Sugarphreak Troubleshooting Thread
Old Apr 17, 2009 | 01:21 PM
  #221
Sugarphreak's Avatar
Push My Button
Anyway, I talked with Bob today. He is going to try and source a 205/50 for me next week. If nothing turns up I have to order it in.
Old Apr 18, 2009 | 09:45 PM
  #222
Push My Button
Ok, so I think I tuned my car finally
E-manage sure doesn't make the car respond nearly as crisply as I originally though.
So this is a WOT 2nd gear pull from about 2000RPM to 7000RPM
I was trying to get it around the low 14's for the lower RPMs and then into the low 13's for the higher RPMs once VTEC kicks in. Although 14.7 is the so called "optimum" I figured I would take ET's advice and go for 3.1 at full WOT in the upper RPMs.
I did add a bit of fuel since this graph was made; near the top RPM's to smooth make it more uniform. I can't find the log for it now though, it was around the mid 13's on the final log.
Anyway, before I really touched anything (I did add some fuel between about 4500rpm & 6000rpm the end because it was down near 10.0 before) it was like this for a similar pull before;
Anyway, so judges; did I do good? lol
Old Apr 19, 2009 | 01:57 AM
  #223
Mr_ET's Avatar
You forgot the most important part, how does the car feel after tweaking it? The same, weaker, stronger?
Old Apr 19, 2009 | 02:55 AM
  #224
Push My Button
hehe, right
I took the car out this evening, it is running great. There is a noticeable reduction in throttle response and that sluggishness I have been complaining about for like a year now
Old Apr 20, 2009 | 11:54 AM
  #225
Push My Button
WOOT!!!!
Some tires just arrived today; Bridgestone RE-11's 205/50's
In case you can't tell... I am a bit excited
Hey ET, I want to book some time on the mustang dyno, maybe on the 1st weekend of May. What do you think?
Old Apr 20, 2009 | 12:39 PM
  #226
Mr_ET's Avatar
That weekend may or may not work since it's my daughter's birthday on the 4th and we are celebrating it that weekend.
Old Apr 20, 2009 | 01:52 PM
  #227
Push My Button
lol, ok don't even try to make it work if it is your daughters B-day!!
We can do the following weekend instead
Old Apr 20, 2009 | 05:01 PM
  #228
Mr_ET's Avatar
Following weekend the 9th should work
Old Apr 20, 2009 | 05:13 PM
  #229
projekz's Avatar
Why don't we make it a Dyno/ Fit meet day on the 17th?
Old Apr 20, 2009 | 09:02 PM
  #230
Mr_ET's Avatar
Now that's an idea!
Old Apr 20, 2009 | 09:37 PM
  #231
Push My Button
Yeah we could do that as well, anybody else want to put down some base runs?
Old Apr 21, 2009 | 11:42 AM
  #232
Push My Button
Where is the cheapest place to pick up Royal Purple synthetic?
Old Apr 21, 2009 | 12:35 PM
  #233
Mr_ET's Avatar
Mopac has some but not sure it's the cheapest? I'd normally get it through Projekz
Maybe I should bring the race car and dyno the 106hp lump :P
Old Apr 21, 2009 | 12:44 PM
  #234
Push My Button
You could bring it down for fun to see where you stand!
I don't know about Mopac, they were not that cooperative last time
I could probably switch to a different synthetic instead; I forget, do I need a special filter for synthetics?
I noticed my car turns 30,000 later this week
Old Apr 21, 2009 | 05:27 PM
  #235
Mr_ET's Avatar
I usually run an oem filter even with synthetic and it's always fine. You can always run a synthetic filter if it makes you feel better :P
Old Apr 29, 2009 | 09:20 PM
  #236
Push My Button
I think I am going to pop that dead pedal I got from YeeFit in today
Old Apr 29, 2009 | 09:41 PM
  #237
Mr_ET's Avatar
nice I have been loving mine for months fairly easy to install just be careful with that plastic piece not to break anything and you should be fine!
Old Apr 29, 2009 | 10:25 PM
  #238
Push My Button
Got it installed and tried it out doing some running around
Is dramatic eh? You can really brace yourself on it, it kind of feels weird after shoving my foot in at an angle for the past two years.
Picked up some Synthetic oil at Superstore; 4.4L of Mobile1 for 30$
Old Jun 6, 2009 | 11:16 AM
  #239
Push My Button
Bumping an old thread....
So I am going to have a bit of a fit over getting this dyno tune pretty quick. I get the feeling I am being blown off
Old Jun 7, 2009 | 08:51 PM
  #240
Mr_ET's Avatar
so any news from this weekend?
