DIY lower your GE8 Fit
Old Apr 20, 2009 | 04:48 AM
  #101
Hownet's Avatar
Eibach Pro-Kit Installed
F-1.2" R-1.4" Dropped
It's about 15~25% stiffness increased(front about 15%, rear 25%), my friends tired sit on the back seats and told me that it's little bumpy. Handling & braking are much better now~ I drove on the freeway about 95 mph, the steering still stable
Old Apr 20, 2009 | 01:17 PM
  #102
Benggolf's Avatar
Hownet, do you posting a "lighter" picture of your car. The current photo is too dark and we can really see how much of a wheel gap there is between the tire and fender. TIA.
Old Apr 20, 2009 | 01:28 PM
  #103
runbikerun's Avatar
How do you like the feel of the Eibachs?
Old Apr 20, 2009 | 08:08 PM
  #104
Hownet's Avatar
Before
There you go~ : )
Old Apr 29, 2009 | 10:52 PM
  #105
firebird079's Avatar
ok i have a question.. ive been looking at lowering springs and idk what the difference is whether one is better or what. i wanna know what the difference is between the tananbe DF210's and the NF210's. or if theres a better set out there for a good price then please do tell. THANKS
Old Apr 30, 2009 | 12:36 AM
  #106
Benggolf's Avatar
Thanks for the second photo. Shows the fender clearances more clearly. Nice drop and I think it looks better than the Tanabe DF210 because the rear sit too low on the Tanabes IMO.
Old Apr 30, 2009 | 01:47 PM
  #107
nice job on the DIY! man, that's a lot or work just to get to that one nut.
your car looks great. the drop looks perfect front and back.
Old May 1, 2009 | 12:04 AM
  #108
niko3257's Avatar
FitFreak GE8 DIY Guy
thanks bro
here is a pic i took this past weekend.
P4270019.jpg?t=1241150607
Old May 1, 2009 | 03:55 PM
  #109
psyko's Avatar
damage struts?
Hey guys, aren't lowering going to eventually blow out your struts? Because on my srt-4 we had to always yous coil overs because the lowering springs would blow out the struts and that was way more costly than the coil overs.
Old May 1, 2009 | 04:39 PM
  #110
Tork's Avatar
I think if you are bottoming out your struts on bumps often, so far havent done that once.
Also if the spring rate over powers the dampening rate of the strut that can wear out struts faster, but again the spring rates on RSR or Tanabe are only 10% or so above stock. Pretty sure not too much danger of blowing out struts in this application. If you really slammed it (2" drop or more) yeah you will probably have issues.
and short shifters wont ruin your transmission from shifting faster.
and putting on an intake wont void the warranty on the entire vehicle.
Old May 1, 2009 | 11:42 PM
  #111
psyko's Avatar
ok, that's all i wanted to know? Btw, i know about short shifters and cold air intakes. but you forgot one, putting NOS stickers on your car adds about 10hp and ups the cool factor by 5
Old May 9, 2009 | 06:43 AM
  #112
kingofpicklez's Avatar
quick question: what happens if you don't cut the bump stop
Old May 9, 2009 | 06:55 AM
  #113
niko3257's Avatar
some people said the backs aren't needed but i disagree.
make sure you cut your bump stops. cut at least 1.5 inches off.
if you don't the front end will ride on the bump stops.
take it from me i know first hand.
Old May 11, 2009 | 09:53 AM
  #114
chipchan's Avatar
Wink
Is it more difficult to go up or down the ramps/slope and speed bumps? Will the tires hit the inner part of the fenders?
On the other hand, does it improve the handling of the car when turning in sharp corners?
Chip of Honda Fit Factory
Old May 11, 2009 | 10:36 AM
  #115
niko3257's Avatar
yes it will be a little more difficult on the driveways and stuff.
fenders don't rub. this all depends if you have aftermarket
wheels and what offset they are.
also handling is better.
Old May 11, 2009 | 11:00 AM
  #116
runbikerun's Avatar
If I lower with Eibachs on stock wheels and tires will I have any rubbing issues?
Old May 11, 2009 | 03:22 PM
  #117
Benggolf's Avatar
No, you should not. Am going to lower our GE8 Sports FiT with Tanabe DF210 this afternoon and don't expect to have any rubbing issues with OEM wheels & tires.
Old May 11, 2009 | 03:36 PM
  #118
Tork's Avatar
Agree with Nick, the fronts are a must, I havent trimmed my back ones yet but it is on my to do list (although I havent bottomed yet) With the Tanabe springs I may be more inclined to say be sure to trim the stops in back right away as the Tanabes seem to sit lower in back.
Yeah learn to take slopes/transitions on an angle and handling is improved.
Old May 14, 2009 | 10:19 AM
  #119
runbikerun's Avatar
I know that it is recomended to get an alignment when springs are installed. Do you guys usually actually do this? Also with the stock rims and tires is it really necessary to change the camber? I just ordered my Eibachs and want to be ready. Sorry for asking so many questions.
Old May 14, 2009 | 10:26 AM
  #120
niko3257's Avatar
i didn't do nothing to mine so far and all is well. tires are still even
and it still drives straight. i guess you'll just have to see after you
do yours. then you will know if you need it or not.
as for mine it didn't need anything.
