Mileage reports: Manual transmission (5MT)
Old Aug 2, 2009 | 06:51 AM
  #1181
anniemcu's Avatar
Originally Posted by kirsch92
... My real time bar spent a lot more time near the 20 MPG mark on that trip
At least the mileage monitor lies a bit in both directions.
Old Aug 2, 2009 | 12:19 PM
  #1182
Texas Coyote's Avatar
I have only driven a few cars with a mileage monitor and all of them gave readings that were exaggerated reading either on the high or low side..... They are still great tools for a driver to use to keep tabs on their driving skills or for entertalnment on long trips.
Old Aug 8, 2009 | 01:15 AM
  #1183
skydiverman's Avatar
Brand new 09 sport manual - mostly highway driving, but rush hour traffic. first full tank numbers - 39.86 mpg, computer on the dash says 48.6 no idea how to calibrate that thing. :-(
Old Aug 8, 2009 | 04:22 PM
  #1184
pcs0snq's Avatar
Originally Posted by RichXKU
6th sounds great but what we really need is just a longer 5th. All they would do with a 6 speed is copy and paste the ratio for 5th to 6th, then make 2-5 shorter.
Honda is prioritizing peppy over MPG in the Fit, the 09s have an even shorter highway gearing than the 07-08.
--Begin real math--
07-08:
5th: 0.757
Final: 4.294
3.25 engine revs per axle rotation in 07-08
09:
5th: 0.727
Final: 4.62
3.36 engine revs per axle rotation in 09.
So the 09s are revving 3.3% higher than the 07-08, and get only 93.5% of the combined fuel economy of the 07-08
--End real math--
If I extrapolate, then the 2039 fit will probably get around 9 MPG and be at 7613 RPM on the highway.
Check the Sport trie size '08 to '09
Old Aug 14, 2009 | 01:35 AM
  #1185
Flowe16's Avatar
Mileage
41 mpg on first tank, 42 mpg on second, thank god for cash for clunkers. Getting about three times the gas mileage that my 96 cherokee got
Old Aug 14, 2009 | 11:24 AM
  #1186
WGE's Avatar
WGE
I recently got back from another trip to hike and climb in Colorado from Nashville, TN. Last year's trip was about 3,300 miles and was started just after my '08 base manual Fit turned 500 total miles. The average mileage for that trip was 45.09 mpg via actual calculation, with the highest single-tank average of 50.9 mpg. For this year's trip, the total miles travelled was a little less at about 3,100 miles and again the average mileage was exactly the same 45.09 mpg and with the highest single-tank average of 47.3 mpg. Tire pressure for both trips was at about 45 psi. Of course, last year the car had the factory oil fill but this year I had changed the oil prior to the trip and used Pennzoil Platinum 5W-20. So, the full synthetic oil and 13,000 miles of break-in seem not to have been a means to better fuel efficiency, but I probably drove a little faster this year, so maybe it helped a little. Life-time fuel economy now after about 16,500 miles is 41.34 mpg. The driver's seat was more comfortable this year; either the Fit's seat or my seat got broken in it seems. The only car-related issue this year was I got a very small chip in the windshield in western Kansas. The Fit continues to please me a great deal.
Old Aug 14, 2009 | 04:27 PM
  #1187
bensenvill's Avatar
09 MT, just went through 2 full tanks of gas, calculating out my mpg, I've gotten 36mpg from each tank.
thats quite amazing because the whole new car thing, I felt like I was driving it like I stole it.... I guess I wasn't as lead footed as I thought.
also all those miles were around chicago and quite a bit of it stuck in gridlock. so I think those are some stellar numbers. 40mpg shouldn't be a problem at all.
Old Aug 14, 2009 | 10:24 PM
  #1188
anniemcu's Avatar
4th tank, got 35+, not being particularly careful and using AC a lot. 5th tank came out at 39+, with just reasonable care and even still some AC. I love this little vehicle!
BTW - that was actual calculated MPG's, not the estimated on the gauge, though it wasn't far off.
Old Aug 25, 2009 | 06:58 PM
  #1189
rangefit's Avatar
Actual calculated mpg after 1300 miles... 39.96 mpg. The mpg gauge avg is at 42.1 - that's driving it regularly and not worrying about mpg. It's been averaging about 4.5% to 5% off from actual. I drive a total of about 90 miles to/from work. It's also interesting the I get my avg up on the way to work and drops a little on the way home (must be uphill to work and downhill to home - midwest - pretty flat out here).
Old Aug 26, 2009 | 10:32 PM
  #1190
anniemcu's Avatar
Originally Posted by rangefit
.... It's also interesting the I get my avg up on the way to work and drops a little on the way home (must be uphill to work and downhill to home - midwest - pretty flat out here).
