Old Feb 10, 2016 | 03:12 PM
  #14921
YeahItFits's Avatar
Senior Member
Originally Posted by shinjari
What taillights are those?
J's Racing. Says in the description! LOL
Originally Posted by connor55
I shoulda got denso ballasts but i got the morimotos instead. The new ones work pretty well in the cold but sometimes they dont really seem super bright.
I had Morimotos for a while. They are good but I picked up some Densos and potted them.
Old Feb 10, 2016 | 03:30 PM
  #14922
shinjari's Avatar
DOH! I saw J's and assumed performance/engine stuff not tail lights lol.
Old Feb 10, 2016 | 05:59 PM
  #14923
YeahItFits's Avatar
Senior Member
No worries! Happens!
Old Feb 10, 2016 | 07:43 PM
  #14924
345ge8RS5mt's Avatar
Did this today...It fits pretty well but could use a shift knob extender...or whatever those things are called that raise up the shift knob a bit higher...
I also want a stitched red/blk cover for the e-brake handle and center armrest but haven't found any as yet...excuse the mess..
Attached Thumbnails What did you do to your GE fit today?-80-image_678179ec953a8affb12742a1fe08cdeed65e6131.jpeg   What did you do to your GE fit today?-80-image_b6d0c344f302b3d8253d46c0653bb5ba06a85474.jpeg
Old Feb 10, 2016 | 08:28 PM
  #14925
counterFIT's Avatar
How hard was this install? I've been thinking of getting a T1R suede shift boot...
Old Feb 10, 2016 | 08:35 PM
  #14926
555sexydrive's Avatar
Very easy to swap from what I can remember when I did it so many years ago now.
Old Feb 10, 2016 | 08:36 PM
  #14927
counterFIT's Avatar
Awesome, thanks
Old Feb 10, 2016 | 09:39 PM
  #14928
FamilyWagon's Avatar
Its my birthday.....555 ill have an everlasting man crush if you send me something J's racing related...hell it can be a sticker.
I know you want my man crushness lol
Old Feb 10, 2016 | 09:43 PM
  #14929
hahaha, be careful.
Omedetou, anata no tanjoubi.
Old Feb 10, 2016 | 09:49 PM
  #14930
Hahaha
Arigatōgozaimashita....hopefully that translates to thank you correctly.
Old Feb 10, 2016 | 10:40 PM
  #14931
BMW ALPINA's Avatar
Thanks!
LS460R's, CBI's, and Denso Ballast is best combo! Lol
Hello
The LS460R, what year is that model?
Is it dual low beam high beam?
and what is CBI?
Thanks
Old Feb 10, 2016 | 10:44 PM
  #14932
xxryu139xx's Avatar
Hello
and what is CBI?
Thanks
rut roh BMW sounds like he wants to learn about retrofitting.
Old Feb 10, 2016 | 11:45 PM
  #14933
Mr.Hollow's Avatar
BMW isn't retrofitted yet? I'm just at the point where I assume he has done all the mods or at least invented them hahaha JK
Old Feb 11, 2016 | 02:14 AM
  #14934
BMW ALPINA's Avatar
Yes, I do not have retrofit headlight...
I was thinking of buying the V-LED LED headlight H4 kit
but I read here the light beam pattern is still not perfect...
I also really like the daytime running light of the standard headlight,
which will not be available if I do retrofit...
but all the nice Honda Fit here with all the retrofit headlight really
make me one to have one too someday
Old Feb 11, 2016 | 06:32 AM
  #14935
xxryu139xx's Avatar
u can haz a DRL with the right relay or switch =p
Old Feb 11, 2016 | 09:13 AM
  #14936
Pop up your cup holder tray in the middle console below your a/c controls etc.
When seated in your car (being that your in a LHD there is no real diff) have a look down below toward the middle console and there will be a littel screw that requires a flat head removal. This is the same for the other side.
Remove the e-brake plastic cover in front of the handle with a small flat head.
In my case (Center console armrest) there were two bolts are the bottom on each side that needed to be removed.
Once that was done I simply reclined the seats and slid the entire middle section up and out.
From there its all removal of the stock and matching back with the aftermarket....repeat the above steps in reverse order
*I should have taken pics*
Old Feb 11, 2016 | 11:11 AM
  #14937
connor55's Avatar
Do it, retrofit is such a great upgrade to your headlight performance. You will not regret it.
LS460R is a modified LS460 projector with a clear lens conversion to make a crisper cut off and has a more compact highbeam actuator.
Dont get anything plug and play for headlights, your beam pattern will be too unfocused/inconsistent.
The ls460 is one of the best oem projectors(it was the best at the time i got mine) out there. It produces very wide, even lighting. In pitch black, i can easily see across 6 lanes of traffic and well into the ditch. The intensity of light on the ground is virtually the same from left to middle to right, no uneven hotspots.
For DRLs there are many options you can go with. You can wire up your foglights to come on independently/automatically with ignition. Or you can install switchbacks like ryu has in his turn signals, or you can install custom leds in various forms. In my case, i have leds in my mugen lip, and led halos mounted within the clear shroud of the ls460R, which are automatically turned on with ignition.
Heres some pics.
Attached Thumbnails What did you do to your GE fit today?-80-1394472b_d244_430d_8372_1213e7e33a67_a785eedf6183f8a33d8ff5367c652ca77aef29d6.jpg   What did you do to your GE fit today?-80-f537e83a_cad7_4674_9796_6df97b1e2827_2a928cc034f981f237a4d98319b29486bd9d62b6.jpg
Old Feb 11, 2016 | 01:14 PM
  #14938
YeahItFits's Avatar
Senior Member
Hello
and what is CBI?
Thanks
Just like prev mention LS460rs are modified by the guys over at The RetroFitsource.
They are still some of the best OEM Projectors
Wide beam, great cut off.
Bi xenon projectors: Hi/Low
They are pricey but really worth it.
CBIs is a type of D2S Bulbs. Pretty much best one you can buy.
Made by Osram it's short for Cool Blue Intense.
Color rating of 5500k. It's white light with a hint of blue.
Let me know if you have any more questions about retrofitting.
Old Feb 11, 2016 | 02:30 PM
  #14939
cajlog's Avatar
Lowering my FIT perhaps in a month, these are the options I'm considering:
B&G S2 Sport Lowering Springs
Progress Sport Lowering Springs
RS-R Lowering Springs
TEIN STech Springs
Old Feb 11, 2016 | 02:50 PM
  #14940
connor55's Avatar
Have you considered swift? They keep the ride really close to stock
