Old Aug 25, 2018 | 06:00 PM
  #18001
GolNat's Avatar
Originally Posted by mike410b
I got photos of it developed.
What film did you use? I like the look and colors a lot!
(GE8 interior is so good)
I agree. Simple and clean, never gets old.
Old Aug 25, 2018 | 06:28 PM
  #18002
Fuji Superia X-TRA ISO 400, with a Canonet QL17 GIII. I need to buy some more, I think they may have discontinued it?
And agreed, not to be biased, but I really think the stereo, JDM hazard button and OEM shift knob from my other car dial it up a notch further. Also super OEM looking but just that little extra.
Old Aug 25, 2018 | 06:45 PM
  #18003
Alfa38's Avatar
Nice! And I agree, too, the GE8 with a double din is just about perfect. Simple, functional, just the necessities.
Is that the Metra double din plater or which brand?
Old Aug 25, 2018 | 07:52 PM
  #18004
That's the OEM navigation surround trim panel IIRC.
Old Aug 25, 2018 | 09:22 PM
  #18005
GolNat's Avatar
I will have to give that film a try. When I don't feel like carrying my DSLR or feel like being extra creative I'll grab my Pentax K1000. I pretty much only put B&W film in it (Tri-X 400) but would like to do some more color. Yes it looks like the Fuji is available on Amazon but says discontinued by manufacturer.
I don't have any film shots of the Fit, I'll have to fix that!!
Old Aug 26, 2018 | 02:25 AM
  #18006
Goobers's Avatar
Today, my Fit decided to give me a heart attack.
Preface: I bought a "Mugen" (knockoff?) oil cap to replace the factory cap that's breaking in some places. But when I tried it, the gasket is completely in the wrong place, even though the threaded part fit fine. Gonna have to return it and maybe buy the "Mobil 1" (also, probably knock off) version as that has a bigger/wider rubber gasket or stick with the old slightly damaged cap.
Back to the heart attack... after trying the cap, I then left for work. But as I was pulling out of my driveway, the Fit hesitated a bit... like I was in too high a gear. And after a moment, I had simply thought I was in too high a gear. Incidentally, a few minutes later, I pulled over to double check to make sure I put the old oil cap back (and it was). Later, during work, it did it again and then immediately after hitting a bump moments later, it got worse until it stalled out. I rolled off to the side and restarted without turning key to off. Started up fine. Checked the ultragauge for any codes... none. No set or pending codes.
Not long after, it did it AGAIN... but this time, even restarting wasn't problem free. Upon restarting, it would slowly stall out. I tried restarting still without shutting off, and it stalled out again. I finally completely shut off (among other things) and it finally stopped stalling out. Still no trouble codes whatsoever. And since then, not repeated that issue.
There's a bit of an adage that says many times, a problem that suddenly pops up is related to the last thing done. Well, the last thing was the oil cap... before that, was the axle-back muffler. Neither of which I can attribute, considering the muffler was done almost a month ago (or at least 3 or four gas tanks ago). Another thought is maybe something electrical... dunno.
Old Aug 26, 2018 | 08:39 PM
  #18007
Marmugmotleocay's Avatar
I washed and sealed the Fit with Mckees 37 on Thursday. Then on Friday I had new OEM pads and rotors installed . I bought the car used with 83000 miles on as my daily beater.
Old Aug 26, 2018 | 10:03 PM
  #18008
Chantastic's Avatar
Originally Posted by degnaw
Those look awesome! I've been trying to figure out a good curtains solution, especially for the back. Do you have a link?
https://global.rakuten.com/en/store/...n/item/fit-ge/
https://global.rakuten.com/en/store/...item/fit-ge-f/
The front and back are sold separately. If you do order them, don't cut anything from the suction cups! I did this thinking it was a mold and that it was the obvious thing to do in order for the suction cups to fit through the holes. This is definitely not the case (thankfully they still work). I have yet to try them out for an actual nights sleep. My only complaint is terrible instructions (hence me cutting the section cups) and the rear piece doesn't fit perfect with the 3rd brake light. But maybe that'd be a good thing to let some light in.
