Sounds like an AWSOME project. I'm sure you'll keep us inform on the progress?
It'll be posted in my picture thread. Exhaust, drop, wheel studs, brakes, retrofit, and tint are all going on soon to "pass the time".
I have ARP studs going in mine. Easy process with a vice, two hammers (one rubber and one smaller tack), and an impact gun.
*face palm* ok goober, you know what? question redacted.
I had no intentions of getting a slight safety lecture or justification or propagandizing reasons to stay in one's own lane.
I thought it was a simple question, didn't realize I had to defend the idea that that was all it was. A simple question.
Thank you, good day, pretend I never ask.
A safety lecture would be telling you to slow down before running yourself off the road and into a ravine. I'm the last person to suggest safety as I nearly shoved myself into the side of a mountain having some fun. My Fit has the scratches from the close encounter.
If you thought it was a "propagandizing" reason, well, that's your problem. Part of the thrill of those European mountain roads is the margin of error you have because many of them are effectively single lane roads. And you apparently lack the imagination of a simple challenge.
All those roads I listed... would be pretty boring if I had used racing lanes across the whole road... they're simply too wide to feel any real thrill doing that. Isn't one of the things that forum members "love" about the Fit, its nimbleness? And what better way to showcase it, than to nail a hairpin turn using only the inside lane and the rubber practically melting off the tire.
But hey, whatever floats your boat.
Not saying it can't be done, just saying I couldn't figure it out. And I HOPE I'm wrong, cause I really want to replace mine with arp's.
Maybe in the rears, but have you done the fronts? I had to replace a stud and there was no way to get it past everything. If you can do the fronts, please post a how-to, cause I had to take mine to the dealership and get raped for a stupid $3 bolt.
I've had ARP extended studs for a couple of years now. Rears are a cinch. Front end options are: 1. go to the dealership and pay up. 2. Remove the knuckle yourself and take it to a machine shop to press out the hub, also requiring new bearings. 3. grind off part of the stud and part of the knuckle so you can slide the studs in without having to take everything off.
I went route number 2 but chose the wrong machine shop. They bent my hub when pressing it back together and I ended up driving with an extreme wobble for a couple of months before having to go to the dealership to finally get it done right. Ended up having to buy two sets of ARP studs, two new bearings and a new hub. total PITA. But, three years later it's still as good as new.
Sounds like it's REALLY not worth doing the extended studs (at least the fronts, but who would do JUST the rears???) unless you're tracking the car hard. I guess inspections for some races require them as well. If you're putting spacers on that effectively shorten your studs, why not just get spacers w/ studs on them? Oh well. Guess it just depends on how far you're willing to go for that attention to detail
Oh well, I'll get nicer lugs at that point.
