Sugarphreak Troubleshooting Thread
Old Oct 27, 2008 | 08:31 AM
  #61
Mr_ET's Avatar
Originally Posted by Sugarphreak
Well officially back in town, been up since like 3:30am thanks to massive jet lag lol, I left Hangzhou Sat morning.... flew to Beijing during the day and then for like 12 hours into the night. I saw the sun rise again for Sat morning in Van
Going down to take the Fit out for the first time in over a month. Hopefully no flats or run down batteries.
Welcome back man!
Old Oct 27, 2008 | 10:35 AM
  #62
YeeFit's Avatar
Originally Posted by Mr_ET
Welcome back man!
Just in time for some wintery goodness!
Old Oct 27, 2008 | 12:41 PM
  #63
Sugarphreak's Avatar
Push My Button
Yeah what is this +2 weather, no wonder the rest of the world thinks we live in igloos!! Brrrrrr
Car started up no problem, feels nice to be behind the wheel again.
Old Dec 15, 2008 | 02:47 PM
  #64
Push My Button
So I think next spring I am going to pull the manifold and computer system from the Fit.
I will have the manifold pulled off and looked at very carefully by some of the top men.
Yes Top Men will look at it, Top Men
Old Dec 15, 2008 | 08:31 PM
  #65
Mr_ET's Avatar
lol
Old Dec 15, 2008 | 08:38 PM
  #66
kylerwho's Avatar
spoon fed
my guess is the tune...... well i know of a certain wearhouse down here in seattle where top men can look at it. ha ha ha
Old Jan 31, 2009 | 10:41 AM
  #67
Push My Button
Hey checkout the WR's newest "no-CEL" design... nothing in the middle, but two connecting channels I don't understand...
Old Jan 31, 2009 | 11:51 AM
  #68
kylerwho's Avatar
spoon fed
where will the hose for the egr plug into?
Old Jan 31, 2009 | 01:19 PM
  #69
alf74's Avatar
Very similar to my intake manifold (Italian Jazz)...
Old Jan 31, 2009 | 01:22 PM
  #70
alf74's Avatar
There isn't any hole... passages are inside head (maybe egr housing is different too...)
https://www.fitfreak.net/forums/fit-...fferences.html
Old Jan 31, 2009 | 06:06 PM
  #71
Mr_ET's Avatar
Tell them to send you this new one since the other one they promised without a cel didn't work and clearly didn't make power...
Old Jan 31, 2009 | 09:15 PM
  #72
Push My Button
No idea, the port is between the runners in the center, unless it somehow picks up the port with that channel... but then where does it vent and hook into the hose?
I am going to have to have a close look at the stock manifold, from what I remember this does not match at all
Old Jan 31, 2009 | 09:17 PM
  #73
kylerwho's Avatar
spoon fed
this design matches the jdm version intake manifold. the usdm mani looks so much differant. hmmm.... looks like weapon r messed up again.
yeah i just checked the manifold flange and it looks way differant than what they have designed.
Old Jan 31, 2009 | 09:24 PM
  #74
Push My Button
Yeah I don't know what is going on, I thought the JDM version didn't even have an EGR port there. The pre-production model I got from WR didn't have anything on the face... the second rev2 version has a port in the center which was drilled in.
Old Jan 31, 2009 | 09:49 PM
  #75
kylerwho's Avatar
spoon fed
the jdm version has these machined passages in the oem flange. i think that have not figured out the usdm fit yet. what if you just drilled out the hole on your flange and put in a bigger nipple to try and eliminate low egr CEL?
Old Jan 31, 2009 | 09:52 PM
  #76
Push My Button
I was thinking about something like that, it is a long slotted hole. I was thinking about matching it and welding on some kind of collector tube with a cap and then hooking the EGR hose into that.
Old Jan 31, 2009 | 09:54 PM
  #77
kylerwho's Avatar
spoon fed
why dont you? its obvious that the egr valve is just not getting enough pressure if its throwing a low code.
Old Feb 1, 2009 | 12:43 AM
  #78
Push My Button
lol, it is on the to-do list
Old Feb 4, 2009 | 10:10 PM
  #79
Push My Button
Hey check out what Leo just posted at the end of this thread... this explains all the trouble I have been having. The stock manifold is re-feeding the EGR gases back into the runners, I think everybody overlooked that. I always though it just fed back into the car.
I think I can drill some holes into the side of the runners where the bevel is and then just get two splitters and run the EGR gases out that way. That or copy the flange dremel. What do you guys think?
https://www.fitfreak.net/forums/fit-...tml#post567633
Old Feb 4, 2009 | 10:13 PM
  #80
kylerwho's Avatar
spoon fed
it looks like a job for a machine shop unless you have access to a vertical mill.
just send it in again for the 100th time and have them replace it.
