Scan gauge schooling
Old May 15, 2008 | 03:59 PM
  #141
Fray Adjacent's Avatar
Senior Member
Sweet! My ScanGauge is in my grubby little hands! I'll plug it into the car when I go get some grub later.
Any tips on how to get it going? The manual doesn't break it down into sections... but I'll give it a read anyway.
Old May 15, 2008 | 05:45 PM
  #142
suketoborudo00's Avatar
setup the scangauge with these settings
engine: 1.5 Liter
engine type: gasoline
fuel cutoff: mine is at 17 (but scangauge manual says to add 4 to the TPS gauge gives you when the foot is off the throttle. so for me when the foot is off the throttle, TPS reading is 13. so 13+4= 17 for the fuel cutoff)
tank size: put it at 10 gallons at first. There is a section in the manual that tells you how to adjust to the correct tank size on your next fillup.
I think those are the main ones you need to get it started, i missed a few because i'm going off memory
Old May 15, 2008 | 05:54 PM
  #143
Senior Member
Thanks. I'll get to plug it in and play around with it soon!
Old May 15, 2008 | 05:58 PM
  #144
solbrothers's Avatar
you won't be disappointed!!!! the scangauge is addictive LOL. such an awesome tool!
Old May 16, 2008 | 01:06 PM
  #145
Senior Member
I can tell it's going to be addictive! I already set up a couple of the trip gauges (today economy and tank economy) as xgauges.
I would like it if you could save a set of gauges as a screen, and have multiple screens you could switch between, instead of just cycling each individual gauge.
The ScanGauge will be an excellent tool in monitoring driving habits. Everyone should get one!
Old May 16, 2008 | 01:31 PM
  #146
pb and h's Avatar
STOP IT! I might have to breakdown and buy one!
Old May 17, 2008 | 04:15 PM
  #147
dyussen's Avatar
xgauges
Hooray! My SG showed up yesterday. Love this thing! Already installed and did a first fillup. I programmed trip MPG, day MPG and tank MPG as xgauges , just showing trip mpg on gauge screen along with rpm, realtime mpg, AIT. Tried to put in tank distance (34) but nothing shows - anyone else tried this? I suppose I can just use the dash trip display for this but I wanted to check if they would measure the same for a tank or two, and if not adjust speed setting on sg. Any other highly recommended xgs?
I'll post a pic later. =)
Old May 17, 2008 | 05:10 PM
  #148
RichXKU's Avatar
Not an Xgauge, but I would leave water temp up (°FWT) as the "cold" light will go out long before the engine is actually warmed up.
125°F - Cold light goes out
173°F - Engine is actually warm
Old May 17, 2008 | 05:12 PM
  #149
what/!?!? how do you do the trip MPG on the xgauge? i want!! i have RPM, MPH, current MPG, and IAT as my 4 gauges. i'd love trip MPG instead of IAT
Old May 17, 2008 | 05:26 PM
  #150
RichXKU's Avatar
It's in the manual in the xgauge section... it tells you exactly which numbers to enter.
Old May 17, 2008 | 05:39 PM
  #151
thanks!! i'll look later
Old May 17, 2008 | 06:08 PM
  #152
dyussen's Avatar
Talking
"00" for the TXD. Manual has more detail - page 30, http://www.scangauge.com/support/pdfs/SGMan5_0.pdf
Here's one more vote for above the steering col.
Old May 17, 2008 | 06:39 PM
  #153
pcs0snq's Avatar
I added HP to the X gauge. Anyone else?
Old May 17, 2008 | 10:06 PM
  #154
kmdebit's Avatar
Added the hp as well, but I've never seen it get over 60hp
I have Current and Tank MPG, WT, and IAT (or HP).
Old May 17, 2008 | 10:42 PM
  #155
pcs0snq's Avatar
Same here HP is less than I would expect. I may just delete that one. Was more of the coolness to try it. I may have gone WOT 5 times in 5000 miles
I only have current mpg as an X
I use trip Current and the reset, to help me see how it's going when doing something. It's very helpful. Try it.
I have yet to see one user that can look at the instant MPG and say it's this or that when driving. It's just all over the place. The X gauge Current can't be reset from the gauge view but can in the Trip view.
Old May 18, 2008 | 01:52 AM
  #156
Senior Member
I set up tank MPG and today MPG as two xgauges. With those on the right side, I have instant MPG and GPH on the left.
Nifty little gadget. Gotta put gas in the car tomorrow or monday... so a few tanks, and we'll see what the numbers show.
Today, I drove about 35 miles, and averaged 35.2 mpg. Not bad! I can tell the feedback helps, and I'll be able to wring out a couple more MPG.
Old May 19, 2008 | 08:50 PM
  #157
ricohman's Avatar
Can the Scangauge be set to read in Imperial gallons or litres?
U.S gallons are smaller than Imperial and it kind of confuses me.
Old May 19, 2008 | 08:55 PM
  #158
i set up an x gauge for the current trip MPG. definately worth doing!! i love having the MPG right next to the trip MPG.
btw, ive been getting constant 40+ MPG trips for the past 5 days. damn!!! i <3 hot weather
Old May 19, 2008 | 09:32 PM
  #159
pcs0snq's Avatar
Suggest you do not start messing with the calibration until you see a real pattern after 4 or 5 fills.
Just do the tank fill and adjust the $/gal and be done.
Keep a written log of the calculated vss SG tank MPG (for the tank) and you will see the variability is not in the SG but you and the gas pump....
Old May 19, 2008 | 09:37 PM
  #160
yes. i agree, that's why i don't pay much attention to people's calculations. the scangauge is an awesome tool. i suggest it to anyone with an OBD2 vehicle LOL
