T1R Turbo Kit
Old Aug 15, 2008 | 09:56 PM
  #261
BlueCell's Avatar
Originally Posted by fitDSfield
Uh... maybe this is off from the topic...
What's the mpg for the MT fit with T1R turbo type S?
I range from 28-32mpg in the summer, I dont drive to save gas at all.
Old Aug 15, 2008 | 10:03 PM
  #262
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Can someone run their T1Red Fit at the track? Kelsey wont do it because hes a jerkface.
I want MPH traps, thats basically it. 1/4 mile track if possible.
PLEASE!!
Old Aug 15, 2008 | 10:17 PM
  #263
BlueCell's Avatar
I'm possibly doing that on Sept 5th if I go that Friday to Houston. But if not, then I'm doing the 1/8th mile on the 6th. Not sure of the plans yet, but I'll let you know.
Old Aug 15, 2008 | 10:24 PM
  #264
drzenitram's Avatar
you know, marcus, from dallas to houston is 239 miles.. that's 956 1/4 miles.
that's a lot of drag racing.
Old Aug 15, 2008 | 10:28 PM
  #265
BlueCell's Avatar
Haha I know, I'm just going with the other Fit members going to the meet we're having on Sunday. They taking it to the track (hopefully) on Fri or Sat.
Old Aug 15, 2008 | 10:36 PM
  #266
Posts in the NUUDE
Wooo!!! Thats greats news. Cant wait.
Old Aug 26, 2008 | 04:08 PM
  #267
YeeFit's Avatar
PLEASE!!
I plan on getting my car dyno tuned on the 6th of September.. if all goes well I will try to go and make a few passes (1/4 mile) the week after.
I think there is a calculation to be made for elevation changes.. I live in Calgary, Alberta Canada and I think we are approximately 3500ft above sea level.. I think I've heard that it adds about 1 second onto a car that runs at sea level... so if I run 16.0 it would be equivalent to 15.0 at sea level.
Old Aug 26, 2008 | 04:17 PM
  #268
BlueCell's Avatar
Very nice. Our Fit meet in Houston is planning to go to the tracks on the 7th after our Go-kart meeting. Let's do eet!
Old Sep 8, 2008 | 03:47 PM
  #269
BlueCell's Avatar
So since we went go karting, and took most of the day, we all didn't get to hit the tracks. No times here.
Old Sep 9, 2008 | 09:53 AM
  #270
jsensk's Avatar
FWIW I took a ride in Blue Cell's car and was totally blown away. Amazing power and made my car feel so slow and worthless afterwards-- I gotta go FI.
Old Sep 9, 2008 | 12:00 PM
  #271
Previc93's Avatar
man im totally excited to get this kit!!!!
Old Sep 9, 2008 | 12:10 PM
  #272
YeeFit's Avatar
You won't regret it! I love mine. Did the install myself with a couple friends and it went smooth. Took us about 12hrs total time, but most of that time was spent doing a custom mount for the optional oil cooler and for the new washer fluid reservoir.
I got dyno'd last weekend and pulled 155whp on a mustang dyno @ 6psi. I still need to get tuned to our elevation (which is 3500ft above sea level), so I am hoping for a few more ponies. Mustang dyno's usually read a bit lower than a Dynojet and much lower than a Dynapack. If I were on a Dynojet and properly tuned I think I would be in the 165-175whp range.
Old Sep 9, 2008 | 01:49 PM
  #273
BlueCell's Avatar
That's some good numbers YeeFit. I expect mine to be higher than my last dyno although I haven't gone up there. I had a stock bpipe, I upgraded that. Messing with my boost a little now.
Old Sep 9, 2008 | 02:07 PM
  #274
Previc93's Avatar
cel still on?? i dont want it if that happens cause then i cant get it through emissions.
Old Sep 9, 2008 | 02:09 PM
  #275
BlueCell's Avatar
Can someone take a pic where that barometric pressure sensor is? I think it's on top of the intake manifold, but I'm not sure which one. I want to try something.
Old Sep 9, 2008 | 03:14 PM
  #276
YeeFit's Avatar
what are you gonna try? supposedly Ben will have a CEL fix and a new and improved 6psi map for us.. its supposed to be released soon.
Old Sep 9, 2008 | 03:30 PM
  #277
BlueCell's Avatar
A map is still a map that needs to be tuned specifically for your car. I don't know what other else he has done to the map. Anyways, I wanted to have a look at it first. I was thinking of putting a spacer if it bolts up to the intake manifold (like an O2 Fix). But I won't know until I see how it works.
Old Sep 9, 2008 | 03:43 PM
  #278
YeeFit's Avatar
Agreed.. I am getting my map tuned, but I am waiting to get his new map before I tune it.. no point really doing it twice.
I'm not sure if spacing the sensor will work like the O2 fix, the boost pressure will still get into that space.. kinda like how the BOV works. But its worth a try.. I heard someone tell me once that it could be fixed, but I can't remember how..
Old Sep 9, 2008 | 03:52 PM
  #279
kelsodeez's Avatar
UNBANABLE
the values need to be corrected in the ecu or someone needs to come out with a true engine management system for the fit. what is happening is the emanage is intercepting the signal to each of the injectors and adding more fuel to the mixture behind the ecu's back. the ecu read the values of the air coming into the engine and thinks its way too lean. i have a 4bar map sensor sitting in my parts box but i wouldnt dare install it without a reflash to correct the value spectrum. the new map that ben is making is like a band aid over something that needs stiches. all in all, i dont mind my check engine light being on. i know what my car is doing. i dont need an internal computer on the car to tell me whats wrong.
Old Sep 9, 2008 | 09:24 PM
  #280
FELIXY69's Avatar
I don't think the cel is such a big deal
its not gonna decrease performance!! So its just a light telling u that u have a trbo kit installed!!
