***The Official SSR Intake DIY Thread (Sid Short Ram Intake)***
Old Sep 26, 2008 | 03:17 AM
  #141
macbuddy's Avatar
Check the breather vent...
Originally Posted by honda_s2k
Hullo everyone.
My brother just did this install, the 2 90° pipes so the filter is in front of his battery.
He is experiencing a "raspy" noise and is afraid that something is wrong.
I'm assuming its not anything wrong. I had a AEM V2 on my S2000 for months and it gave it a roar from under the hood
Try checking the crankcase breather vent, make sure that it isn't plugged up.
-macbuddy-
Old Sep 26, 2008 | 11:22 AM
  #142
honda_s2k's Avatar
Ok, i'll get him to take a look at that.
Thanks. He's a few hours drive away from me. He's in Cleveland, OH.
Old Oct 3, 2008 | 05:35 PM
  #143
Texas Coyote's Avatar
I had a AEM cold air intake on my Fit until I damaged the filter end when I ran over an alligator and did $2000 dollars worth of damage to the front end and other plastic parts on the underside of the car. I had to remove the lower tube of the CAI and I bought a filter with a conical shaped rubber mounting base at O'REILLY Auto Parts and mounted it on the throttle body mounted pipe. It is now a short ram intake and has never ran better. Texas is very hot in the summer, but the heat has not made a noticeable negative difference even though the 1/2 of the filter is behind the radiator and in the hot air flow. It also floods here at times in a very short period of time and I don't have to sweat that as much now either. I like seeing people that are creative enough to use their brains instead of a credit card, just to get a decal. The end result is so close and looks so good as well.
Old Oct 4, 2008 | 05:28 PM
  #144
pb and h's Avatar
Well, I finally made my intake and it only cost $45 using the parts from O'riely and Advanced Auto, I only made one in hopes of better mpg :
Old Oct 4, 2008 | 05:49 PM
  #145
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
oh my god clean your engine bay!!
all that dust is going to make ME sneeze
Old Oct 4, 2008 | 06:28 PM
  #146
That will work. That is the same type of filter that mine has, the throttle body side is funnel shaped and and works like a velocity stack. Don't believe anyone that says that it will use more fuel, because the engine management system will compensate for the additional air flow and the air to fuel ratio will remain the same. Also the drive by wire throttle body will not open as much at low RPMs which in turn increases intake velocity and increases torque. As for the dust, mine is much dustier than that. If I washed it off every time it got that way I would be a busy man. Country living, I would guess. Dust is a small price to pay when you get to drive on roads that twist and turn and go up and down hills.
Old Oct 11, 2008 | 08:21 PM
  #147
Nerv2g's Avatar
Did mine today! Awesome right up +1 rep
Old Oct 24, 2008 | 06:41 PM
  #148
Sam Misled's Avatar
Sweet!
Just put mine on. This write up helped a lot. +1 Rep for you!
Old Oct 25, 2008 | 01:51 PM
  #149
silverbulletfit's Avatar
what about when it rains? is a bypass valve necessary?
Old Oct 25, 2008 | 07:10 PM
  #150
Sam Misled's Avatar
I washed my car right after I put it on and no water was even near the intake.
Old Oct 27, 2008 | 05:33 PM
  #151
im doing this tonight. ill post pictures later on when im finished! :]
Old Oct 28, 2008 | 01:08 PM
  #152
so i finished up my intake. couldnt take pictures last night because i did it in the dark and all i have is a crappy camera phone. these are the best i could get:
im gonna change the 60 to a 90 when autozone gets more in. the filters rubbing up against some shit but for now it works!
thanks sid for a great diy!
Old Oct 28, 2008 | 02:34 PM
  #153
Sam Misled's Avatar
Anyone know if it would be possible to turn this into a CAI? I might try it and see what I come up with.
Also, did anyone have any problems with their filter rubbing what looks like the radiator hose? How did you guys fix it?
Old Oct 28, 2008 | 07:34 PM
  #154
I had a AEM CAI and had to remove the lower pipe and get a new filter after an accidental collision with an alligator. Now it a SRI and it runs much stronger After some hard running while cruising in San Antonio, I had the hood up and noticed that the intake tube didn't even feel warm,even after numerous tire spinning starts and stop and go driving. I am sold on SRIs over CAIs. My young hotrodder brother in laws were both amazed at the difference.
Old Oct 29, 2008 | 10:09 PM
  #155
I loosened the radiator hose clamp and gave it a little twist , doesn't touch it now.
Old Oct 30, 2008 | 12:13 AM
  #156
Sid 6.7's Avatar
Why so serious?
I am so happy that so many FitFreakers are having such good experiences with this intake.
I sill haven't had the need to clean my filter. It is in very good shape and not covered in dirt at all. So depending on mileage and the are you drive in, the filter should last you a long time before you have to service it.
Old Oct 31, 2008 | 07:17 PM
  #157
Luichenwai's Avatar
Will a Fujita Filter work instead of the Sceptre?
Old Oct 31, 2008 | 07:37 PM
  #158
Luichenwai's Avatar
I'm looking at the pics of this one and the fujita SHORTY..... How come this one has a little breather... and the fujita doesn't?
Old Oct 31, 2008 | 09:52 PM
  #159
polaski's Avatar
Because technically that breather is "off road use only"
Did anyone remove that pesky support bracket off the tranny that the OEM box bolted to? I'm having problems with fitment because of that and that alone.
Old Nov 3, 2008 | 10:19 PM
  #160
polaski's Avatar
Well I don't think I have to remove that bracket. By sliding the coupler all the way up the TB I got just enough room to sit the filter on that bracket-- on the aluminum ridge in it-- and it still clears the metal framework above the headlight.
That's the price I pay for reusing the old AEM filter element from the civic. The size adapter kinda extended the pipe!
Still I want to leave it on. Man oh man it has a nice sound to it. Thank you Sid!
pic tomorrow
