Old Sep 16, 2010 | 03:43 PM
  #1361
Black3sr's Avatar
Originally Posted by Krimson_Cardnal
Nope. Just pulled the rail bolts. Stacking the washers under the rail and getting the bolt through was the trickiest part. With the front bolts off the seat tips back just enough to frustrate you.
It is a subtle change but does make a difference. Passenger side I would raise to 1/4" for sure. The bolt will take it. Time to pull the seat??
I tried replacing the rail bolt, however, they have a funky stater nub on the end and I wasn't able to get the new off-the-shelf bolt started - of course it was blazing hot at the time and I was loosing patience. Never quite seen a set-up like that, it is just a bolt.
Reason for me to lengthen the bolt is to mount a support bracket for a universal RAM mount I've had for a while. The brackets go on the seat rail bolt and on the Fit I'm going to need to raise the seat bolt head to clear the floor contour. If I figure it out I'll be able to mount a lap top in the cabin. I'm hoping it wont crowd things too much.
RAM Mounts
OK KC. I will give it a try. It is not hot here but rather a cold Sept rain.
Old Sep 16, 2010 | 03:53 PM
  #1362
Krimson_Cardnal's Avatar
Rain! Now if your garage wasn't full of slot cars...
We're getting the same rain, about time - been a dry end of summer, we need the moisture. This AM I spent readying the wood pile for winter. Moved a face cord into the basement 'garage' and straightened up the outside stack for two more cords. My cars haven't seen the cover of a roof in years... who would have thought at my age I would still be rolling around on the pavement doing car stuff.
Old Sep 16, 2010 | 05:10 PM
  #1363
Black3sr's Avatar
KC. No stacking wood here. I just turn up the thermostat for gas furnace.
My cars have always survived outside except for the Bugeye. It had the garage when I restored it.
Yes we need the rain here too.
I suppose I could drive three blocks and use the F in L's garage. I did last year for the seat covers. Oh sheet I have to wash his van while he is away.
Old Sep 17, 2010 | 05:30 AM
  #1364
shaka808's Avatar
5" Oakley 3D Metal Icon Stickers (USA/CANADA/UK/JAPAN/MEXICO)
I can't seem to find these anywhere online.. only on eBay of course!
$20 for a sticker?? Which country should I represent??
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Sep 18, 2010 | 03:01 PM
  #1365
GrocerySnake's Avatar
Washed, waxed, etc. Looking CLEAN.
Now I get to drive it to work 20 miles and get bugs and dirt all over it again!!
Old Sep 18, 2010 | 05:59 PM
  #1366
Lazarus's Avatar
Got the rear, rear quarter and rear side windows tinted (20%), and installed my new Weathertech FloorLiners. :-)
Old Sep 20, 2010 | 05:17 PM
  #1367
JJIN's Avatar
changed the motor oil with mobile1 (0w-30) and hamp filter. also changed out the ATF, the drain bolt on the transmission was torqued down so tight that i had to use my ratchet and the jack to break it loose.
the fit took about 2.65 quarts of honda atf z-1 to indicate proper fluid levels when running hot.
ive been running the factory viscosity 5w-20 mobile1 so far and trying out 0w30 to see if there is a difference. so far the engine responses quicker to input than with the 5w-20. now i need to see if there is an increase in mpg.
Old Sep 20, 2010 | 11:31 PM
  #1368
Lil Blue's Avatar
Ordered my Acura cargo light, Accord Horn, and a CR-Z engine cover(testing purposes only) today.
Old Sep 20, 2010 | 11:37 PM
  #1369
Farther's Avatar
Installed a Hidden Hitch. Next will be the wiring harness.
Old Sep 21, 2010 | 04:17 PM
  #1370
thefit09's Avatar
Keep us posted on the CR-Z cover!
I ordered the FX-R Stage III kit from theretrofitsource.com. Getting ready to do some baking!
Old Sep 23, 2010 | 09:08 PM
  #1371
j1nNju1c3's Avatar
Let's see...got a detail....and got rear ended...
What a day..
Old Sep 23, 2010 | 09:51 PM
  #1372
blackndecker's Avatar
Sux man, at least you're OK. Maybe there will be enough insurance money left over to pay for some of the JDP hood:wishful:
Old Sep 23, 2010 | 09:54 PM
  #1373
j1nNju1c3's Avatar
Haha..I already saved up for that...kids shouldn't drive while on their phone!!!!!!
Old Sep 23, 2010 | 10:03 PM
  #1374
DSC's Avatar
DSC
Washed, clay bar'd and waxed. Love that clay bar.
Old Sep 23, 2010 | 10:08 PM
  #1375
awptickes's Avatar
Tried to fix my brakes, and failed.
https://www.fitfreak.net/forums/2nd-...ake-noise.html
Old Sep 23, 2010 | 10:35 PM
  #1376
ThEvil0nE's Avatar
tire pressure now at 35 psi... mpg now averaging at 21 from 16
Old Sep 23, 2010 | 10:48 PM
  #1377
I've upped the pressure to 35psi as well. Still on the stock Dunlops [which I started out not liking] and am very pleased with their performance. Honda service guy suggested the boost for winter driving and to help eliminate false TPS alerts.
I'm only guessing I'll see a boost in the MPG's as well.
What's up with the low MPG's Evil? I'm above 40 right now.
Old Sep 24, 2010 | 03:35 PM
  #1378
Liberator's Avatar
My addition is a new shifter knob. I've been toying with a few different knob styles. This one is a beer tap handle, with a local brewery's sticker on it...nothing fancy. Total height of tap handle is 5.5 inches, so it's not as tall as the picture shows. Thinking about trying to create and cast a epoxy/polyester resin knob.
Old Sep 24, 2010 | 06:04 PM
  #1379
Staff@WR's Avatar
Nothing since my wife has it today but come monday I gotta put in my new radiator hoses, CAI, Header maybe a catback and make some lower chassis braces
Old Sep 25, 2010 | 01:40 PM
  #1380
j1nNju1c3's Avatar
Header? Umm please explain
