KWSC Kit Release Ramblings
Old May 28, 2008 | 06:08 PM
  #381
OJRKraftWerks's Avatar
Former Vendor
leonine,
I am glad that your guys at the service center took care of you. I had a great conversation with them about what the car should and shouldn't do, and what they could expect. It sounds like they did a great job, and things worked as I expected with the stock injectors. The A/F ratio is great, and you should have no worries.
You should go down the road a happy camper now.
I apologize for the trouble, and I want to let the Fit community know that we have been working very hard to make sure that leonine and others have no more issues. Of course, contacting us direct is best, that way we can rectify the situation.
Thanks for the support FitFreaks!
-OJR
Old May 28, 2008 | 06:41 PM
  #382
Wave's Avatar
So to clarify...
Leonine, you are currently running with stock injectors even though you have an aftermarket header and cat back?
Are you running with a test pipe or did you put the cat convertor back in?
I'm just monitoring your progress with great interest for when it comes time to install the kwsc into my A/T Fit.
Old May 28, 2008 | 06:43 PM
  #383
Illusive's Avatar
Had a great talk with Oscar this afternoon. I got a Scangauge II and a Wideband A/F gauge and will report my readings with the injector upgrade and let you guys know what I've come up with when I get these parts in!
Old May 28, 2008 | 09:25 PM
  #384
xorbe's Avatar
i went and read one the fit exhaust FAQs. stock exhaust is 48mm it says -- so no wonder 50mm doesn't have the flow required of the 60mm+injectors setup! 50mm is +8%, 60mm is +56% cross-sectional area.
i probably shouldn't have gotten the t1r header, oh well it's mine now! i might do an axle-back muffler for upgraded looks, but that has little to do with overall flow, i suspect. so, i don't plan on grabbing the injector kit i guess...
Old May 28, 2008 | 09:34 PM
  #385
Hondasforlife's Avatar
hey so i got the 60mm skunk 2 exhaust..and im getting headers next summer/hondata(if it is available for AT)..but my exhaust and the supercharger should be a good combo for now right??
Old May 28, 2008 | 09:39 PM
  #386
leonine's Avatar
Originally Posted by KraftWerks
leonine,
-OJR
Thanks so much again Oscar for EVERYTHING! keeping my fingers crossed that the scangauge tells me that all codes are gone and i will pass inspection. I'll keep ya posted.
You da man
Peace bro!
Old May 28, 2008 | 09:47 PM
  #387
eldaino's Avatar
Originally Posted by leonine
i can't speak to other components but if anything it is not the header but the axle back imo. even with the test pipe and header at idle it is pretty quiet. when i had the skunk2 60mm cat back i put the same test pipe on and it was not drivable because it was too loud.
so again it seems that depending on the setup you have you would either need to stay with the stock injectors, 195cc(maybe) or 205cc.
to say that the header/test pipe requires the injector upgrade i think has been proven to be an untrue statement in some cases.
I sure hope my car still has that oomph it did before when i drive it home tonight.
so it was more of a noise issue? i didn't think skunk2 would be quiet, even before f.i.
so theoretically, if i keep my cat, which i will, i should be ok running a header, new b pipe and axle back(a quiet one?)
oh and glad to hear it worked out for ya leonie! we need a full on review! and the info has been priceless! kudos to kraftwerks for sticking with us too!
Old May 28, 2008 | 09:48 PM
  #388
leonine's Avatar
i doubt the stock exhaust is 48. my 50mm pipe looked much larger but i never measured. but it does shed some light on the subject. If i wasn't so in love with my mugen axleback i would dump it. I wanted to get the megan 60mm mid pipe but they were on back order forever like 5 months.
Currently i am running:
Mugen headers
T1R test pipe - 50mm
T1R mid pipe - 50mm
Mugen dual axleback
I do have a megan test pipe 60mm in my basement with an extra 02 bung already welded on if anyone is interested in a local pickup. needs a new donut gasket.
Old May 28, 2008 | 09:49 PM
  #389
eldaino's Avatar
Originally Posted by Illusive
Just purchased a T1R Test Pipe and T1R 50S Ver.2 Exhaust to replace my Fujitsubo one. Also added an O2 bung to the test pipe and will be installing the AEM Wideband UEGO gauge like leonine to monitor the A/F ratio.
whoa! so no more cat for you! and did you get the t1r 50s just to match the test pipe and have a nice tr1 flow, or was the wagolis causing issues in conjunction with the kit!
man this is so confusing.
