T1R Turbo Kit
Old Jul 28, 2008 | 10:28 PM
  #221
kelsodeez's Avatar
UNBANABLE
Originally Posted by FELIXY69
so when is that dyno graph comming ?
my dyno graph? not for a few weeks. the tuner i brought it to seemed like he didnt know what he was doing, and their dyno broke today so i am taking my car to so cal to get tuned by someone that knows whats up. also, i doubt the 175 whp run was accurate at all. we will see.
Old Jul 28, 2008 | 11:35 PM
  #222
ericman20's Avatar
Originally Posted by TitePhit
FYI, Mobil1 full synthetic extended life oil is one of the best oils you can buy. I've recently switched from amsoil to extended life. I've done some good research on this issue. At least this is my opinion. Everone has there own.
Words been around that Mobil 1 isn't too fond for Hondas?
Old Jul 28, 2008 | 11:38 PM
  #223
BlueCell's Avatar
From my 1 year of using fully synthetic, it burns kinda fast. Pitch black every 3k-4k miles.
Old Jul 29, 2008 | 12:20 AM
  #224
YeeFit's Avatar
Originally Posted by BlueCell
Yes actually that is recommended by shop tuners, a must buy is a wideband as one of the top gauges to buy when getting a turbo.
Really? I spoke with Ben @ AJ-R and he never said anything about an AFR gauge.
He just recommended Oil/Water Temp, and Boost.
I didn't get an AFR gauge.. is it really a necessity?
If so, which one should I get? and where is the best place to get one?
Old Jul 29, 2008 | 12:32 AM
  #225
BlueCell's Avatar
Yes those would be necessity too. But yea air/fuel is good to have because you want to know how much fuel is being put in your engine. If too lean or too rich, you're gonna blow.
Old Jul 29, 2008 | 12:43 AM
  #226
YeeFit's Avatar
Hmmm... but if I do not add any boost I shouldn't need any additional tuning correct? So if I stay with the 6psi that Ben sets it at, should I not be ok?
Would I get a CEL before I explode?? I just didn't budget in a $300 gauge!
Now I'm a little concerned...
Old Jul 29, 2008 | 12:46 AM
  #227
BlueCell's Avatar
You don't have to buy $300 dollar gauges, I just do for looks. They work well yea but you can always get cheaper gauges like ac autotechnics, autometer etc.
Old Jul 29, 2008 | 12:50 AM
  #228
YeeFit's Avatar
I actually bought Prosport gauges. But the only wideband A/F gauges I've seen for sale are all around $300... or can I just get a normal A/F gauge and not a wideband?
Seems to me the wideband ones are the $300 ones.
This is a the prosport version. Its a narrow band, not wideband. Would this be better than nothing? or is it pointless and I need to get a wideband one?
Amber/white Air Fuel Ratio Gauge
Old Jul 29, 2008 | 08:23 AM
  #229
Mr_ET's Avatar
narrowband a/f gauges are just a light show man I`ve had both narrowband and wideband in the past and you can`t even compare them.
If you plan to stay turbo for a long time and want to really properly monitor your engine you need a boost gauge, a wideband and probably an oil temp gauge to make sure the engine and turbo are getting adequate pressure.
with that said the only one I would REALLY recommend getting is a boost gauge. If the fuel and timing management on your kit is decent it should work for a long time without ever giving you any other hassle
Old Jul 29, 2008 | 08:51 PM
  #230
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Buy a wideband. Its a must. And seeing and hearing the T1R's kit runs around 13.0 AFR's Id highly suggest it. Thats really lean for a car with boost. Even on low boost.
No you wont get a CEL before the motor blows.
The main reason why I suggest a wideband is any kind of weather changes the AFR's of a car with FI. Moisture, cold, hot, all that can add or take away 1.0 AFR from the cars normal AFR's.
Old Jul 29, 2008 | 08:54 PM
  #231
Posts in the NUUDE
Damn man... Thats pretty shitty. IDK about the 175whp either anymore. Seems like his dyno was out of calibration. Probably why it broke.
If it was even broke. :-/
Im really interested in your dyno numbers and those AFR's.
I want AFR's before and after man. PLEASE!
Old Jul 29, 2008 | 09:18 PM
  #232
kelsodeez's Avatar
UNBANABLE
yea ill get all the printouts scanned when i get the tune on my car. i am so nervous about trailering my car 500 miles just to get it tuned. but id rather do that and get it tuned right than blow my engine.
Old Jul 29, 2008 | 09:23 PM
  #233
Posts in the NUUDE
DAMN! 500miles? That is a lot. :-/
But yea... At least its going to get done right.
Old Aug 5, 2008 | 03:53 PM
  #234
Hondady's Avatar
an external waste dump would be nice.
Old Aug 5, 2008 | 04:48 PM
  #235
YeeFit's Avatar
The T1R turbo has an external wastegate which dumps to the atmosphere
Old Aug 5, 2008 | 06:08 PM
  #236
Fa1's Avatar
Fa1
Coulda saved yourself a trip. Mase is in the bay area.
Old Aug 5, 2008 | 07:41 PM
  #237
BlueCell's Avatar
Lastest video from 0-over 90mph. about 6-7 seconds for 0-60mph.
YouTube - 0-60MPH run on my Fit
Old Aug 5, 2008 | 07:47 PM
  #238
YeeFit's Avatar
Niiiiice!Thanks for the vid BlueCell.. I'll have my kit hopefully installed this weekend.
Old Aug 9, 2008 | 03:19 PM
  #239
SWRWKFS's Avatar
I put in the t1r kit and my car wont start. the engine rolls over and tries to start but it seems like its the ingnition. I was using the stock spark plugs regapped.
I was wondering if anyone knew what the heat range is on spark plugs for the fit cuz i'm just gonna buy new plugs, or maybe just an opinion on whether to run hotter or colder plugs.
ty
Old Aug 9, 2008 | 03:30 PM
  #240
kelsodeez's Avatar
UNBANABLE
ty
sounds like the emanage isnt hooked up right.
