Integra Type-R front disc brake installation
Old Nov 13, 2010 | 10:54 PM
  #161
Evotech8's Avatar
Originally Posted by racetek82
I just did the upgrade with the FastBrakes.com rotors. I ended up having the brackets milled 4mm on the mounting surfaces. This worked out great! The only issue I encountered was having to trim the cooling shields. They rub pretty bad, and bending them doesn't give enough clearance. No testing yet since I finished pretty late, but I'll break in the rotors tomorrow and post my results!
I had to do some creative bending/flattening of the splash guards with pliers to keep it from rubbing the bigger rotors. But it will work, just looks like ass when finished. Meh, can't see it from outside view anyways.
Looking foward to your review...
Old Nov 29, 2010 | 07:14 AM
  #162
mgutt's Avatar
Spoon Calipers and rotors received:
Mein Honda Jazz Performance-Projekt - sind die felgen eigtl mitlerweile da?...
I test the installation in a few days.
Old Dec 8, 2010 | 01:03 AM
  #163
astig's Avatar
^installed it yet??
can i use any 17CL15VN calipers or do I need specifically the one from ITR 4x114? these calipers are also used on the CTR, Legend, accord, etc..
Old Dec 8, 2010 | 04:32 AM
  #164
Jodele's Avatar
That one part number is used on several different cars...as you had found out. Thay are all identical...take it off of any of the cars and you will be good to go. The real IRT has 5X114 and not 4X114...
Old Dec 9, 2010 | 09:00 PM
  #165
90jdmcivic's Avatar
I dint kno the front rotors were that close in size..good info
Old Dec 9, 2010 | 09:01 PM
  #166
90jdmcivic's Avatar
I was lookin for an 11" disc..couldnt find it on the site..
Old Dec 9, 2010 | 11:09 PM
  #167
Jodele's Avatar
The Acura Integra Type-R has 282-mm front discs...that equals 11.10-in...
is that close enough? If so, then you've found it!
Old Dec 10, 2010 | 04:57 AM
  #168
mgutt's Avatar
Originally Posted by astig
^installed it yet??
no. to much snow at the moment
Old Dec 10, 2010 | 07:07 AM
  #169
Jodele's Avatar
vielleicht bald
Old Dec 12, 2010 | 07:11 AM
  #170
90jdmcivic's Avatar
ohh..wel thanks, for the longest time i thought itr rotors were 10.3..thanks for the clarification.
Old Dec 16, 2010 | 09:24 PM
  #171
ku8o's Avatar
i want to upgrade my front caliper, using cross n drilled rotor (same size wit' OEM rotor)
which type of aftermarket caliper would fit (bolt) into my 15" rims et 48
can anyone help ?
IMG_0099.jpg?t=1292553436
IMG_0098.jpg?t=1292553443
runstoprotorslotndrilled.jpg?t=1292553458
Old Dec 16, 2010 | 09:35 PM
  #172
Jodele's Avatar
I don't know of just a caliper upgrade...there are several manufacturers that make just a disc upgrade though. This thread shows a complete brake upgrade that will fit within a 15” wheel.
Old Dec 16, 2010 | 10:05 PM
  #173
ku8o's Avatar
yes , i've seen it,
with a changing rotors aslo
too bad i've already bought those rotors ...
Old Jan 17, 2011 | 11:55 AM
  #174
mgutt's Avatar
First step, balancing
Results:
Mein Honda Jazz Performance-Projekt - hehe nicht lustig^^ Was...
Spoon Twinblock Caliper 2,27 kg
Spoon Brake Pad 474 g
Spoon Brake Rotor 5,84 kg
Old Jun 24, 2011 | 02:44 AM
  #175
chinkster's Avatar
damn sucks that neither itr nor dc5-r 5-lug isn't direct bolt on like on civics!
Old Jun 24, 2011 | 09:30 AM
  #176
Jodele's Avatar
This is about as close to direct bolt-on as you can get…all you need is a specific disc.
I’m also very surprised that this thread didn’t make “sticky” yet…
Old Sep 19, 2011 | 01:31 PM
  #177
AdrenalineRush's Avatar
Sorry to drag up this thread from the dead again, I'm just curious if any members with JDM/EDM fit/jazz were able to complete this "bold-on" modification with their GD1Fits. The stock rotors are smaller 240m vs 262mm USDM, I'm not sure if this affects anything?
I'm thinking of trying the 282mm stoptechs with some wilwood dynalite calipers (to keep off the unsprung weight vs the OEM type R calipers).
Old Sep 19, 2011 | 03:20 PM
  #178
Jodele's Avatar
I know that this mod works on any USDM Fit (GD3 and GE8). I have no way of getting a hold of a GD1 since they were never imported into the US…not a USDM model.
Any Caliper that will fit an Acura Integra Type-R (DC2) will fit the Fit. So if Wilwood makes a direct replacement caliper for the ITR, you can use it.
Old Sep 19, 2011 | 03:51 PM
  #179
Thanks for the quick response, and I realize you wouldn't have access to a GD1. I was Curious if any of the UK/Euro/Aussie/C'bean or Asian based members had tried your idea.
Not sure if Wilwood make a direct replacement, but I figure these brackets and calipers might just work with the slightly smaller stoptech rotors.
https://www.fitfreak.net/forums/fit-...4-fit-gd1.html
Old Sep 19, 2011 | 05:08 PM
  #180
Jodele's Avatar
Honda probably used the same caliper for the GD1 and GD3…so, if the GD1 came with 240-mm rotors and the GD3 comes with 262-mm rotors, the 310-mm rotors replace the 262-mm. 310 – 262 = 48-mm. Since the GD1 came with 240-mm, for the caliper to fit, you need 240 + 48 = 288-mm rotors. Since StopTech makes 282-mm rotors, the math is right. 282 will definitely work in lieu of 288. If you can’t make a longer bracket, I’d try it.
