T1R Turbo Kit
Old Aug 9, 2008 | 04:01 PM
  #241
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
sounds like the emanage isnt hooked up right.
Any update man?
BTW, did you relocate the dump pipe on the wastegate? Its too close to the axle boot.
Old Aug 9, 2008 | 04:15 PM
  #242
kelsodeez's Avatar
UNBANABLE
Any update man?
nah, the location of the dump pipe is fine where it is. the only thing i would improve about this kit is the oil return line. it sits dangerously close to the driveshaft. and if that line breaks, goodbye turbo. goodbye engine.
i got my car dynoed. ill post the sheets in an hour. i gotta go take back the trailer to uhaul.
Old Aug 9, 2008 | 06:11 PM
  #243
Posts in the NUUDE
The dump pipe is right above the axle-boot.... Thats not fine.
Bad news bears.
How was the AFR's, numbers ok?
Old Aug 9, 2008 | 06:13 PM
  #244
kelsodeez's Avatar
UNBANABLE
Old Aug 10, 2008 | 12:16 PM
  #245
SWRWKFS's Avatar
well, i checked the emanage and it was hooked up right... but..
I had blown the ignition fuse somehow.... hahaha i dunno.
so i replaced the fuse and now have a running turbo fit! I just have to get it tuned!
OH and does anyone have the base map for the AT and the map for the MT? jw
Your Fit is awesome kelso... just thought i'd let you know. And thank you and Bluecell for answering like all of my millions of questions.
Old Aug 11, 2008 | 10:14 AM
  #246
YeeFit's Avatar
So, I got my kit installed this past weekend. It went pretty smoothly.. took me and a couple friends about 10-12 hours to get it installed. Only somewhat time consuming parts of the install were the mounting of the oil cooler kit and the smaller washer bottle..
The car is so much faster! I love th BOV sound and how it pulls.. I just have a couple minor adjustments to make to get it running good.
I have a couple q's for the other ppl with this kit.. I have a CEL on right now, I don't know what it is, but Illusive is bringing over his scangauge tonight to see what the code is.
Also, I have a little bit of hesitation in the acceleration and initial get go... its intermittent, but I don't think this is normal.. I have to give the car a bit more gas to get it going from a stop, if I don't it sputters or feels like it wants to stall... any ideas? I also noticed a couple times that if I accelerate slowly it will hesitate again around ~3000 rpms..
Apart from this little bug, the kit is awesome.. I love it!
Old Aug 11, 2008 | 11:40 AM
  #247
BlueCell's Avatar
You're welcome. If I got an answer, I'm willing to share it.
The code would most likely be the barometric pressure reading in the intake manifold. Did Ben not give you his latest fuel map?
It will hesitate around 3000rpms when your car is cold. When you warm up, it will go away. Actually, someone else with a TC has the same problem. It's an emanage thing and I haven't really looked into it.
As for the stall start, you should retune it to give a little more fuel in the idle range. I noticed it was a little low and just added some more. It's fine now.
Enjoy your kit, make sure its broken in to
Old Aug 11, 2008 | 01:14 PM
  #248
YeeFit's Avatar
Thanks Blue.. I'll call Ben to see if he did or didn't give me the latest map. Was it hard to adjust the idle? did you do it yourself or should i have a shop do it?
Old Aug 11, 2008 | 01:29 PM
  #249
BlueCell's Avatar
You can do it yourself with a computer. You must have a 2.0 USB cable though. I can't tell you exactly how much more to put it. It's been a while. I think it was at -.25 at start and changed it to -.35, correct me if I'm wrong. I did it at the shop, but he was telling me what he was doing while I was watching him do it. It's just for the 500-1000 rpm. The shop guy put lower fuel to try it out and my car died sometimes on a cold start up. So just a little more than the preset should be good. I can ask for you next time I go to the shop, but I don't know when that will be. Or ask Ben while you are at it.
Old Aug 12, 2008 | 10:29 PM
  #250
Stevens24's Avatar
I was set on the high boost supercharger but it seems to be taking forever and it seems like it really cram your engine compartment. I may switch to this turbo instead. Does it leave a little more room in the engine bay?
Plus it seems that except for JDMChris everyone is dynoing at 120-125hp on the base kit. I'm just trying to get to 150-160hp.
Old Aug 12, 2008 | 10:33 PM
  #251
BlueCell's Avatar
It crams engine space for the intercooler pipings and intake piping. But otherwise theres still a big hole on the front of the engine, to the driver side.
Old Aug 12, 2008 | 10:38 PM
  #252
kelsodeez's Avatar
UNBANABLE
yea it doesnt seem as crammed because it doesnt have that tube over the intake manifold but it does deff get more crammed for space
Old Aug 12, 2008 | 10:44 PM
  #253
TOOL's Avatar
Lastest video from 0-over 90mph. about 6-7 seconds for 0-60mph.
YouTube - 0-60MPH run on my Fit
GREAT video man!
Thanks for sharing
Old Aug 12, 2008 | 10:47 PM
  #254
Stevens24's Avatar
That still looks nicers than the KWSC engine bay. I had a jackson kit on my integra back in the day, but I'm afraid that the highboost kit with Hondata is going to be 6k which just seems like a lot to get to 160hp.
Thank for the responses so quick.
Old Aug 12, 2008 | 10:49 PM
  #255
BlueCell's Avatar
I have a picture posted on page 4. Wow Kelsey, I can barely tell you had anything in there. Its so stealthy.
Old Aug 14, 2008 | 01:00 AM
  #256
SWRWKFS's Avatar
um...
when i plug in my laptop to the emanage and start the car, it gives me an error reading that says "low v-tec at 1000rpm" ...help?
I got the map from ben like 2 days ago, and my car wont let me go over like 3200 rpms, in addition to the error reading. not good huh?
any ideas?
Old Aug 14, 2008 | 01:02 AM
  #257
BlueCell's Avatar
That low vtec signal is always an error. It's normal Ben said. You cant go over 3200 rpms?
Old Aug 14, 2008 | 01:16 AM
  #258
kelsodeez's Avatar
UNBANABLE
um...
any ideas?
sounds like your car is running in "limp" mode. try resetting the codes and check your fuses.
Old Aug 14, 2008 | 03:29 PM
  #259
SWRWKFS's Avatar
I reset the codes. And checked all the fuses.
Started the car and still no change.
Maybe i did something wrong with emanage wiring even tho it looks right and works.... i dunno.
Old Aug 15, 2008 | 09:15 PM
  #260
fitDSfield's Avatar
Uh... maybe this is off from the topic...
What's the mpg for the MT fit with T1R turbo type S?
