Mileage reports: Manual transmission (5MT)
Old Jul 20, 2009 | 11:28 AM
  #1161
elohel's Avatar
^ Now that is impressive
Old Jul 20, 2009 | 11:45 AM
  #1162
RichXKU's Avatar
41-42 is right on the money of where a normally driven Fit should be, probably even better since the 09+ are geared shorter. Keep up the good work
I just filled up: 45.1 MPG.
That's 534.2 miles/tank for those keeping score at home...
I think the Mishimoto CF shorty intake has helped due to higher intake temps.
Old Jul 20, 2009 | 10:05 PM
  #1163
SCBarren's Avatar
Hmm, I should look into the intake possibilities. I'd love to achieve even 500 miles on my tank. Is that after running it past empty? Or was this at the point of the gas light turning on? That would blow mah mind! But I'm still damned happy with even 40+ xD.
Old Jul 20, 2009 | 10:49 PM
  #1164
RichXKU's Avatar
That was about 10 or 15 miles after the gas light came on. But that also included filling almost to near the top. You can "fit" about 2 gallons more after the pump clicks off, it just takes a bit of time, because you have to wait for the foam to go down.
I can usually drive about 150-160 miles from "pegged" to the "F" slash.
Anyway, keep up the good work man!
Old Jul 20, 2009 | 11:20 PM
  #1165
SCBarren's Avatar
Will keep this in mind for future road trip events
Old Jul 20, 2009 | 11:49 PM
  #1166
Contrabida Face's Avatar
i don't know how you guys do it. i average around 32-36mpg with mixed city/highway. the highest i've done was ~40-42mpg on my road trip from vallejo, ca to biloxi, ms. i don't drive like a jerk, i drive pretty conservative mostly. where is the best shift point? i usually shift at around 2600-3000. is that too high? i don't want to shift too fast to a higher gear to over load the engine. i wish we had a 6th gear for the freeways.
Old Jul 21, 2009 | 10:40 AM
  #1167
SCBarren's Avatar
Depending on the gear or how fast I'm going I tend to shift a bit lower. Generally around 2000-2200 RPM's, which can be too low at times, so I don't always. But, if I'm doing flat driving I get better MPG's (city speeds) in higher gears.
Old Jul 22, 2009 | 09:13 PM
  #1168
rickbhill's Avatar
I have filled up 4 times with my new Honda Fit Sport. Every time the electronic average MPG indicator shows my average MPGs to be 2-5MPG more than my odometer/fuel pumped calculations. Is everybody else experiencing the same difference?
Either the electronic indicator is wrong or the gas stations are under pumping gas.
Old Jul 24, 2009 | 12:05 PM
  #1169
SammiJo's Avatar
+1.
Getting ready for an 800 mile road trip next week. Will report back with MPG.
My average around town is 36 MPG. And I'm not a conservative driver.
Old Jul 24, 2009 | 12:22 PM
  #1170
anniemcu's Avatar
...i wish we had a 6th gear for the freeways.
Originally Posted by SammiJo
+1.
+(another)1
Old Jul 24, 2009 | 12:53 PM
  #1171
RichXKU's Avatar
6th sounds great but what we really need is just a longer 5th. All they would do with a 6 speed is copy and paste the ratio for 5th to 6th, then make 2-5 shorter.
Honda is prioritizing peppy over MPG in the Fit, the 09s have an even shorter highway gearing than the 07-08.
--Begin real math--
07-08:
5th: 0.757
Final: 4.294
3.25 engine revs per axle rotation in 07-08
09:
5th: 0.727
Final: 4.62
3.36 engine revs per axle rotation in 09.
So the 09s are revving 3.3% higher than the 07-08, and get only 93.5% of the combined fuel economy of the 07-08
--End real math--
If I extrapolate, then the 2039 fit will probably get around 9 MPG and be at 7613 RPM on the highway.
Old Jul 24, 2009 | 01:16 PM
  #1172
SammiJo's Avatar
2345
Old Jul 24, 2009 | 01:17 PM
  #1173
honda2112's Avatar
Beginning of the month trip to NYC from South Hadley, MA: moved a friend from Queens to Brooklyn, drove around both cities with stop and go around rush hour then back=43mpg. Week after to the beach in New Hampshire to Newbury Port then back home= 42 mpg. Work week, 15% highway= 39.7mpg. Not too shabby!
Old Jul 24, 2009 | 01:42 PM
  #1174
Texas Coyote's Avatar
I believe I read that the U.S. market Fits have been geared lower because of the added weight to meet safety requirements, lower octane fuel and fat people not to mention the obsession with 0 to 60 times..... British motorcycles were geared lower for the U.S. and Harley-Davidson put an international belt pulley and shorter drive belt on the big twins sold overseas.
Old Jul 25, 2009 | 06:29 PM
  #1175
Black01's Avatar
I just filled up. I know this is not impressive but 339.9 and refilled 8.158 = 41.66mpg. This is driving the car hard, hitting VTEC and sometime going 5k-6k rpms. This is excellent mpg for a Fit driven hard.
Old Jul 25, 2009 | 06:46 PM
  #1176
wdb's Avatar
wdb
It's the electronics. Gas station pumps are tested by duh gummint every so often, and it really doesn't pay them to cheat.
Old Jul 30, 2009 | 06:09 PM
  #1177
kirsch92's Avatar
Happy after First Tank
09 Taffeta White Sport 5MT 1st Tank
Mileage indicator read 45.9 mpg
Actual mileage was 40.26 mpg
Mostly highway driving, but a lot of up and down hills.
Light foot on the go pedal with tach 2k-3K seems to work best.
A/C really works that tiny motor too.
A light car and short gearing really hurts it on the downhills.
I think neutral coasting would really boost the mileage on the downhills.
I have a 2 mile downhill where the Fit slows down on a 5th gear coast.
My 04 Odyssey is accelerating on its own and would be happy to be doing 75 without some braking to keep it in check.
Old Jul 30, 2009 | 06:15 PM
  #1178
rickbhill's Avatar
Unbelieveable! And that is completely stock? I just tested my 5th tank: 26.3MPG (all city driving). Still the best I've reached was 33.5MPG (Mostly highway with A/C use). I switched from neutral coasting to coasting in gear when possible because I've been told the computer shuts off fuel injection at those points.
I don't even look at the electronic mileage indicator anymore because it is always 3-5MPG higher than when calculated at the pump. Definitely an unsatisfying add-on by Honda. I would have rather they left it out and saved me the money.
Old Jul 30, 2009 | 09:47 PM
  #1179
kirsch92's Avatar
Completely stock. I drive to and from work at odd hours, with only a few lights on the drive.
I know a lot of people don't like the real-time mileage bar, but it seems to remind me to keep a light foot on the gas.
I mostly coasted in gear, but I found I was losing a lot of speed doing so, so I experimented with neutral coasting. I was having to accelerate too much at the end of the downhill. I've been minimizing the A/C usage.
My 2nd tank isn't looking as good though. I went into Seattle for a Mariners game. Between the heat and the traffic, I think I am going to lose a few MPG. Plus I have a twisty back road I just HAD to try out on the way to work.
My real time bar spent a lot more time near the 20 MPG mark on that trip
Old Aug 2, 2009 | 12:07 AM
  #1180
nerual13's Avatar
First fill tonight, actual was 31.8, though the gauge read 36.9, so not sure what that is about. But, not bad compared to the 14 or 15 on my old Jeep. Stock, brand new Sport M/T that I've been taking out joyriding to break her in
