Old May 28, 2018 | 02:40 PM
  #17881
Fit10's Avatar
Can anyone just order a new Type R motor or will you have to be a registered garage or racing team?
Old May 28, 2018 | 03:17 PM
  #17882
BMW ALPINA's Avatar
You will have to show HPD that you are using this motor for racing purpose (at least initially when you place the order).
I think it would be easier to either sourced the motor from junkyard (totaled car)
or buy the engine and transmission as parts (brand new from dealer).
The main question is will the transmission and engine fit in the Honda Fit GE engine bay...
Old May 29, 2018 | 02:55 PM
  #17883
Fit10's Avatar
Yes I agree. Will it fit in the GE chassis
Old Jun 1, 2018 | 11:22 AM
  #17884
down_corporal's Avatar
Rota 16x7 Spec-R. 205/50/16 Firehawk Indy all around
Old Jun 4, 2018 | 05:51 PM
  #17885
Goobers's Avatar
Gave it an oil change (+new filter) and rotated the tires... those tires aren't going to last another rotation... sigh, barely a year since I bought them.
Need to decide on whether to stick with Continental DWS... I liked the previous version, but hating the "06" version.
edit: forgot to add, finally determined the source of an ongoing rattle... the tie-rod (end link) on the right side of the front sway bar. Seems like the inner bushing is worn out.
Old Jun 4, 2018 | 05:58 PM
  #17886
connor55's Avatar
didn't happen today, but just recently got this in and out of the fit.
Old Jun 8, 2018 | 06:20 PM
  #17887
QSP's Avatar
QSP
Recently installed a Sony XAV-AX5000. I'm very happy with it. I am working on also adding a backup camera. Used the Nav Dash Panel and bracker with a Metra Honda Pilot trim kit. I was able to direct connect the steering wheel controls and use the custom settings in the unit to program the functions. Touchcreen is very responsive and it has a very bright display. I like the Sony user interface as it is very easy to use.
Old Jun 17, 2018 | 09:05 PM
  #17888
Actual daily next to my dream daily.
Old Jun 18, 2018 | 01:00 PM
  #17889
msbxiv's Avatar
We have a new winner! I for one am not worthy of this beautiful beast and what's it's carrying leaves me speechless. Wow!
Old Jun 19, 2018 | 01:57 AM
  #17890
connor55's Avatar
Thanks for the love! only a couple months till its back in the fit, this time on the other end
Today I finally started dialling in the fitment! so much better, but inner fender still needs work to go the last little bit. not a bad start though.
Old Jun 19, 2018 | 09:06 AM
  #17891
Fit10's Avatar
Wow. connor55 your car is amazing. I really like the retro fit headlights. nice work.
Old Jun 19, 2018 | 09:25 AM
  #17892
Cruciarius's Avatar
Haven't done anything with my Fit since shortly after getting it about 3 years ago, I think. Had swapped the stereo unit out for an aftermarket. Been wanting to do something more, so the other day I finally scheduled to get that airbag recall done, but also get the armrest with storage installed and a nose mask to be cut and put on. Both of these I've actually had in the trunk for about 2 years.
Also ordered the Spyder taillights last night, which I'll install ASAP, when they arrive. Wanting to swap out the headlights too, to match. Any suggestions? Links would be welcome. Tried checking on Amazon, CARiD, and Andy's Auto, which are the only places I can seem to find with a decent selection of aftermarket stuff. Problem is, only headlight stuff I see on any of them look to be just bulbs or headlight assemblies that just look too stock to me.
After the taillights I think my next item to tackle would be the front seats. Or maybe I'll tint the windows...
Edit:
After posting this the site where I ordered the Spyder taillights from contacted me saying that it's a discontinued item and will not be back in stock. Found them on another site that is out, but claims more stock will be in 8/8, so fingers crossed I can grab them then.
Old Jun 23, 2018 | 03:42 PM
  #17893
Goobers's Avatar
Finally replaced both endlinks for the front sway bar.
The nuts at the bottom (sway bar mount) refused to come off. I think threads rusted over. I gave up and used a dremel to slice the bolt almost in half. I didn't slice all the way because I worried about cutting into the sway bar. I used a flat tip screw driver to pry it apart slightly and then used a wrench to twist it off like normally. Did that for both sides.
I really hate dealing with threaded bolts that need Allen wrenches. Why couldn't they just put a regular hex head on the other side right before the rubber boot?!?
Old Jun 24, 2018 | 02:35 PM
  #17894
Frenzal's Avatar
You can use a long nose vise grip to squeeze the bolt from the back, then use an impact wrench to remove the nut. Don't do this a on a new endlink, but no problem for those that will go in the garbage.
Old Jun 24, 2018 | 03:31 PM
  #17895
Goobers's Avatar
I have an impact wrench... but the compressor is low volume and whats worse, just as I was prepping it to work on the endlink, the control knob failed (lost all pressure in the outlet)... sigh.
So yeah... no avoiding my arms being sore.
Old Jun 24, 2018 | 07:27 PM
  #17896
NorthtownsMike's Avatar
My Lloyd Rubbertite mats arrived. I like the look of the maroon with the black interior and the silver exterior. The mats are cut really nicely, and so far I am very happy with them.
Old Jun 24, 2018 | 08:08 PM
  #17897
xxryu139xx's Avatar
replace your endlinks with Moog. they don't use the allen key.
Old Jun 25, 2018 | 01:35 AM
  #17898
Goobers's Avatar
Aww... I already installed the OEM links.
Old Jun 25, 2018 | 03:31 PM
  #17899
traviskfit's Avatar
Tinted my fog lights! Was a pretty easy process.
Old Jun 25, 2018 | 03:35 PM
  #17900
traviskfit's Avatar
Added drl lights a while back
Plasti dipped my takeda cold air intake
