Old Dec 3, 2016 | 07:26 PM
  #8621
gd3~fit's Avatar
Originally Posted by lakia5524
Depending on what you guys are running cat or not cat I can give you free calibrations of mine fully tuned by vit viper very conservative on ignition timing and safe , also with flashpro you can kick your map stabilizer box and injector compensation box and let your ecu do the work im also running the a/t fit with manual rotrex
Yes please share 👍🏽.
I'm running J's header, J's testpipe, T1r b pipe and Apexi chambered axle back.
Automatic too lol.
  #8622
gd3~fit's Avatar
Originally Posted by Hootie
The base map is the "Base 310cc KWSC" or something along those lines in the calibration selections. Select that (adjust injector size if RDX is larger), switch from NA columns to Boost columns, enable your live tuning tables, click datalogs, record, AND finally upload.
Once upload is complete, you can activate auto tune and putter around as FP gets things into a decent ball park.
got it thank you haven't messed with the Flash Pro yet
Old Dec 4, 2016 | 12:45 AM
  #8623
lakia5524's Avatar
It wont let me send the cal file on here ill have to send through email , are you using the 410cc injectors?
Old Dec 4, 2016 | 06:18 PM
  #8624
Hootie's Avatar
Hey, that would be nice! Are you running the 10 lb kit as well?
I haven't had much time to actually sit down and tune the Fit with work and it being completely dark out when I clock out.
Sending PM shortly.
Old Dec 4, 2016 | 08:17 PM
  #8625
lakia5524's Avatar
yea im also running the 15-60c rotrex i want to step up to the next bigger unit but not sure if it will mount up to the other bracket or have clearance issuse
Old Dec 7, 2016 | 07:04 AM
  #8626
mr_RogerWill's Avatar
Connected the 4-pin trailer harness to the Fit and tested the trailer...its lit! ��
Attached Thumbnails What did you do to the GD Fit today?-80-20161206_200104_78a6e8f5e10ea4b6fd0c9e615566753637d2f7de.jpg
Old Dec 7, 2016 | 05:21 PM
  #8627
solbrothers's Avatar
Nice. I'm currently rebuilding my trailer. It's sanded/grinded and then primered. Waiting for a warm day to lay on some paint.
Old Dec 7, 2016 | 11:26 PM
  #8628
yeah, i plan on rebuilding this one too..got it for cheap but previous owner said it was sitting for a looooong time.
Old Dec 9, 2016 | 02:11 AM
  #8629
workhorse status lol
Attached Thumbnails What did you do to the GD Fit today?-80-20161209_010410_0da00557b9070beb86a7d6ac7177556d37f0ef68.jpg   What did you do to the GD Fit today?-80-20161209_010426_d8ff78db3036153abf1ff0b4f09b49c0d0322223.jpg
Old Dec 9, 2016 | 01:08 PM
  #8630
cnordt24's Avatar
Well since my last post I've added:
Last Station chamber intake
Progress rear sway bar
Apexi SV axle back
Weapon R Race 2 piece headers
Megan mid-pipe
GD illuminated door sills (not installed)
JDM Jazz floor mats (carpet, leaving those out till spring)
LED brake light behind bumper cover vent (lights up for brake, blinker, and reverse)
JL Audio 4 channel amp
JL Audio 10" enclosed sub (more boom and still fits under the back seat!)
Attached Thumbnails What did you do to the GD Fit today?-80-chamber_intake_eea2de0d142b0c14a1f512d5af80ff4c3c9bed56.jpg   What did you do to the GD Fit today?-80-bumper_led_504884ec9e31234c9f83d5cf8ed8c6d943adf364.jpg   What did you do to the GD Fit today?-80-sub_e42fb1e716b1a1bcc727c47b6ffbd0641eb453a3.jpg
Old Dec 9, 2016 | 09:15 PM
  #8631
lakia5524's Avatar
cnordt24 where did you get that throttle body spacer from??
Old Dec 9, 2016 | 11:24 PM
  #8632
cnordt24's Avatar
Ebay!! Same place i got the throttle body lol
Old Dec 14, 2016 | 02:19 AM
  #8633
feifei's Avatar
What does the throttle body spacer do?
Old Dec 14, 2016 | 02:01 PM
  #8634
cnordt24's Avatar
It helps improve the air flow in to the manifold which will increase HP and Torque. Given it won't be much on our little Fit motors, but every little bit helps
Old Dec 19, 2016 | 07:51 PM
  #8635
lakia5524's Avatar
so you got a difference throttle body other than stock? is this a bigger throttle body
Old Dec 21, 2016 | 03:00 PM
  #8636
cnordt24's Avatar
I'm using a throttle body from a 06-11 Civic. It's 55mm while the stock Fit throttle body is 50mm. It's also a direct bolt-on replacement to our stock throttle body, you will just need some longer hoses since the coolant nozzles face in different directions. Going from 50mm to 55mm may not sound like much, but every little bit helps and the R18 throttle bodies are fairly cheap (used for around $60). Plus being able to add a spacer is a nice upgrade too.
Old Dec 23, 2016 | 11:56 PM
  #8637
DWils's Avatar
I just realized I haven't been on here for 4 months. I've probably only changed the oil a few times and got whatever recall was needed a few months ago done. I'm still waiting for some extra income to buy the leather seat covers.
Old Dec 28, 2016 | 03:19 PM
  #8638
cnordt24's Avatar
Haha, that happens to all of us.. you saving up for Clazzios?
Old Dec 28, 2016 | 08:32 PM
  #8639
DWils's Avatar
No, I have to save up for a $400USD Dyson hair dryer for the gf first. Yes, you read that correctly: $400USD for a hair dryer. There is a lot of story behind it, but if I buy her that then I can have the green light to drop $300-400USD on the Clazzios. Nothing fancy though. Just the black on black or black on grey with black or grey stitching. Then the Fit will be complete and I can say Fit is go!
Old Dec 28, 2016 | 10:08 PM
  #8640
gd3~fit's Avatar
this happened
Attached Thumbnails What did you do to the GD Fit today?-80-img_0083_359dce9ef7e38944250d7abed918cd2748a961fd.jpg
