K20 Fit How To Discussion
Old Sep 12, 2007 | 12:43 AM
  #161
fitjunkie's Avatar
Great to hear the good news, it's been forever!! Time to upgrade the rotors and pads...
Old Sep 13, 2007 | 09:51 AM
  #162
gettinafit's Avatar
YouTube - k20a challenge part 1
YouTube - k20a battle part 2
YouTube - k20a battle part 3
Honda Fi places 2nd in pre-qualification lap time!
"J's Racing Honda Fit GT" K-series all motor Fit! In the straigt at the START flag it passed everyone with it's overall straigtline speed, but needs further modification to suspension in my opinion to take the victory.
Nice to hear all of those K-series motors!
Old Sep 13, 2007 | 10:56 AM
  #163
tonyd3773's Avatar
Smile K20a
The K20A setup costs enough money w/ K-Pro. I would hope it performs like an animal!
Old Sep 17, 2007 | 06:55 PM
  #164
gotfitted's Avatar
Dude, those videos just further demonstrate the superiority of the older chassis to the modern ones. They're lighter and have dbl wishbone front and rear. ;_; torsion beam rear suspension
Old Sep 18, 2007 | 09:45 AM
  #165
jits14's Avatar
the fit woulda placed higher if the driver wasn't so sloppy
Old Sep 18, 2007 | 05:39 PM
  #166
gettinafit's Avatar
You are correct! The EK's were the last of the Frt/Rear Double wishbone suspensions, and those suspensions performed well on their specific chassis that they were designed on.
It's not the chassis that is double wishbone, So I wouldn't say that the "newer" chassis' like the new gen civics and the Fit are inferior.
It is said that the new suspension's are to not allow the chassis to flex as much.
"From Honda"
(Control-Link MacPherson Strut front suspension design: This advanced design provides the precise handling, stability and comfort of a double-wishbone layout with packaging efficiency that is difficult to achieve with a conventional front double-wishbone design. )
Still no excuse for the rear suspension on the fit. And of course overall the Fit in particular, as compared to the new gen civics, the fit is NOT designed to perform the same.
It can be converted to double wishbone for ones with enough $. Until then...... Win-on Ek's and EG's.
Well, the car seemed in my opinion not to handle well in the turns, I don't think it was driver error, it seemed like suspension deficiency to me. IT Sure was Fast in the First Striaght!~!! Passing by ALL!
Old Sep 19, 2007 | 01:08 PM
  #167
gotfitted's Avatar
aaaaaaaanywayz....
so how's that swap coming? oh yea, just information for anyone with a K20: my friend at skunk2 has a RSX-S that they test their cams and stuff on and he said that with the Stage 2 cams and valvesprings and retainers, the K20a2 gained nearly 20hp when they swaped in the K20z3's intake manifold. So if you want to grab that intake manifold for a cheap upgrade. Oh yea, and their large bore throttle bodies should be coming out soon.
Old Sep 19, 2007 | 07:13 PM
  #168
gettinafit's Avatar
Z3 manifold does not fit due to space in the engine bay on the FIT only.
But that's good to know for others with K20a2 swaps!
Still waiting for parts..... hopefully sometime this week......
Old Sep 19, 2007 | 08:02 PM
  #169
gotfitted's Avatar
really? i thought hasport used everything from the Z3...go figure
Old Sep 20, 2007 | 06:19 PM
  #170
gettinafit's Avatar
Nope Z3 engine and Z3 TB with a homemade adapter to up convert the A2 monifold bolt pattern. (No-one up converts normally, usually they get the RBC manifold and get an adapter for the existing TB DBW if necessary)
Anywayz, it is what it is.
***Update***
I HAVE GREAT NEWS!!! The Harness and computers are in my hands!!!!!
This weekend will be the time I put this car back together! Minus the Header.... I have to contact Hasport and see whats the status of that!
Old Sep 20, 2007 | 07:35 PM
  #171
Wave's Avatar
Oh snap! I'm there to help brother.....the only thing that might be a problem for me is the United Nations General Assembly in Manhattan. Hopefully I won't have to work it. Not sure yet
Old Sep 20, 2007 | 10:27 PM
  #172
sy11580's Avatar
hopefully, I see you there man.
Old Sep 21, 2007 | 01:03 PM
  #173
gotfitted's Avatar
F@$* it, just run open headers LOL! wake up the neighbors and scare the chickens
Old Sep 21, 2007 | 09:54 PM
  #174
thane's Avatar
***Update***
Would you mind taking a picture? I would like to see if the harness is different from the prototype Hondata threw together for Hasport's original swap.
Good Luck
Old Sep 23, 2007 | 11:15 AM
  #175
gettinafit's Avatar
** Update**
The Engine is mounted and sitting nicely in the engine bay again. The pictures are to come. I will be installing the accessories and everything else over the next few days.
Old Sep 23, 2007 | 02:17 PM
  #176
gotfitted's Avatar
** Update**
can't wait!
Old Sep 23, 2007 | 03:31 PM
  #177
OneStopCustoms's Avatar
nice job on the car...
Old Sep 23, 2007 | 10:54 PM
  #178
gettinafit's Avatar
**update**
I found a little time to do a little work on the Fit this weekend, seeing that I had new parts and motivation to start the engine! So here's what I've accomplished today.
Engine/trans Assy. (bare) Permanently Mounted in the bay!
Showing the Clearance of room along the drivers frame rail! (trans. mount)
Passanger side clearance.
Waterpump pulley close to the frame rail. (is it what it is)
Rear Engine mount at rear crossmember.
Differential at EPS rack and pinion mounting bracket. SO DARN CLOSE!!
Mated harness (L15A1 and K20A2) With ECU clips for 2 ECU's!
Intake manifold, throttle body, harness, accessories, shifter cables, accel cable, clutch lines. THats all for today.
Little by little it's comming back to life!
THat's all for today's work, Stay Tuned!
Old Sep 23, 2007 | 11:09 PM
  #179
smeister's Avatar
Lovely!!!!
Old Sep 23, 2007 | 11:25 PM
  #180
SPON FIT's Avatar
sweet as hell dude.its nice to see progress again
