***The Official SSR Intake DIY Thread (Sid Short Ram Intake)***
Old Jul 2, 2008 | 09:06 AM
  #101
doubler2k's Avatar
Originally Posted by Koi
So has anyone found a good way to mount these intakes so they don't vibrate and lower the possibility of it falling off while driving? I can hear the filter rattling a bit when it's under load sometimes. I want to keep it from vibrating against the radiator hose and battery bracket rod (I put a little plastic shield between the hose and the filter to remedy this for now). Tried buying the official intake mounting brackets from Spectre but they didn't work.
As long as everything is nice and tight all the way up it should reduce the vibration, also make sure the filter is pushed in all the way to the bend, I did that quite by accident and noticed a big difference in the shaking and rattling.
Old Aug 6, 2008 | 01:06 PM
  #102
DrKelso's Avatar
Will this work with any 3" intake filter? I'm assuming it will but I wasn't sure about hood clearance or anything like that
Old Aug 6, 2008 | 01:54 PM
  #103
Fitcapo's Avatar
Should work with any filter that can connect to a 3 inch pipe or the one I have actually has a larger opening but has two adapters to bring it down to 3" size.
Old Aug 12, 2008 | 01:57 PM
  #104
willy65000's Avatar
the breather filter i picked up states that it fits 3/8-1/2" tubes. should i have gone smaller?
Old Aug 15, 2008 | 06:02 PM
  #105
Sid 6.7's Avatar
Why so serious?
I updated my SSR intake in my personal Fit with the addition of another 90 degree elbow. Since everyone has commented that this would lower the intake temps, I decided it was worth a try.
Here are the pics.
Old Aug 15, 2008 | 10:29 PM
  #106
drzenitram's Avatar
lol, nearly twins!
Old Aug 16, 2008 | 04:08 AM
  #107
Fitcapo's Avatar
Here are the pics.
I changed mine from a 90 and a 60 to a 90 and a 90 because with the 90 60 it was rubbing on a hose and eating a hole in the filter. My filter is resting quite a bit lower than yours right now sid. I couldn't get it to not rattle when it was higher.
Old Aug 16, 2008 | 11:11 AM
  #108
drzenitram's Avatar
mine was rattling when it was over there, too. now, with a 60 and a 90 i just angle it down and it's about an inch from everything, doesn't rub on a thing or rattle.
Old Aug 16, 2008 | 02:48 PM
  #109
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
wow jason it looks so good
WHEN i get my fit, i want my engine bay to look just like yours
Old Aug 16, 2008 | 02:57 PM
  #110
Sid 6.7's Avatar
Why so serious?
Thanks guys.
Amazingly enough, I have no rattling at all and I did not have to move my battery or anything when I added the new 90 degree elbow. I've heard many have to loosen the mounting bolts and shove the battery as far back as they can within the mount.
The elbow just went right on in like 3 minutes, I wiped down the area with some spray detail (it was pouring down rain outside and I had pulled the nose end inside the garage) and then snapped the photos.
Old Aug 16, 2008 | 03:18 PM
  #111
yeah, it looks really good
Old Sep 4, 2008 | 08:55 AM
  #112
DrKelso's Avatar
Has anyone else had problems with the couplers not fitting easily over the pipes? I double checked and the couplers are made for 3" piping and the pipes are labeled as 3" but they won't go on without some serious elbow grease.
Any tips on how to get them to slide on easier?
Old Sep 4, 2008 | 04:34 PM
  #113
spearsoft's Avatar
I had the problem with the Plastic colored couplers, they were a real problem, so I ended up going with the couplers that came with the elbows.
Old Sep 4, 2008 | 05:40 PM
  #114
Fitcapo's Avatar
You have to fenangle them on a little bit but mine went on just fine. They are really hard to get off tho.
Old Sep 4, 2008 | 06:10 PM
  #115
SukebePAUr's Avatar
You know what, I'm going to try this SiD Intake. I've never really thought about it but this is pretty much what your buying when you get those Short Ram intakes. A tube with a filter at the end. I'll bite, I'm going to make one next weekend.
Old Sep 4, 2008 | 06:29 PM
  #116
ezduzit's Avatar
A little silicone spray or WD40 will make it a breeze.
Old Sep 4, 2008 | 06:42 PM
  #117
Sloto200's Avatar
you gotta lick it before you stick it right?? I spit on my finger... wiped in on the inside of the silicone boot and it slid right on with no problems!
Old Sep 5, 2008 | 12:51 AM
  #118
DrKelso's Avatar
I haven't yet had a chance to go out and actually install this on my car yet because of all the rain here around chicago, but I've been "test assembling" it and even with lubrication the sleeves don't slide in easily.
I've noticed that the sleeves need to stretch a bit in order to accomodate the piping. Do I need to heat up the silicon or something so it stretches easier? Or do I just happen to have defective parts? It all goes together, but I'm having trouble imagining it will be easy to fenagle these parts onto the TB and then wiggle the two bends onto each other very well once it's actually in the engine.
*shrug* I guess I won't know 'till I try, right?
Old Sep 5, 2008 | 11:04 AM
  #119
Fitcapo's Avatar
Well it shouldn't be too easy if they just slide on then it would be too loose and you would have issuse with it falling apart. It is almost a good thing that it is kinda difficult to get them together because that means that once you have it together it is going to be just as difficult for the engine to shake it apart.
Old Sep 7, 2008 | 01:21 PM
  #120
jvm051's Avatar
I'm thinking of doing this today, but was wondering what you are using to support the filter side of the setup? Or are you just letting it vibrate and move around? Just wondering with the radaitor hose underneath the pipe, that it might cause a issue, or vibrate itself apart after some time.
