Old Oct 26, 2011 | 09:07 PM
  #3561
SilverBullet's Avatar
Originally Posted by Goobers
Say NO to crack!
In other news... I had a strange dream that it snowed... and that's all I remember of the dream too.
I would've put the shelving units in the Fit, mostly cause I don't have a trailer to use.
Its going to be a bad winter around Chicago. Rain storms comes through and then there is rain effect off the lake for the next 3 days. The last 5 rain storms followed this pattern. So your dream of snow and only snow is not that far off.
Crack is bad stuff, but the road crews are trying to seal them as fast as they can.
Old Oct 26, 2011 | 09:35 PM
  #3562
CharlotteGE8Alex's Avatar
get nitrogen in your tires
Old Oct 26, 2011 | 10:59 PM
  #3563
Krimson_Cardnal's Avatar
.... the open area of the carpet seems clean enough. Just can't get under that plastic.
So, anyone got tips on removing the plastic? Or should I just take my car to a professional detailer? I wonder if the pros take seat cushions apart. Maybe they can finally clean the old Pepsi spill on the other side of the rear seats.
This all could've been avoided ... if I hadn't tried to be slick and tried to carry two large plastic jars and one smaller glass jar at the same time.
If you start on the forward door seal, the piece that runs up along the inside by pulling it in towards the cabin, you then might be able to get the door sill trim piece off. Pull the rubber door gasket clear in that area first.
The sill trim clips [2] into the rearward piece so you'll need to unclip-pop them first. Take care and don't over stress the pieces and you should be okay. Remember use force, but try not to gorilla it. Sill piece should then lift up from the bottom to unhook it.
Good luck - least it isn't milk [phew]!!!
Old Oct 27, 2011 | 12:20 AM
  #3564
Hootie's Avatar
Did an oil and filter change on a teacher's GE8 today at school. This is the same GE8 that we put Drag-21s on and transferred the TPMS sensors by the way. The owner of the GE actually wanted to learn more about their vehicle and how to perform most of the basic maintenance but was side tracked for the evening so I couldn't show them the procedures for the oil change.
Used Mobil 1 5w-20 for oil and a Fram oil filter with a new FREE drain bolt washer (Thanks Honda of Lake Jackson :thumbs up: ), showed the owner how to reset the maintenance minder as well as the location of the engine's air filter and the cabin's air filter (and how to check/replace them). Sometime next week we'll be doing a tire rotation, brake inspection, and chassis inspection.
Old Oct 27, 2011 | 10:07 AM
  #3565
Hootie's down - teaching the teachers... good show!!
Old Oct 27, 2011 | 09:09 PM
  #3566
Blueeyed Banditti's Avatar
What does the nitrogen do? Is it free? I have never heard of that. Would the techs at Honda think I was nuts asking for that? I am confused.Name:  smilie035.gif
Old Oct 27, 2011 | 09:24 PM
  #3567
All honda dealerships do the nitrogen in the tires , and they know about it, it cost 40-60 bucks heres a article on it> If you are one of the 85% of Americans who
don't regularly check tire pressure, you need
nitrogen.
We take in nitrogen with every breath. Air is composed of:
  • 1% Water Vapor and Other Gases – Escapes up to 250 times faster than Nitrogen
  • 21% Oxygen – Escapes 3-4 times faster than Nitrogen
  • 78% Nitrogen – The largest molecule in
    air, dry, non-flammable.
Because of their large size, nitrogen molecules are the least permeable and stay in your tire longer.
It's not about the nitrogen. It's about reducing oxygen, water vapor and other gases.
By reducing the percentage of oxygen, water vapor and other gases in your tires from 22% to 7% or lower, your tires will maintain proper pressure longer than if you use “plain old air.” For example, with 95% nitrogen in your tires, they retain optimal pressure three to four times longer.
Proper tire pressure is a big deal.
Maintain it with nitrogen, and you'll see
these three primary benefits:
  • Increased Fuel Efficiency – Correct tire pressure keeps the manufacturer's recommended “contact patch” on the road. This lessens the rolling resistance and maximizes fuel efficiency. Read On...
