DIY lower your GE8 Fit
Old Nov 4, 2010 | 04:21 PM
  #221
niko3257's Avatar
FitFreak GE8 DIY Guy
looks good. plus rep to you
Old Dec 8, 2010 | 11:20 PM
  #222
Unreal12's Avatar
Hello there my fellow fit freaks I'm new on this forum and the first thing that sparked my interest is dropping my car since I did receive today from fedex, my eibach sportlines. Now I love this write up! But I do have a few questions, first, is it necessary to cut or do anything at all to the bump stops? What happens if you do nothing to them? Ride height affected?
My second concern would be the front suspension, is it really necessary to use spring compressors to remove the old springs? I read somewhere they were not too tight and would be safe to remove without the use of them.
Old Jan 12, 2011 | 05:54 PM
  #223
ACS Rob's Avatar
^ mind if i asked where you ordered your springs from? i'm looking to get a set of sportlines myself. great diy btw!! thx for posting!!
Old Jan 30, 2011 | 10:40 AM
  #224
WhiskeySix's Avatar
Great write-up! Put in a set of Eibach pro-kit springs last night without much trouble at all! (Man, this is my first experience wrenching on a car without rust... only 1kmi on it... what a joy!)
Since this info was so helpful, I feel a little compelled to share some lessons I learned while doing this install:
1) When taking of the rear strut-tower bolts, be careful not to drop the nut/washer when hey come off the threads. I got distracted just as I took the right one off and it fell down into the bodywork... not the end of the world, but I had to waste time trying to get the plastic cladding off the side of the cargo area.
2) taking the cowl off isn't all that difficult if you take your time. I didn't take photo's, but once you know where the clips are, you can do it easily. Here's some feedback on clip location based on my experience... thanks for the original photos:
the large cowl piece is held on by two rows of clips. The 'rear' clips are along the windshield. and pop out pretty easily. I snapped half of one, but it still went back together pretty easily. The 'front' clips are on the very edge of the cowl and wrap around the edge of the metal cross-member:
The triangle pieces I found to be easier to remove with the hood closed. They're held on by two clips. First, along the top, there's a lip that tucks under the metal. Then there's a single stab-thru clip (for lack of better word), towards the bottom. Be careful if you use a screwdriver here, the edge of the glass is right there and you can easily make a little chip:
3) To get the metal sheath of the top of the rear struts, the allen-wrench and vice-grip combo worked great! Just be careful - you barely need to squeeze with the vice-grips... it spins really easily. If you grip it too tightly, you'll just make it hard to unscrew as the sleeve will be grabbing against the threads resisting twisting.
4) On the front struts, the rubber accordion-type shock-protector is lightly clipped around a flange along the 'bottom'.
5) I cut the bump-stops off the fronts while they were still attached (I couldn't figure out how to get them off It's pretty easy to do. You just 'scrunch up' the rubber shock-protector, and lay it across the edge of a table/bench. Use the vertical edge of the table to hold the rubber boot back while you cut.
Old Feb 8, 2011 | 01:41 AM
  #225
egw84's Avatar
Anyone remove the front lower lip after lowering? Mine was all chewed up from previous towing & it scraped way too often so I parted that out. Any aftermarket lips that arent as low?
Old Feb 8, 2011 | 08:26 AM
  #226
09 Fit's Avatar
The "lip" is not just decorative. It is an air deflector and directs air to the radiator and engine compartment to help keep things cool.
Old Feb 27, 2011 | 10:23 PM
  #227
Ray731's Avatar
Mine is finally done!
I got DZ springs for Christmas and I've been waiting till I have two days off consecutively in case I ran into an issue. After much research I decided to try to do this without removing the cowl! YES it can be done! I did it using a ratcheting boxend wrench...
I'll spare most of the pics. If you want them click on the link in my signature. It's my progress thread.
Before
After
The ride is better than I expected! A bit stiffer than stock but that's what I like. I feels like it handles better, and I liked how it handled to begin with. I just wasn't looking to rally race! It looked like an SUV with little tires.
Thanks for everyone with the info and suggestions.
-Ray
Old Feb 27, 2011 | 11:07 PM
  #228
Goobers's Avatar
When I installed the Swifts, I also did it without taking off the cowl.
Unfortunately for me... I didn't have a ratcheting boxend. It took so long using a regular combo wrench... I probably could've gone to sears to buy the ratcheting boxend... come home, decided I didn't like it, go back to sears and exchange it for another one, come home to find it doesn't fit, exchange again... and still finish the job in half the time than the way I was doing it.
Old Feb 28, 2011 | 12:53 AM
  #229
DiamondStarMonsters's Avatar
Don't you hate it when you think you find a shortcut and it just takes ten times longer?
