Old Apr 3, 2018 | 03:49 AM
  #17821
hotkey's Avatar
Originally Posted by Goobers
Replaced my auto-tensioner... much better, I can actually hear the supercharger (again) even though the engine is only idling.
update on auto-tensioner: After some driving it, for some reason feels like the Fit has more pep in it. It definitely had more pep after getting it back from the rebuild.
So I'm thinking its one of two things, it's a placebo this time and I'm totally imagining it or it really does have that little bit of pep.
I'm thinking it's the tension on the belt courtesy of your new auto-tensioner. More grip, less slip. Probably.
Old Apr 3, 2018 | 03:51 AM
  #17822
hotkey's Avatar
Recently installed:
It took a while to find alloy wheels with the specs that I like at a price I can afford. Turns out, they've been around for about 3 years or so, I just didn't know about it: WedsSport SA-15R, 6.5 inch width, +48 offset. Weighing 5.91kg, the width allows me to retain the stock 185/55-16 tires for maximum weight loss.
The alloy wheels no longer appear on manufacturer's website.
I wanted to use Leggdura or Rays aluminum lugnuts, but they're too short; extended studs were installed so I could use stock wheels with Wilwood 4 pots. Finally decided on long (48mm) steel lugnuts.
Old Apr 3, 2018 | 04:29 AM
  #17823
USDM's Avatar
Originally Posted by hotkey
Beautiful!
Old Apr 3, 2018 | 09:20 PM
  #17824
julianachos's Avatar
Originally Posted by FormulaJDM
After daily driving an Integra Type R for 15 years , bought this in 2013. Bilstien coilvers and ADVAN wheels make this a worthy successor !
I had a 99 GSR with a CTR trans for about four years and can agree with you too Still miss it
Old Apr 3, 2018 | 11:15 PM
  #17825
hotkey's Avatar
Originally Posted by USDM
Beautiful!
Thanks!
Old Apr 4, 2018 | 04:24 AM
  #17826
down_corporal's Avatar
Had some bad luck lately. Thieves smashed my driver window and stole my backpack...had junk in it. Also did a civic cmc swap, but first time around the swivel screw was not tightened enough on the cmc so I eventually leaked brake fluid till I took it out and redid it again, seems to be ok now. Been in an my fault accident over a year ago and replaced airbag, rebar, both sensors, and had srs computer reprogrammed. Cost just under $2000 out of insurance. Shes currently sitting on 15x7 slipstreams and michelin x-ice 2 and has Progress rsb and said cmc.
Old Apr 4, 2018 | 07:30 AM
  #17827
Fit10's Avatar
Bummer to hear about the smashed window and car accident down corporal. What part of Canada are you located in?
Old Apr 4, 2018 | 08:39 AM
  #17828
spike55_bmw's Avatar
Dumb question: What's a "cmc" that can be swapped from a Civic that has something to do with brake fluid? Is it "Clutch Master Cylinder"?
Old Apr 4, 2018 | 08:42 PM
  #17829
Yes that is correct
Old Apr 6, 2018 | 04:03 PM
  #17830
TIGHT-FIT's Avatar
Just got back from paint shop.
Old Apr 8, 2018 | 12:42 PM
  #17831
Frenzal's Avatar
Very nice color!
Old Apr 8, 2018 | 12:50 PM
  #17832
TIGHT-FIT's Avatar
Thanks! I was torn between original blue color and this one. (I wanted as close as I could get to BMW Laguna Seca Blue, or Mitsu "blue by you.") My only fear was, they'd mix wrong and I would be stuck with Easter Egg Lavender...
Luckily, the painter is a huge Honda and BMW nut, and he really took his time to get the color dialed-in perfectly to the sample I gave them.
If you saw it in person, and I told you how little it cost to paint whole car, you'd call me a liar! They hooked it up.
One of the fringe benefits of being a dealer is I use lots of paint shops, and they try to keep me happy on my personal cars.
Old Apr 9, 2018 | 01:00 AM
  #17833
BMW ALPINA's Avatar
Finished with all the wiring and all equipment in my audio project finally operational
https://www.fitfreak.net/forums/2nd-...ml#post1397988
Old Apr 9, 2018 | 02:46 PM
  #17834
TIGHT-FIT's Avatar
That Zapco gear is SWEEEET! OH, MAN.
Nice looking wiring, for sure!
Old Apr 9, 2018 | 03:11 PM
  #17835
BMW ALPINA's Avatar
Thanks TIGHT-FIT,
I am saving money now to get the BRAX MX4 "PRO" power amplifier that will be launch sometimes late summer... after that, then my Audio Project is complete
Old Apr 10, 2018 | 05:41 AM
  #17836
Frenzal's Avatar
Well, got my first CEL. Also, VAS light is on...
Will check with my OBD2 scanner tonight and might drop the car at the dealership since I have an extended warranty. Hopefully, it will be warrantied.
Old Apr 10, 2018 | 07:53 PM
  #17837
Mine had both CEL & VSA lights when the OBDII code noted a misfire in #2 & #3 cylinders. Those spark plugs were loose. Tightened them up and all was well. Don't let them tell you that all of the coil packs need change.
Old Apr 10, 2018 | 11:34 PM
  #17838
degnaw's Avatar
In case anyone is curious, this is what a 1" lifted Fit looks like on stock wheels. (Just took my snows off)
Old Apr 11, 2018 | 05:36 AM
  #17839
Frenzal's Avatar
Yup, got the P0300, P0302 and P0303 codes. Let the car to my trusted mechanics and told him to check the plugs torque. Would have done it myself, but cannot access my garage right now and I don't have the time... Shouldn't cost too much, and I have more confidence in my diagnostic and mechanic then in Honda.
If all plugs are tight, then I will go to Honda. Hope I caught it soon enough so I don't have any damage on the engine...
Didn't heard any weird clicking, and didn't smell gas or exhaust in the car.
Old Apr 11, 2018 | 10:32 AM
  #17840
Frenzal's Avatar
Well, everything is OK with the spark plugs, all tight!
Tonight I'm gonna pick the car up at my mechanic and drop it at the Honda dealer. Coil packs are under warranty, so if they want to change them, I'll let them do it.
Will have to wait until tomorrow to know what is going on...