  • Longer Tire Life – When it comes in contact with other materials, oxygen causes oxidation. Oxidation can make rubber brittle and cause it to lose tensile strength. In addition, at high temperatures and pressures, oxygen reacts and damages inner tire liners and belt packages; nitrogen does not. Read On...
  • Increased Safety – Under-inflated tires cause 90% of blowouts. Nitrogen provides more reliable pressure for reduced blowout potential. Read On...
Other benefits:
  • Improved TPMS Performance – If you have a new car, you likely are plagued by a flashing light telling you your tire pressure is low. For example, one woman's light was going off every four to five weeks. After inflating with nitrogen, her light didn't reappear for 53 weeks!
  • More Predictable Pressure Fluctuation – NASCAR teams use nitrogen so they can more accurately predict tire pressure fluctuation. Regular compressed air can fluctuate considerably when water vapor is present. Read On...
  • Longer Rim Life – Rim rust caused by condensation from water vapor and other gases can get caught in valves and create slow leaks in tires. Nitrogen is completely dry, so it eliminates the potential for condensation.
Old Oct 27, 2011 | 10:24 PM
  #3568
specboy's Avatar
Brushed Snow off the car before hopping in to head home.
I guess I know what I'm doing this weekend... Putting the Snows on.
~SB
Old Oct 27, 2011 | 10:35 PM
  #3569
nitrogen.
Other benefits:
Nice write up, but doesn't it cost 20 dollars every time you need air?
Old Oct 27, 2011 | 10:55 PM
  #3570
W.Crispy's Avatar
Plus, nitrogen in your tires makes you go faster. That's what the N0S stickers mean.
Old Oct 27, 2011 | 11:04 PM
  #3571
Nitrogen has not been proven, Air is 78 percent nitrogen and if it even gave .1 percent better mpg they would use it in the trucks. At 4 dollars a gallon and using 30,000+ gallons a year that would be 120+ dollars per truck, my company would use it and the DOT would require it.
Old Oct 27, 2011 | 11:11 PM
  #3572
B-Blue's Avatar
Many gas stations give you free air whether you fill up with them or not. I seriously doubt I'll make up the price difference at the pump.
Old Oct 27, 2011 | 11:35 PM
  #3573
Paul56's Avatar
I have my own portable air compressor so filling the
tires with air is relatively painless and easy.
It would drive me nuts not being able to check the
pressure once I started using nitrogen... because
each time you check the pressure a little leaks out
thus increasing the frequency I have to pay someone
to check the nitrogen level and fill as necessary.
Old Oct 28, 2011 | 01:26 AM
  #3574
W.Crispy's Avatar
I threw a couple of stickers on. You know. To go faster.
I'm trying to get the software to open up my database of graphics I designed while working at a sign shop years ago. From what I remember, my portfolio had some real hilarious stuff. I'd love to get a plotter and start making decals again someday.
Old Oct 28, 2011 | 01:36 AM
  #3575
Goobers's Avatar
Well, sometimes if you want to do some things, you'll need to try new things... in other words... you can try taking longer intervals between checks.
Then again... if you have your own air compressor... why bother with nitrogen?
Old Oct 28, 2011 | 02:55 AM
  #3576
blassty's Avatar
Cool
Nice Half-life sticker.
Old Oct 28, 2011 | 04:34 AM
  #3577
Black3sr's Avatar
Not sure what is in my 09 Stock tires but my winter tires are nitrogen filled. That is nice because who wants to freeze fingers checking tire pressures.
Old Oct 28, 2011 | 12:21 PM
  #3578
CG_FL4DR's Avatar
nitrogen is good for cars that sit more than they are driven. air is more practical for a daily commuter.
oh and i got my windows tinted
Old Oct 28, 2011 | 12:26 PM
  #3579
Subie's Avatar
So how much faster per sticker?
Old Oct 28, 2011 | 12:30 PM
  #3580
im a daily driver and nitrogen in my tires made a HUGE diffence, alot smoother ride, i havent had my air pressure go down since i got it done almost a year ago. Worth every penny to get it done. Ill never go back to air, must the new Honda come with nitrogen in the tires already. If your see a Honda with green vavle covers it means it has nitrogen filled tires. I reccommened to to everyone.
