was wondering if our stock Dunlop tires will work on these rims. I have a Fit Sport. Thanks!
Old Aug 6, 2007 | 04:07 PM
  #754
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Hammers? The Hammers are the old DA Integra wheels. Theyre 14in.
Others are called Fat5's and GSR Blades. I had Fat5's on my Fit with 225/50/15's. Rode Great. The Fat5's are 45mm offset.
You need the right size tires all the way around. Im sure they need to be balanced. How old are the tires? Maybe they have flat spots.....
That seems normal. Anytime people get a MPG drop its after an oil change. No one knows why...
Ive switched tires a lot and my MPG is always the same. However, my best was 38mpg. As of right now judging by my miles on my current tank Im probably going to get 33mpg.
Need more info. Offsets and tire size. What tires are on them, what are you planning to run?
Old Aug 10, 2007 | 11:23 AM
  #755
Mx6
Thanks alot
Old Aug 11, 2007 | 12:14 AM
  #756
jman245's Avatar
i just got some old 5 zigen div.3 n1r rims and was thinking of using 205/50/15 tires,will this be okay?not sure what the offset is,it came off an old hatch.oh yea, i am lowered on tanabe gf210
Old Aug 12, 2007 | 11:20 AM
  #757
N600 Nostalgia's Avatar
Re my P195-15-R15s, up from the base R14s, is the speed decrease effect linear or does one have to use an elaborate calculation to calibrate? Thanks. WKS
Old Aug 24, 2007 | 03:05 PM
  #758
TxTurboFit's Avatar
You might check to see if they changed your oil to 5w30 rather than the 5w20 that Honda recommends for the Fit. The reason I say this is because I had the same issue until I changed back to 5w20 oil.
Old Aug 30, 2007 | 08:58 AM
  #759
jim@tirerack's Avatar
Former Vendor
The best plus one is the 205/45R16. It will keep you within 1/10" of the original tire. If I can help let me know.
Old Aug 30, 2007 | 07:31 PM
  #760
Apex77's Avatar
Will there be any rubbing with a 3cm (1.18") drop and 16" wheels?
(Tires selected appropriately so Odometer is not affected).
What is the biggest wheels the Fit can take without tire rub?
