Old Jan 22, 2013 | 10:57 PM
  #7441
xizorian's Avatar
Recieved and installed new dome light tonight...stock photo. Freaking BRIGHT and the blue mood light is great!
Old Jan 23, 2013 | 01:53 AM
  #7442
hello_you1's Avatar
where did you get that? i want one.
Old Jan 23, 2013 | 08:27 AM
  #7443
Dwalbert320's Avatar
Order information please^^^^^
Old Jan 23, 2013 | 09:30 AM
  #7444
xizorian's Avatar
The dome light can be ordered at www.japanparts.com. They have quite a few parts for GD and GE Fits.
Old Jan 23, 2013 | 09:35 AM
  #7445
xizorian's Avatar
Haha! Too funny. Reminds me of the jingle: "I can't spell VW, but I drive a Porsche, cause I'm a blonde, yeah yeah yeah."
Originally Posted by Dwalbert320
How long does it take to go 80 miles if you are driving 80 mph? Follow this link to find the most funny answer ever!
https://www.facebook.com/photo.php?v...type=2&theater
Old Jan 24, 2013 | 04:08 PM
  #7446
x4x5x1x's Avatar
Took off the Fit emblem, washed, got an oil change, and added oil and fuel additives. Switched from 5w-20 to 0w-20 also.
Old Jan 24, 2013 | 05:59 PM
  #7447
KCTitan's Avatar
Originally Posted by Jephu
Washed it and finally got rid of all the hard water spots on the windows.
https://www.youtube.com/watch?v=CbYMJD4z1pY
https://www.youtube.com/watch?v=syJ9eKny5QI
Some good tips! Thanks for sharing!
Today I washed the Fit after about 4 weeks since the last wash. She really needed it but I've been too busy to get out and get it done. Tonight I'm going to pick up an oil filter and change her oil in the morning for the first time myself.
Yesterday I ordered some replacement White LEDs for the Parking Lights up front.
Old Jan 24, 2013 | 06:28 PM
  #7448
Wafulz's Avatar
got a flat lol
Old Jan 26, 2013 | 10:01 AM
  #7449
Syne's Avatar
I need more power!
Installed a dedicated 2.1 amp USB power port in the dash with a 1.0 amp power into the glove box. (the glove box power will eventually be removed and used to power a car DVR when I finally decide which unit to buy.)
I took apart
a cigarette lighter adapter a cigarette lighter adapter
and soldered on some leads then added a circuit to the ACC fuse spot. Total cost under $30. Would be slightly cheaper for you apple fans since I needed a
shorted USB micro cable shorted USB micro cable
to get my Android to full power charge out of a USB port.
This is the mount I used for in the dash This is the mount I used for in the dash
. It is about 20mm in diameter, but the 19mm hole maker from my heated seat switch install worked perfectly.
This project took about an hour. It would have taken less time if I was better at soldering.
So with extra time on my hands and being dejected that this USB project was so easy... it was time to tackle the hookup for my heated mirrors. I ran the lines about a year ago when I added side winkers. That was, by far, the hardest mod to date. About 12 hours to get those stupid wires to run through the factory wire harness. Ugh. And another 4 hours to pull the mirrors out of the casing and scrape down that black adhesive on the back and stick these heaters on. The power supply says that together, they pull 1.4 amps. I can see the outline of the heater elements in about 10 seconds. They do defog the whole mirror in about a minute.
I bought a relay and was trying to find the defrost switch wire. Googling around and found out that Goobers thought fuse 55 might be switched on when the defogging switch is on. Pulled out my DMM and sure enough it was true!! Added a circuit to fuse 55. Bam we have power. Amazingly easy wiring. They go on and off with the factory defog switch.
WAIT! Something happened. I think the passenger side mirror might have arced and melted the backing on the mirror a little. The second time I turned them on this little yellow dot appeared. It looks to be one of the contact points of the heater. It still heats up, and the spot didn't seem to get bigger when I left it on for about 10 minutes.
I am ordering a new heater and replacement glass. I think I didn't isolate the leads well enough. Will take it apart and see when the replacements get here.
~Syne
Old Jan 26, 2013 | 04:36 PM
  #7450
krunk13's Avatar
Finally washed it after about a month. Weather was allot nicer today than it been in a while.
Old Jan 26, 2013 | 04:54 PM
  #7451
Wafulz's Avatar
Got ride of my.new tires the eagle gt I hated. And bought new ones DW. I have to Say fawkkkk talk about rain grip very nice
Old Jan 26, 2013 | 05:49 PM
  #7452
Rampo's Avatar
Looks good. Still in the low 20's here in the Northeast so mine will have to stay dirty a bit longer. I like your license plate. Just not loving the offset location. I know lots have done this mod and everyone's opinion is different, but to my conservative eye, the plate would look better in it's original centered position.
Old Jan 26, 2013 | 05:58 PM
  #7453
Cocowheat's Avatar
Wow I'm not even going to beat around the bush, your car makes me LOVE the 2012 sport model. Great job!
Although I am setting a bit tired of the whole yellow overlay look. That's why i will probably take my overlay off and finally do my IS300 fog retro. (If I ever get my damn raise at Toyota. Lol I know. The irony)
Old Jan 26, 2013 | 06:06 PM
  #7454
Protagonist's Avatar
One reason why the offset plate looks wrong is that it's at an angle, not so much because it's off to the side. If the mount kept the plate perpendicular to the car's centerline, even the offset wouldn't look bad.
Were I to do an offset like that, I wouldn't offset it as far, and I'd use shims to make the left side stick out from the bumper farther so that the plate is still perpendicular rather than angled to the left. But that's just me…
Old Jan 27, 2013 | 12:09 AM
  #7455
MyFitOwnsYours's Avatar
Did my oil change and installed the sti s204 lip :]
Old Jan 27, 2013 | 12:11 AM
  #7456
pig_pit's Avatar
Looks like a jdp lip.
Old Jan 27, 2013 | 01:01 AM
  #7457
krunk13's Avatar
The center plate F's up the paint underneath it.
Old Jan 27, 2013 | 02:05 AM
  #7458
cfran55's Avatar
once my paycheck comes in im going to give it a go at that lip
Old Jan 27, 2013 | 07:38 PM
  #7459
Cliff's Avatar
Took it home..
2013 Fit Sport manual in polished metal metallic. My 3 series is being retired from daily driver duty.
Old Jan 27, 2013 | 10:02 PM
  #7460
Rampo's Avatar
I see your point. I just recently removed mine totally. (I'll keep it off until someone officially asks me to put it back on). The area under the plate was a real mess. There was an ugly center hole from the dealer, which I had to plug, and also a bunch of scratches from the original plate holder, which I buffed out a little.
