ETC 12 step Adjustable Throttle Controller
Old Sep 21, 2011 | 02:56 PM
  #381
dled1286's Avatar
my bad...just checked the usps tracking number and it says its processed thru the houston facility, houston being as close as it is, can i expect it the end of this week? maybe in time for a weekend install?
Old Sep 22, 2011 | 01:43 PM
  #382
dled1286's Avatar
Just got it dropped off...get it installed Saturday and ill post pics of where i put it...
Old Sep 22, 2011 | 07:08 PM
  #383
roguenode's Avatar
Originally Posted by xcelir8fit
Yes, I lined up where I wanted the display to be, used a sharpie to a make a dot where the cable would have to run through (slightly to the right/under the left side of the display) and drilled a hole large enough for the cable/end connector to fit. I was able to take the entire black cup holder out by pinching/yanking, so I did this on my bench. I then used a little velcro to hold the unit down and some 'goop' glue behind it with tape covering the whole thing until dry. Then, I just ran the cable under the center console to the driver's foot well and popped the entire cup holder with display back down and wala!
Did this today. Easy and quick. I've been driving in SP7 mode lately. Drove my buddy's G37x yesterday and was like, "Damn, you gotta smash the pedal and wait a bit before this thing goes!"
Old Sep 26, 2011 | 03:39 AM
  #384
twpanson's Avatar
late night bump~~~
Sincerely,
Panson
Old Sep 26, 2011 | 08:58 AM
  #385
dled1286's Avatar
So heres where I mounted mine...
Super simple install. All the wiring is run along the firewall behind all the venting in the center then up behind the glove box. The main control unit is mounted behind the glove box on the metal support near the front. Super simple to learn how many time to press the mode button to get where you wanna go so being able to see the unit is unnecessary IMO. Looks super clean with out it in the main cabin too.
+REP for Pan!!! Awesome product, would HIGHLY recommend for anyone wanting that little something extra for the Fit, or just about any car with an electronic throttle.
Old Sep 29, 2011 | 02:58 AM
  #386
bao khong's Avatar
how much for one im interested
Old Sep 30, 2011 | 12:00 AM
  #387
twpanson's Avatar
Hi,
You've got a pm.
Sincerely,
Panson
Old Sep 30, 2011 | 01:43 AM
  #388
Jamy's Avatar
Just put mine back in the car. Took it out for a bit. Have had it on Ec3 all day. Feels amazing. Nice and smooth take offs. Gas milage for today was 42.3 avg. I'm falling in love all over again
Old Oct 1, 2011 | 11:23 AM
  #389
twpanson's Avatar
Morning Bump for a great add-on that every Fit owner should get one..
Sincerely,
Panson
Old Oct 4, 2011 | 12:00 AM
  #390
Noxm09's Avatar
still waiting on your reply
Old Oct 4, 2011 | 12:38 AM
  #391
twpanson's Avatar
Sir,
PM back, sorry for the oversight.
Sincerely,
Panson
Old Oct 8, 2011 | 02:27 PM
  #392
twpanson's Avatar
All pm replied.
Sincerely,
Panson
Old Oct 16, 2011 | 11:37 PM
  #393
twpanson's Avatar
All PM replied!
Bump~~~
Panson
Old Oct 19, 2011 | 08:39 PM
  #394
TxTurboFit's Avatar
I am interested in ordering this, can you please send me the purchase info.
Old Oct 20, 2011 | 02:53 AM
  #395
twpanson's Avatar
Hi,
You've got a pm
Sincerely,
Panson
Old Oct 25, 2011 | 09:55 PM
  #396
Hootie's Avatar
3 questions for TWPanson and any ETC owners.
1. My Fit has to have a OBDII state inspection soon. Would it be okay to disconnect the OBDII connector for the ETC and leave it disconnected until the inspection?
2. Would leaving the OBDII connector unplugged do anything else aside from not power the ETC? By anything else I mean any Diagnostic Trouble Codes or Check Engine Light illumination.
3. Has anyone wired the reverse cancel wire for their ETC yet?
Old Oct 25, 2011 | 11:35 PM
  #397
Java^FiT's Avatar
for questions 1 and 2: In nature it shouldnt cause any issue, it will not receive any power to the control module and thus act as a blank gateway if you will through the wireharness and act as it did when stock
to answer your third question, i have had the reverse wire connected since day 1 and everything works fine, did you have a specific q about it?
Old Oct 26, 2011 | 12:48 AM
  #398
twpanson's Avatar
Hi,
Tks for the question.
1. It is okay to disconnect OBD. Acceleration will go back to stock mode. This is part of ETC's safety bypass system.
2. Leaving OBD unplugged won't cause any CEL or code in your ECU.
Sincerely,
Panson
Old Oct 26, 2011 | 12:51 AM
  #399
Hootie's Avatar
You're response to 1 & 2 does make quite good sense. My concern though would be that I don't wait long enough (the papers recommend 10 minutes) before unplugging the throttle's connectors and with my luck I'd trip the CEL. Ha!
In regards to 3, I was wondering where does the stray blue wire go to. I picked up one of TWP's ETC's second hand from a buddy who who sold their Fit and was strapped for cash. I'm not sure if it was trimmed down some or came that way for the M/T GD3 (I have an A/T GD3) but there isn't any mention of where the blue wire runs to for the reverse cancel that I know of.
Old Oct 26, 2011 | 02:21 AM
  #400
Texas Coyote's Avatar
I have never unhooked mine for state inspection or hooked up the reverse wire... It scared the hell out of my wife when she backed the Fit out of the barn one morning when I told her she could take it to work. I was driving it all of the time in the SP7 setting before I upgraded the S/C to 10PSI.
