Old Jul 17, 2012 | 04:02 AM
  #5641
MEATBABY's Avatar
Originally Posted by remoer
I-Vtec SOHC stickers in black, HID 6k 4H bi-xenon headlights and HID 3k 11H fog lights.
Oh, don't forget to remove the DRL fuse to make the HID work properly. Down fall is no fog light while head light switch is in the accessory position but it works fine with headlights on the on position.
HIDs in just your stock reflector housings... feel sorry for the people driving towards you at night
and yes, the fogs only come on when the headlights are in full ON position. removing the drl fuse is just going to get rid of your drl...
Old Jul 17, 2012 | 04:32 AM
  #5642
KCTitan's Avatar
Applied eyelid and Fitfreak.net decals. Will post pictures today when it gets light out.
Old Jul 17, 2012 | 06:16 AM
  #5643
555sexydrive's Avatar
Picked up birthday gift #2.
I think it may be lighter than the shipping box.
Old Jul 17, 2012 | 10:10 AM
  #5644
Socialvegetable's Avatar
Originally Posted by mkane
You fellas with the Bilstein coilovers, is this a better set-up than swift springs?
You kind of answered your own question if you think about it. The springs themselves may not be as good as Tohatsu, but the damper will be much improved over the stock one.
What he said. Now, you could pair the Bilstein dampers with Swith/Eibach/etc springs later on, if you wanted custom spring rates as opposed to the progressive springs that come paired with the Bilstein dampers. Stiff Swift springs on stock dampers sounds like a terrible ride, but I could be wrong.
Old Jul 17, 2012 | 11:13 AM
  #5645
Wanderer.'s Avatar
Originally Posted by kgb4187
Filled it up in Castro Valley and sat in some traffic, then drove all over SF before trying to get burgers. Usually the readout is around 28...
I feel ya, I took a drive around Little Italy and SOMA on Sat and my avg readout dropped like a rock from ~38 to ~34, which is big considering I did about 200 miles at 38 already and only probably 10 miles of city driving
Old Jul 17, 2012 | 03:01 PM
  #5646
SportGirl11's Avatar
Debadging her, putting company banner on windsheild, took off all other stickers, and getting my red lugs installed
Old Jul 17, 2012 | 04:27 PM
  #5647
KCTitan's Avatar
Eyelids installed. Going to give her a good wash on Thursday.
And before anyone says it, yes I did clean the areas before applying.
Also installed a bit of Fitfreak rep.
EDIT: Had Problems getting the pics to come up.
Old Jul 17, 2012 | 05:18 PM
  #5648
Goobers's Avatar
Swift makes two types of springs.
one set to replace OE springs and another far stiffer race springs.
The OE replacement springs from Swift are pretty good on stock dampeners... there's a saying...
Don't knock it, till you try it.
Old Jul 17, 2012 | 05:38 PM
  #5649
Wanderer.'s Avatar
Swift replacement springs for the GE8 are only 2.3K F and 2.1K R (soft!), couple that with a modest drop of 1" and I think the Swift springs are the best springs on the market to match with OEM struts.
http://www.swiftsprings.com/file/ss.pdf
Their GD springs are much stiffer.
Old Jul 18, 2012 | 01:38 AM
  #5650
ThEvil0nE's Avatar
teaser!!!
just finished installing HKS hipermas s-style x coilover. total time 2hrs... on a lift with an extra set of hand
teasers...
stock rears vs. hks style x. didn't do a side by side with the fronts but you get the idea
check out the ridiculous baby springs I think they were just 6" tall. has to use zip ties to keep them in place. zip ties off after install.
rear wheel gap and this is still up on the lift... thing is slammed already even before hitting ground
compare the wheel gap with swifts springs on... this is an old footage video when we were doing the mid pipe http://vimeo.com/45829895
test touchdown... can still go down about 2 inches but I'll keep them this height until spring settles
next up... alignment. it's way off and the front toes are ridiculously pointing inward... I can feel them dragging when driving. also, the natural camber made my front so sunk
Old Jul 18, 2012 | 01:46 AM
  #5651
If the toe is that bad, get under there real quick and adjust it out a bit, very easy to do to save your tires from screaming, "WTPh are you doing to me?" :P
Old Jul 18, 2012 | 01:51 AM
  #5652
ThEvil0nE's Avatar
they're pretty bad... I never drove so slow in my life LOL. I'll be finalizing the height and off to an alignment she goes.
Old Jul 18, 2012 | 01:57 AM
  #5653
Good deal, it doesn't take much driving if the toe is as bad as you say to scrub the insides to nothing.
Old Jul 18, 2012 | 02:05 AM
  #5654
ThEvil0nE's Avatar
and the ride was not even close to harsh... tight but not harsh is what she said... no nose dives
Old Jul 18, 2012 | 02:17 AM
  #5655
FittedOnEm's Avatar
I chewed through atleast 50% of my tires when I drove with the toe super off
Old Jul 18, 2012 | 12:21 PM
  #5656
BlueBoogers's Avatar
Ordered a bunch of stuff. What's new?
Old Jul 18, 2012 | 12:49 PM
  #5657
My bad, I was making an assumption based on what I know about their stiff springs.
Old Jul 18, 2012 | 01:17 PM
  #5658
remoer's Avatar
That was true even BEFORE you took the DRL fuse out. Basically, that's how the fog lights are supposed to be working in the Fit.
Eh, I'm use to just having my fog lights on the accsesory setting on my 91' hub. Hey it's my first new car.
dame, that's going to suck. Any idea how to adovid blind on coming traffic?
Yeah again I'm a noob to anything beyond ODB0/1 Honda cars. Lol
Old Jul 18, 2012 | 01:51 PM
  #5659
MEATBABY's Avatar
You need to have retrofitted headlights w/ a projector in them to properly run HIDs. W/ the current reflector housings that super bright 6K light reflects out of your headlights in a million different directions. With projectors the light beam is very focused, so it points where you need to see but doesn't blind people unless they are literally coming straight at you, even still the beam is pointing downwards so unless they're riding a big wheel they still won't be blinded.
Retrofits are expensive FYI. And if you're still unsure what I'm talking about then google image search Projector Headlights. You'll recognize them. Many many new (and usually nicer) cars have them. If you don't want to pay for a retrofit or buy aftermarket projector headlights for the fit, then I would just recommend selling your HID kit and using the stock bulbs.
Old Jul 18, 2012 | 03:04 PM
  #5660
Texas Coyote's Avatar
Tohatsu was my 1st motorcycle, a 50cc in 1969.
Mine was a Bridgestone 175 in 1966.