Old May 28, 2008 | 10:08 PM
  #390
eldaino's Avatar
Originally Posted by DynamicFit
As promised here are they dyno charts from
Before Mods: Mugen header, Mugen drop-in filter, J's Racing catback
After Mods: Jackson Racing Supercharger base kit, J's racing catback
http://farm3.static.flickr.com/2248/...6a2510a2_b.jpg
From this you can see that although the Jackson racing supercharger does make some good additional power after 4.5 grand, without the header, you are looking at a torque and horsepower curve that lies underneath that of a setup without the supercharger. Your results will vary with the type of header you guys are looking to run. Also as you can see the hp and torque curves are very linear, and provide a very even and stock feel of increased power.
Hopefully when I get the injector upgrade package back on I'll be able to regain the lost bottom end and even some more. I'll be back with an update once the package becomes available.
Tom
interesting, and thanks for the post tom! do you think the power loss was due soley to you not running a header, but running a cat back?
Old May 28, 2008 | 10:16 PM
  #391
eldaino's Avatar
Mugen headers
T1R mid pipe - 50mm
Mugen dual axleback
so like you said earlier, having all this didn't really require the upgraded injectors? kraftwerks response to the contact they had with your mechanic and the install seems to support this.
so i guess if no injectors but a cat delete/test pipe addition, headers and axle back is ok with the base kit, we should be gravy.
i just got a decision to make now.
Old May 28, 2008 | 10:33 PM
  #392
leonine's Avatar
It seems that way thus far. but i cannot give the green light until my ecu passes all of its tests.
Old May 28, 2008 | 10:43 PM
  #393
eldaino's Avatar
cool beans. anxiously awaiting the results! glad it worked out for ya man, truly, and thanks for answering my questions!
Old May 28, 2008 | 10:55 PM
  #394
leonine's Avatar
Ohh and by the way stock exhaust diameter is 42.7mm
Old May 28, 2008 | 11:07 PM
  #395
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
took her to the track on friday night. im not even going to post my results. i was so mad... reason being - i found a huge boost leak the next day. I was only boosting 2 lbs at the track. Hey, at least i still beat a stock prelude by .2 sec!!! Im going back next month after catdelete/headers/hondata... hoping to break into 14's
alright, alright i ran 16.8... pretty bad. but that was at full weight, less than half boost, and AC running (it was hot as hell, i 4got to shut it off lol)
Im ordering t-bolt clamps for the whole system, cuz even at 5 psi i've noticed the Fisher Price clamps that come with the kit tend to move a little even after tightening... i've had to fix the same boost leak about 4 times now All I have to fix now is the 2 brake lines that rattle every once in a while and I'm good. When it runs at its peak, it's OH SO SWEET.
I was down at seaside heights over the weekend. Literally, every corner i came to, somebody said something along the lines of "is that a boosted fit?" or "that shyt is sweet!"
And for anyone who's goal is to beat an SI... it's possible... i raced the SI... he beat me once.... the other nine times, he finished second My friend has vids... I'll post once i get my hands on em
Last edited by JDMchris.com; May 29, 2008 at 12:28 PM. Reason: Re-Edited for Street Racing Content
Old May 28, 2008 | 11:10 PM
  #396
eldaino's Avatar
sorry about your woes dude, but other than that, congrats! and get those vids up!
Old May 28, 2008 | 11:38 PM
  #397
xorbe's Avatar
the faq says 48mm OD twice... is that 42.7mm ID? Then 50mm is +37% and 60mm is +97% (!) cross-sectional...
Old May 29, 2008 | 12:49 AM
  #398
DynamicFit's Avatar
I think the cause of the slightly lower power down low is caused specifically because of the poor flow characteristics of the stock header. I have a feeling that it probably doesn't really have much to do with cat back though. If you read into what the Jacksons have done in terms of reflashing the ecu, you will see that a lot of the adjustments they have made to the tuning are related to low rpm performance (movement of v-tec change over to a lower rpm, ignition map changes).
I'm sure the power gains would've seemed a lot more impressive if I never had a header, but I am pretty certain that once I have that and the Hondata reflash w/ injectors, I will be making a good deal more power. I'm thinking about 160 on the dyno I've been doing all my testing. Will report back once the kit has been installed.
Old May 29, 2008 | 02:47 AM
  #399
claymore's Avatar
16.8 with supercharger??? My mainly stock Jazz went 17.009.
Old May 29, 2008 | 08:57 AM
  #400
Yay Rexxxxx....i Want To Beat Every 4door Si....grr Si's Are Not Suppose To Be 4door....sorry In A Cranky Mood Guys...but Good I Hope I Beat An Si Atleast Once..lol
