Old Nov 8, 2011 | 06:11 AM
  #3681
BlueBoogers's Avatar
Originally Posted by FitStir
I thought there was some aiming needed after mounting? (can't wait till I do my projectors)
Are you guys going to be offering this as a kit and maybe a discount for fellow Fit owners?
Saw that in the other thread and really want to do something very similiar. Parts list? any DIY in the making?
There is no rotational aiming of the Mini D2S needed when used in the H4 socket, however vertical and horizontal alignment are necessary and are done via the factory headlight alignment.
I can definitely retrofit a pair of LS460s for you if you want to go that route. A DIY on the LS460s would be very difficult and would basically give away confidential information. It's a one-off install that many professional retrofitters are paid a lot of money to do.
Old Nov 8, 2011 | 09:37 AM
  #3682
FitStir's Avatar
Thanks for clearing that up for me.
I will definitely be contacting you when the time comes for me do this mod (and the money). I saw that post and thought that was a great combination, especially how clean the led rings look with the shroud you used.
Is that possible with the Mini D2S's? Which shroud is that?
where'd you get the key ring? how much?
Links below.
https://www.fitfreak.net/forums/2nd-...ml#post1048000
Can't recall the name of the new manufacturer, but I bought it from rsstyle.com (Thailand) ---> Key Ring LED Universal 2 Step. - . It looks almost exactly the same, the newer one has beefier wires, and a slightly different control unit (diff resistors, same functions). Aside from that it's exactly the same - blinking red when locked, solid blue when unlocked, and off when key is inserted.
Shipping is relatively pricey, and expect a wait with customs releasing the package.
Old Nov 8, 2011 | 11:51 AM
  #3683
wakali's Avatar
Thanks! I appreciate the info.
We have install guides on our site under the "Resources" tab.
The Mini D2S kit with Gatling 2.0s is $295 shipped in the US. The D2S projector fits into the Fit's H4 socket without any work and alignment is even pre-set!
-Andrew @ TRS
Old Nov 8, 2011 | 02:11 PM
  #3684
MikeNSX's Avatar
Ordered a set of 205/50-16 Continental DWS tires.
Old Nov 8, 2011 | 04:50 PM
  #3685
flip's Avatar
Originally Posted by littleblackcar
Is this a common problem on the Fit?
Mine is the same as you guys, before I lowered it on sportlines, and after. Maybe cause its the side with the transmission? wild guess
Old Nov 8, 2011 | 11:11 PM
  #3686
jnesselroad's Avatar
Got around to putting my eyelids on. Had to take off the vinyl ones when I did my retro, so I made some fiberglass ones...
Old Nov 9, 2011 | 07:16 AM
  #3687
The LS460s have their own clear shrouds, actually. We could mimic the look by putting CCFLs or LEDs behind a shroud that has openings such as the Apollos.
Old Nov 10, 2011 | 11:12 AM
  #3688
kennef's Avatar
air filter, oil change, new brake fluid, and a tire rotation. i wonder how much that would have cost at a dealership or an independent mechanic?
Old Nov 10, 2011 | 09:05 PM
  #3689
MikeNSX's Avatar
Got in my new set of tires...Continental 205/50-16 DWS's...
Old Nov 10, 2011 | 10:30 PM
  #3690
blassty's Avatar
Cool
Drove through the Cascades this afternoon. While US 2 isn't the Dragon's Tail, it was still pretty fun. This guy got pulled over in front of me for speeding. He was tearing it up probably 25 over the limit. He zipped by me when he had the opportunity. Glad it wasn't me, but then again I was only doing 64.
Old Nov 11, 2011 | 11:53 PM
  #3691
I wrote you guys the diy you asked for.
Morimoto Retro for the GE
Old Nov 12, 2011 | 06:10 AM
  #3692
Black3sr's Avatar
Nice pic. Going to be my desktop for a couple days.
Old Nov 12, 2011 | 10:56 AM
  #3693
Subie's Avatar
Nice! I'd be interested in how the DWS's handle black ice in your neck of the woods. Enjoy!
Old Nov 12, 2011 | 04:29 PM
  #3694
[IMG]http://i80.photobucket.com/albums/j182/blassty/car/014-medium.jpg[/MG]
I love the Cascades so much. I'll move there at some point in my life.
Old Nov 12, 2011 | 09:28 PM
  #3695
Goobers's Avatar
What did I do to my Fit? Hum... I swapped a tire to my spare because the tire was the victim of a bolt shoving its way through the tread face.
Old Nov 13, 2011 | 11:10 AM
  #3696
Krimson_Cardnal's Avatar
Goobz Saw that on another thread - Sure hope you can plug it. Really sucks when a match-up set of tires gets busted. Least it took out the most worn one, or had you swapped those to the rear?
Any way it sucks. It ain't karma, it ain't luck - sometimes it just beeez that way.
Old Nov 14, 2011 | 02:19 PM
  #3697
kennef's Avatar
wore out its tires!
Old Nov 14, 2011 | 04:35 PM
  #3698
littleblackcar's Avatar
I drove to Pisgah NF, parked in a corner spot, hiked, came home and washed the bugs off!
Old Nov 14, 2011 | 10:17 PM
  #3699
Goobers's Avatar
no, hadn't rotated them since my last oil change.
got it patched earlier today... man, kinda annoyed. All he did was stick a piece of some material in... and that was it for $10. Well, I'm not annoyed at the guy, just the thought that maybe I should've done it myself.
I put the tire on... let's see how the patch holds up.
as for the karma/luck/breeze... it ain't a good one this month, whatever it is.
Old Nov 14, 2011 | 10:51 PM
  #3700
Full moon just swung through. Don't be annoyed when the tire guy fixes the hole ;-) He knew what to do and how to do it and $10 is an unheard of price - that's karma