Old Aug 26, 2018 | 11:48 PM
  #18009
Chantastic's Avatar
Added an motion sensing LED bar underneath of the privacy cover. It runs on batteries and is currently attached with doubled sided tape. Also reconfigured my bike stand setup after seeing some forum posts here, to make it so that I still have one seat available in the rear.
Old Aug 27, 2018 | 04:06 PM
  #18010
Goobers's Avatar
Well that's... annoying.
I just found out that my driver side fog light isn't securely mounted. A swivel bolt, part of the assembly, backed out too far and allows the reflector to rattle. After 8 years, it's rusted solid. I might spray some PB blaster later to see if I can fix it.
I've been spending way too much money lately, so I'll have to hold off on fixing this, if I decide to replace it.
Old Aug 28, 2018 | 03:09 AM
  #18011
USDM's Avatar
Certainly better than the GK5! I've been driving a GE8 for the past few days and the car feels much more solid in terms of how it's put together.
Old Aug 28, 2018 | 03:32 AM
  #18012
Goobers's Avatar
It's too bad the one defect of the picture is the alignment of the radio trim with the upper glove box.
Every time I look at my dash, I wish there was some way to adjust it.
Old Aug 28, 2018 | 08:16 PM
  #18013
nikita's Avatar
New Honda brake pads. Old ones wore evenly and not quite down to the noise makers, but very close. Rotors look excellent. I dont turn rotors, but replace them if there is anything wrong. Flushed brake and clutch fluids.
Old Aug 28, 2018 | 09:51 PM
  #18014
upallnight's Avatar
Programmed Chip Keys
Programmed 2 additional keys for our daughter's Honda Fit using the above OBD II programmer. The programmer was under $50.00.
Old Aug 28, 2018 | 10:25 PM
  #18015
GolNat's Avatar
Link please? I could use another key for mine.
Old Aug 28, 2018 | 11:07 PM
  #18016
upallnight's Avatar
You will need to get the key cut. I have a key cutting machine that I used for my other cars and my motorcycle. The programmer is to program the security system in the Fit to recognize the new key.
Here's the link for the programmer.
CarKeyDeals - Car Key Programmer Dealer
They also sell the key cutting machine.
This is the machine I used to cut keys with.
http://www.carkeydeals.com/wholesale...g-machine.html
I'm one of those guys that will spend money on a tool instead of going to the dealer.
Old Aug 29, 2018 | 06:44 AM
  #18017
MontrealFit2012's Avatar
CLutch fluid
Some dude mentioned flushing clutch fluid
i just bought my Fit with 66k on it
When do ppl suggest flushing it?
Is it the same idea as changing break fluid?
Old Aug 29, 2018 | 10:29 AM
  #18018
mwoodski's Avatar
Mugen oil/rad caps aren't terribly expensive for the genuine ones, why not just go with that?
Old Aug 29, 2018 | 03:16 PM
  #18019
Goobers's Avatar
But they are expensive, for what they do (I consider $50 or more as expensive for a cap). If you're a genuine Mugen aficionado, then by all means, especially if it's a show car. I'm not that particular about the cap, rather, I just wanted something that wouldn't chip and break like the factory cap I have. I figured an inexpensive aluminum cap would work.
The cap I bought was with the intention of just using it for a cap. I didn't plan on installing the emblem.
I still have the cap, since I decided not to deal with 3rd party returns. I might just see if autozone/advanced auto has a gasket that fits since that's the only issue. And no, I don't plan on installing the emblem now as well.
Old Aug 29, 2018 | 04:51 PM
  #18020
GolNat's Avatar
Green Stuff pads and EBC slotted rotors. Braided lines are back order from StopTech so they will go on another time.