Hmmm... are you usually running a little bit late on you way there?
Old Sep 3, 2009 | 07:22 AM
  #1191
rangefit's Avatar
oops, I meant the other way around - downhill to work and uphill to home. I also drive leisurely to work and pretty excitedly on the way home. LOL.
Avg on the gauge has been sticking at about 41.5 which should give me about a 39.5 actual (from prev exp). I shift at faily higher rpms now and cruise at about 70mph.
Not bad fuel consumption at all if I may say so (coming from an 18mpg car).
Woo hoo!
Old Sep 3, 2009 | 08:08 PM
  #1192
dixeyk's Avatar
So far...
Over the first 1,000 miles (got the car used with 18K on it) we're getting 33-35 in not particularly careful city driving. Best tank was 39.14 on mixed driving including a drive up to Mount Baker fully loaded.
Pretty happy with it. I have yet do do any real highway driving so I haven;t seen 40+ yet but I am confident it can do it.
Old Sep 8, 2009 | 02:39 PM
  #1193
Shadow6453's Avatar
I just bought on 8/18 an 09 mt sport. Got it with 24 miles on it and its up to 1500 miles today. Computer indicates 39.5mpg and I checked it when I filled up today and I came up with 35.2mpg. I have checked couple times and it always seems the actual is 4mpg lower then the computer shows but I am still happy with it. I drive about 80 miles per day and a lot are freeway miles. I do notice myself trying to coast if red light ahead or setting the cruise. I think I will be able to get the computer to register 40mpg...as its summer in AZ and ac is running even at night an and will try to increase the tire pressure a little as friend told me he did on his 08 and have read may help with increase mpg.
I am a very happy FIT owner!
Old Oct 5, 2009 | 07:32 PM
  #1194
shane's Avatar
ok my first fill up was 345 miles on the trip, 1/4 tank of so.
AVG according to dash was 42.8 90% city
Actual was 40.5 so only 5% off
Old Dec 7, 2009 | 04:35 PM
  #1195
huisj's Avatar
Lifetime average is at 35.6 now. I've had the car since March. My mileage steadily increased from the time it was new through July, but it's been dropping a lot lately with the colder weather. I have a pretty short drive to work that has a lot of country roads mixed with stop signs or lights every mile or so, so my speed is all over the map. That's probably why I'm not able to get the bigger 40ish mileage on a regular basis.
The Fit M/T (Honda Fit) | Fuelly
Old Mar 12, 2010 | 01:26 PM
  #1196
ShotgunSi's Avatar
Just put my first tank into my 09 Fit Sport MT. I got an average of 39.1 mpg in 80% Highway 20% City. The car only has 400 miles on it, hopefully it gets even better
Old Apr 26, 2010 | 02:34 AM
  #1197
azizajalal's Avatar
hiiiiiiiiii
I just recorded 33.4 mpg all city/urban driving. does any one know what the likely hood of geting better mpg in the future? I know that some cars of the same make just do much better then others... thanks.
Tinting
Old Apr 26, 2010 | 10:38 AM
  #1198
carlosalicea's Avatar
Tinting
Easy: don't use the car.
I mean 33.4 is excellent. I get 30- 35 average and I drive like I mean to I don't check if I am doing it to get good MPG. Just drive it and have fun....
BTW my 07 sport manual has 107k already, so believe me the car is fast fun and economic.
Old Apr 28, 2010 | 09:45 AM
  #1199
ganginwood's Avatar
i was researching the average mpg for fits and came accross this site. since i bought my car i've been a little disappointed with its mpg. but after reading these threads, i'm hoping that its just a mechanical problem that can be fixed or its my bike racks.
quickly....i do a lot of cycling and keep my racks on the car all the time. but even before i added the roof racks, i never saw 300 miles on a tank of gas. granted...it was only for a week or 2 before i threw the racks on. now...i'm lucky to get 25. i'm going to start keeping thorough track of my mpg and going to remove the rack for a while to see what i get.
here's a pic of my set up. just wondering how much you think the rack w/out a bike on top would effect my mpg. i live in a hilly area of pennsylvania but have been disappointed with my mpg. any suggestions as to make this more efficient w/out having to loose the racks?
i'll keep you posted on my progress....
Old Apr 28, 2010 | 11:16 AM
  #1200
Roof mounted racks are bad news for fuel mileage on any vehicle.... You would do better fuel wise to mount a carrier hitch mounted rear rack. That is what a lot of my customers were doing 20 years ago when I was the owner of 2 bicycle shops.... I had put a roof mounted rack on an air cooled VW Beetle and couldn't even reach the highway speed limit when driving into the slightest head wind with nothing on the rack.
