Old Aug 29, 2016 | 12:45 PM
  #16001
xxryu139xx's Avatar
Originally Posted by Boostedtaco
Installed a convex mirror!
I'll be installing some OEM wheels from another car next
best upgrade IMHO. cant drive with a regular side view mirror anymore.
Old Aug 29, 2016 | 06:41 PM
  #16002
cajlog's Avatar
NM, re-aligned projectors today; followed a guide on the previous page .
Old Aug 29, 2016 | 09:32 PM
  #16003
shinjari's Avatar
Received my Injen intake today. Looks like it'll be a piece of cake to install the short ram. Feel the filter is a little on the small side. May have to get a larger K&N replacement.
Old Aug 29, 2016 | 11:05 PM
  #16004
counterFIT's Avatar
The short ram really is a breeze. The full intake was kind of a pain, but I feel like it was worth it lol.
Old Aug 29, 2016 | 11:08 PM
  #16005
Mr.Hollow's Avatar
How low are you going? As I mentioned before my 15x8 +35s are good. If I were slammed I may need to do a fender pull for the front, but not the rear.
Originally Posted by FamilyWagon
Yeah depends on the ride height. I would only go a few more MM outward, bc of how low my front end is. I have no wheel gap at all in front and would like to raise it up a little.
I am on tien s. tech springs (1.6") all around and I have camber bolts at 1.75 degrees.I rub a little on my 16x7 +40 205/50/16 tires.
But I plan on running a 15x7 205/50/15 wheel and tire. Which is a 1" smaller diameter.
Right now I have .5 inch wheel gap. And with the 15 wheel & tire. it should add another. 5 inch. so 1" in total wheel gap. Hopefully that one inch gap will give me the clearance I need.
Old Aug 29, 2016 | 11:10 PM
  #16006
FamilyWagon's Avatar
I dont know why youre rubbing, i dont at all.
I would like to run a 15" or 16" wheel setup though
Old Aug 30, 2016 | 12:26 AM
  #16007
Mr.Hollow's Avatar
Haha should be more clear, I autocross the fit also. The car rolls some in the hard corners so it rubs. Normal driving is fine. The fender liner is alittle chewed up, I am thinking of trimming it where it rubs.
Old Aug 30, 2016 | 12:41 AM
  #16008
shinjari's Avatar
AHHHHH makes more sense now haha. I do not autocross, but could see rubbing the fronts if I were to drive hard enough.
I have heard mixed reviews. The CAI takes longer to install and I've heard the short ram performs or sounds better. We will see. =)
Old Aug 30, 2016 | 01:04 AM
  #16009
Boostedtaco's Avatar
Lol. I think it's #3 on the list. Behind Oem arm rest upgrade and civic Si seat. Either way I wish I done it sooner.
Old Aug 30, 2016 | 06:11 PM
  #16010
BMW ALPINA's Avatar
Install my IPF LED Foglight bulb today
HERE COMES THE LIGHT
https://www.fitfreak.net/forums/fit-...ml#post1353077
So Project IPF LED Headlight and Foglight conversion is done
Old Aug 30, 2016 | 07:06 PM
  #16011
connor55's Avatar
Finished polishing the jdm rs headlights, just dropped them off to get the clear bra protection film. Also, fixed one of the broken mounts on the headlights.
Also getting my winter wheels plastidipped in blue..... Winter is coming.
Old Aug 30, 2016 | 07:43 PM
  #16012
frogz's Avatar
Last weekend installed the interior leds . Going to clean the engine bay and start prepping for my Zage kit!
Old Aug 30, 2016 | 08:25 PM
  #16013
Frogz, awesome! Another turbo GE8
Old Aug 30, 2016 | 08:51 PM
  #16014
connor55's Avatar
Give us some numbers when you finish!!
Old Aug 31, 2016 | 12:01 AM
  #16015
dirtybird222's Avatar
I've got the whole front end torn apart and top end of the engine. Retrofitting Morimoto D2S X lens projectors into the car, adjusting valves, replacing seals, cleaning out dirt/mud from a rallyx, and installing a 2012 Civic Si steering wheel. The original steering wheel is disgusting and worn out. Had an extra Si wheel laying around.
Old Aug 31, 2016 | 01:05 AM
  #16016
Mr.Hollow's Avatar
Connor,
Is the clear bra a film or spray? I want to do what you did, because the factory UV film is peeling badly now. But all the diy films have a hole cut where the bump is, which completely defeats the purpose.
Old Aug 31, 2016 | 09:12 AM
  #16017
jy1129's Avatar
Where did you get the convex side mirrors? I have a convex rear view mirror but that still isn't enough for the blind spots.
Old Aug 31, 2016 | 10:23 AM
  #16018
shinjari's Avatar
Connor,
In the same boat, getting my car detailed this weekend and they will be spraying my headlights.
I agree, the film that has a cut out for the bump is ridiculous...ok here protect 95% of the headlight...but not this area in particular.
Horn related note, anyone install Hella supertones or sharptones? I'm leaning towards the sharptones for their deeper sound.
Old Aug 31, 2016 | 10:30 AM
  #16019
Make sure you get the water proof relay for the super tones or they will only last a few months.
Old Aug 31, 2016 | 12:48 PM
  #16020
shinjari's Avatar
Got any info/link for this relay? Is it different than the one pictured to be included with the horn?
I did find a wiring diagram that shows running a 12v power to the battery, is it not possible to run it directly form the OEM horn power wire?
HELLAHornsinstall-1.jpg Photo by Rippen_Griffin | Photobucket
Attached Thumbnails What did you do to your GE fit today?-80-61eyiko5bql_sl1200__e203f92d824b93c447cfc909eb3c5bc979a4dafe.jpg
