2k-mile trip
Racked up 2k miles driving to WA and back to CA in my '08 Fit Sports AT. Held up well throughout the trip - straightaways, mountain curves, some rain, uphills and downhills. Averaged anywhere from 28-34 mpg @ slightly above the speed limit
. Just couldn't find a comfy sitting position though but was great every time I pulled up to a gas station - always under 10 gal.
Maine was wonderful - trip totaled 800+miles, 40MPG, seats are comfortable - I've raised the font of the rail mount by 3 washers and it does add just enough leg support to make a positive difference. Rides and drives like a Fit, I love it.
finally installed my jdp grill. friend ended not spraying the grill so i took it back (after 5 months of waiting) and sprayed it myself. i need to respray because it came out more of a creme color / offwhite. i might just end up selling it though. i initially bought this because it would be easier to clean vs the stock honeycomb grill...well that and i had the mod itch. lol. now i dunno if im feelin' it.
finally installed my jdp grill. friend ended not spraying the grill so i took it back (after 5 months of waiting) and sprayed it myself. i need to respray because it came out more of a creme color / offwhite. i might just end up selling it though. i initially bought this because it would be easier to clean vs the stock honeycomb grill...well that and i had the mod itch. lol. now i dunno if im feelin it
I had the same problem painting my hood louvers with acrylic paint that was mixed to match the factory color... When and if I do some body work I will have to pay through the nose and get some base coat clear coat paint and shoot it again.
~SB
We can get spray cans of touch up at local Auto store (Crappy Tire for you Canucks)
I did the scrape on my lip and matched very well.
KC. Good idea on the washers. I may try that. Nothing else to do on it.
bill
bill
Received my dead pedal cover from Zeta Products today. Ordered it in the "smooth" finish. Check out the pics in my progress thread:
https://www.fitfreak.net/forums/2nd-...tml#post910894
I'm still considering doing a new raised trunk floor like I did in my Integra.
It's not looking like a projector Retrofit
I like the color 6000K but not the glare.Actually, do you know what size washers you picked up? and are there pics of how much it raises it up? (I'm considering this)
~SB
Mean time, all you need are three 3/8" washers each side under the front of the seat rail. That's 3/16 more or less and was all I needed. 4 washers would lift it 1/4". I wouldn't get carried away - it really doesn't take much, too much and you will need to get a longer seat bolt. I was simply looking for a bit more upper leg support out of those short seats. Forget who planted the seed in my head, but it was posted somewhere on the forum.
Interesting thing is that I kept in mind the loose seat rail issue some complain about on the Fit. Spec says those bolts should be at 25ft/lbs. Not much, mine were tight, but I'm sure they're tighter now.
Did you disconnect battery before doing this? I was wondering with the airbags if a concern. I am going to try it on the passenger side for the wife as well.
bill
bill
HA I'm working on a HDfeature movie!
Nope. Just pulled the rail bolts. Stacking the washers under the rail and getting the bolt through was the trickiest part. With the front bolts off the seat tips back just enough to frustrate you.
It is a subtle change but does make a difference. Passenger side I would raise to 1/4" for sure. The bolt will take it. Time to pull the seat??
I tried replacing the rail bolt, however, they have a funky stater nub on the end and I wasn't able to get the new off-the-shelf bolt started - of course it was blazing hot at the time and I was loosing patience. Never quite seen a set-up like that, it is just a bolt.
Reason for me to lengthen the bolt is to mount a support bracket for a universal RAM mount I've had for a while. The brackets go on the seat rail bolt and on the Fit I'm going to need to raise the seat bolt head to clear the floor contour. If I figure it out I'll be able to mount a lap top in the cabin. I'm hoping it wont crowd things too much.
RAM Mounts
RAM Mounts
I hate seeing this $hit on the road. Inconsiderate drivers blinding everyone else on the road with ricer headlight mods. Retro or go home. BTW, this is also illegal. :thumbdown:
