Quote:
Originally Posted by Syco54645
I calibrated it three times at the same pump since people said it is inaccurate some times after just one. Somewhere I read two was better, three was best.
It will never be 100% accurate. After first few fill ups adjustments. It should be less than 0.5 gallon off every time you fill up (if you use the same pump). I had it for almost 2 years and I still needed to make minor adjustment every time I refueled.
