Integra Type-R front disc brake installation
Old Sep 8, 2016 | 05:11 PM
  #221
mangosmoody's Avatar
just found this awesome thread thanks!!
Old May 22, 2023 | 11:27 AM
  #222
brazzy's Avatar
Anyone know if this will fit a UK spec 2003 Jazz? The early Jazz's in the UK came with 240mm front rotors...
Old Nov 21, 2024 | 12:45 PM
  #223
mr_RogerWill's Avatar
Originally Posted by Jodele
Over 30K views and no Sticky? What's up with that?
Bump for sticky
Old Aug 30, 2025 | 08:18 AM
  #224
marq's Avatar
Abs and traction.
Hey, so I did this. Bbk upgrade as well on my ge8 about 4 months ago and my abs and traction light came on about 3 weeks ago. Idk why but the brake peddle as been very squishy.. to be honest the stock brakes felt more safe.
is there a write up on why the abs and traction light come on after doing this brake upgrade?
Old Aug 31, 2025 | 03:31 PM
  #225
Jodele's Avatar
The short/simple/quick answer is that you did poor job of bleeding the brakes.
Things to check when bleeding;
are the bleed nipples at the top of the caliper piston?
Air is significantly lighter than brake fluid…that means that air will be at the top…with reference to GRAVITY, not the caliper. Fill a clear plastic bottle most full of water. Put the cap on tightly. Now rotate it in any direction and take note where the air is. Now, visualize that in the brake caliper and the air inside the caliper.
since I don’t know what your installation looks like, since you have a spongy brake pedal, you have air in the caliper. It takes work to get all the air out. You probably will have to unmount the caliper, put in a block of steel the size of the disc brake (or an actual loose disc brake), and visualize where the air is in the caliper. Rotate the caliper so that the bleed nipple will be above the air bubble.
Old Sep 5, 2025 | 12:11 AM
  #226
GrE8_Fit's Avatar
Maybe air in the ABS block.
VictorHash
Jan 19, 2019 12:31 AM
BklynFit07
Nov 29, 2017 04:17 AM
glockprime
31
Jan 27, 2014 07:59 PM
sabawballs
Jan 15, 2014 05:00 AM
Sleeper
29
Mar 24, 2006 09:20 AM