Those flex head ratchets are worth their weight in gold sometimes! The "crows feet" for socket extensions too!
Old May 10, 2011 | 07:14 PM
  #230
ciref8's Avatar
while disassembling, i've some how manage to strip the top of the struts. Now i can't finish the passenger side. Can anyone think of a solution to this problem?
thanks, i'm putting everything back together for now.
Old May 10, 2011 | 07:20 PM
  #231
neil patrick harris's Avatar
if you don't have one, rent an impact gun from your local auto store. that's the only way i got mine off when it got stripped. hope you're as lucky as i was.
Old May 10, 2011 | 07:58 PM
  #232
ciref8's Avatar
tried two autostores and none of them had an impact gun
Old Jun 4, 2011 | 03:37 PM
  #233
rla217@'s Avatar
thanks
Niko & WhiskeySix,
Thanks for taking the time to take pix & post up your DIY & tips. Both very helpful. I put in Swifts on my 09 today, took about 3 hours total. First time spring-changer... no probs with dropped axles thank doG.
Thanks again
Lee
Old Jun 24, 2011 | 01:36 AM
  #234
dynimite53's Avatar
THANK YOU FOR THIS DIY!!!!! IT WORKED REALLY WELL! i decided after reading through this thread that i was going to use the box-ended ratcheting tool! took a little while bit it worked. the process took me about five hours( im not a big tech guy and this was my first job without someone else knowing exactly what to do) the first front driver side took about three hours. the other side and the back took about 2 hours( obviously i didnt know what to do on the first one and i was going back and forth looking at the computer screen) all in all the drop is great although i might have to roll my fenders, we will see after i do the alignment.
thanks again OP.
by the way i had n extra set of hands helping me and i highly recommend having someone else help you to run things a bit faster. pics up tomorrow!!
Old Jun 24, 2011 | 12:21 PM
  #235
niko3257's Avatar
Originally Posted by rla217@
Niko & WhiskeySix,
Thanks again
Lee
thanks again OP.
no problem. just trying to make it easy
Old Jun 28, 2011 | 02:39 AM
  #236
dynimite53's Avatar
Pic's as promised (not very good, taken really quickly)
BEFORE:
AFTER:
Old Feb 23, 2012 | 01:45 PM
  #237
garrettt331's Avatar
Compressor
Do you have to have the spring compressor for the install or is there another way?
Old Feb 23, 2012 | 05:03 PM
  #238
Goobers's Avatar
Most lowering springs are short enough that you don't need the spring compressor to install the new spring.
BUT
The old spring is under enough force that you should the use the spring compressor to UNINSTALL it. If you don't, the nut will SHOOT itself from the strut is high enough velocity to break stuff.
I didn't use a spring compressor. But I knew it would shoot off from the strut, so I aimed it at a piece of wood... it deflected of the wood, back at me. It barely missed me and rolled itself under some crap in the garage.
So yeah... you should use a spring compressor.
Old Feb 23, 2012 | 07:37 PM
  #239
doctordoom's Avatar
Supervillain
LOL, a piece of wood is probably one of the last things I would have chose to point the strut at, along with a concrete wall or steel beam.
Note: I'm not saying it's safe to do this without a spring compressor, so please don't hurt yourself and blame it on me.
But if you're not going to use a spring compressor, choose better objects for energy absorption. I've used cardboard boxes several times, they're pretty much my favorite now because they're pretty good at retaining the nut, and if it does get out, it usually doesn't get far.
You could try pointing it into a hamper of dirty (or clean) laundry, a pile of rags, etc. Don't choose rigid objects though unless you want the nut ricocheting through your work space.
Wear glasses/goggles if you have them, and keep your legs/shins out of the line of fire, or line of ricochet. If you do get hit on the ricochet, it's not that bad really, in my opinion, getting hit with an airsoft BB is more painful.
And that my friends, is a safer way to do something unsafe. LOL.
Old Feb 23, 2012 | 07:49 PM
  #240
doctordoom's Avatar
Supervillain
Again, this is just something that has worked for me. It is still not a recommended method - using proper tools is still the safest way.
If you use a cardboard box, have one end open and lay the box on its side. Don't brace the box against the wall or anything like that, just let it absorb the impact and slide/jump on the ground, that's energy it's taking away from the nut's ricochet.
Point the strut into the box and close the flaps as much as possible to retain the nut after it hits the far wall of the box. The bigger the box, the better, and the further the distance from the strut to the far wall of the box, the better. Just make sure the nut goes into the box initially.
Keep in mind that the nut can still ricochet out of the box, so assume that it will do so and prepare accordingly. That means, don't do this right next to your car, a bunch of wine glasses, a gigantic mirror, some spare windshields, etc.
