Received Letter Safety Recall Drive Shaft ('09)
Old Apr 5, 2021 | 08:47 PM
  #81
Odie's Avatar
Took these tonight . Doesn't look good . Probably need both replaced . Plenty of rust is beneath flaking paint on the driver side .
Old Apr 6, 2021 | 12:51 PM
  #82
claycolvin's Avatar
Axles
I have a Florida car and live in Florida so no loss of protective covering. I sprayed oil on the dampers just as a precaution. May not make much difference. Others may want to do that too if not in the rust belt. Best of luck. Clay
Old Apr 6, 2021 | 10:42 PM
  #83
spin out's Avatar
ugh. this looks ugly. This is after 13 winters. In New Jersey they brine the hell out of the roads.... whether the forecast calls for less than 1 inch or 20 inches of snow.
Old Apr 7, 2021 | 12:54 PM
  #84
Odie's Avatar
Looks like both are in need of replacing .
Old Apr 7, 2021 | 05:58 PM
  #85
SiXiam's Avatar
Same here. I changed my oil today and had a look at mine. They look all rusted without any paint. So I guess I'll be getting two new ones whenever I do the recall.
Old Apr 7, 2021 | 09:32 PM
  #86
Odie's Avatar
Do we dare to keep driving ? Doesn't mention not to drive in the 2nd notice . Not sure if we'd be liable if there's an accident due to the axle(s) .
Old Apr 7, 2021 | 10:27 PM
  #87
spin out's Avatar
After I got a look at mine last night (for the first time), I had the same thought. I became instantly wary of driving the car.
I talked to 2 local honda dealers today and one of them (a guy at Freehold Honda) didn't even know there was a recall.
The guy at Open Road Honda wasn't aware of any particular problems with the shaft actually snapping.
The thing that would worry me about the pics you took is that your passenger side looks similar (but no quite as bad) to the condition of punx45's when his snapped.
Last edited by spin out; Apr 7, 2021 at 10:32 PM. Reason: needed to be more specific
Old Apr 8, 2021 | 07:55 AM
  #88
spike55_bmw's Avatar
In mid-March, I took my '11 Sport AT / 89k miles (salty winter Pennsylvania roads) in after getting the recall notice. They changed them out since the the remaining diameters were below spec. Sadly, I didn't take 'before' pics since I wasn't expecting to get anything for free from the dealer, but you can see the corrosion on the heavy extension shaft coming out of the passenger side of the transmission. My 'after' inspection showed new shafts on both sides. Also less 'slop' in the drive-line when I stop the car, put into 'R' to back into the driveway. What a bonus!
Old Apr 12, 2021 | 12:34 AM
  #89
greenpoint.fit's Avatar
No parts in stock
I just went to the dealer today in queens to have mine (09 MT) checked out. The service dept let me know my passenger side needs replacement, but to come back in a month when they have the parts. I might just wait two because who knows when they'll actually get them. It was good to get it checked out regardless, though i wish they'd told me no parts were in stock, I would have waited.
Old Apr 12, 2021 | 07:49 AM
  #90
Ultrawolf's Avatar
I was scheduled to have mine looked at today, but it's raining so I rescheduled. The dealer says they have the parts and can do the work right away. But I don't want to risk getting any water inside the sealed axle system due to the boots and other parts being wet. I know it sounds kind of extreme, but I've had issues with careless dealer service before. I don't think the service techs are paid to take time for things like drying off the area before taking things apart.
Old Apr 12, 2021 | 09:46 AM
  #91
ANGST's Avatar
@spin out @Odie
Yes, they look worse then mine did when mine snapped. Check out the pic https://www.fitfreak.net/forums/2nd-...ml#post1456847
Old Apr 12, 2021 | 02:17 PM
  #92
Odie's Avatar
Originally Posted by ANGST
@spin out @Odie
Thanks for getting back . Getting replaced within a week .
Old Apr 12, 2021 | 09:16 PM
  #93
Troymcclure's Avatar
Hopefully sooner than that for you. I took my manual 12 sport in today to get it done.
Old Apr 12, 2021 | 11:18 PM
  #94
Are you in the NY/NJ area? I went to Paragon Honda in Queens but would drive somewhere further if there's a dealer with parts in stock.
Old Apr 12, 2021 | 11:36 PM
  #95
Cincinnati area. Called the dealer on Friday after I saw the status changed from ‘recall open parts not yet available’ to ‘recall incomplete’. They said they didn’t have anything in but their system said it was available to order from the local warehouse. Monday I called in and it arrived so brought the car in. I might try calling the parts desks of a few dealers in your area. Make sure they look it up by VIN as they might confuse it for the auto.
Old Apr 13, 2021 | 12:08 PM
  #96
Ultrawolf's Avatar
I had mine done today. The dealership had the parts kits so they did the work right away. It took about 2 1/2 hours from first arriving to getting the text that the car was ready.
I posted photos of my axle shafts before, showing that the passenger side looked really good while the driver's side clearly had the plastic coating breached with a rusty shaft exposed. The dealership replaced both sides. An added bonus of this work is that you get shiny new rubber boots. Those can sometimes split when they get old, so having them replaced is a major plus in my book.
Here are some before and after photos:
Old Driver's Side
New Driver's Side
Old Passenger Side
New Passenger Side
Old Apr 13, 2021 | 12:36 PM
  #97
Odie's Avatar
Looking good . Thanks for those pics . Have you checked A.T.F. level ?
Old Apr 13, 2021 | 12:44 PM
  #98
Mister Coffee's Avatar
@Ultrawolf: Looks like it worked out for you.
Every time you change your oil, spray some heavy duty silicone on those shiny new boots. It will keep them from cracking.
Old Apr 13, 2021 | 01:39 PM
  #99
Ultrawolf's Avatar
Yes, and I did my own ATF drain/fill some time ago. But that's unrelated to axle shafts, right?
Old Apr 13, 2021 | 01:44 PM
  #100
ANGST's Avatar
When pulling the driver side axle , some ATF will leak out . The service procedure states to top it off after you do it.
In my case I went by the online service manual and drained the fluid . I didn't get reimbursed for the extra fluid or the crush washer
