Old Jun 29, 2018 | 02:22 PM
  #17901
Frenzal's Avatar
Just noticed that I finished paying off my 2014 Fit last week!
Now, must a least get another 10-12 years from that car without too many problems and I'll be very happy!
Old Jun 29, 2018 | 04:11 PM
  #17902
Fit10's Avatar
Congrats on paying off you car.
Old Jun 29, 2018 | 07:39 PM
  #17903
Goobers's Avatar
Took my Fit for a 300 mile drive from Chicago to Detroit for some golf thingy.
Old Jul 1, 2018 | 01:20 PM
  #17904
eulogy's Avatar
Originally Posted by down_corporal
Rota 16x7 Spec-R. 205/50/16 Firehawk Indy all around
i was considering a set of these for myself....got any more pics of these?
Old Jul 1, 2018 | 02:16 PM
  #17905
BMW ALPINA's Avatar
Solved the inherent problem of Bluetooth phone call only came out from the FRONT RCA Channel of Sony RSX-GS9 Head Unit:
https://www.fitfreak.net/forums/2nd-...ml#post1404157
Old Jul 5, 2018 | 12:31 AM
  #17906
connor55's Avatar
lowered the fit some more today. the JDM front fenders certainly let it fall more than the USDM ones, but will still need a little work later on.
Old Jul 5, 2018 | 01:00 AM
  #17907
msbxiv's Avatar
I am old, so that is too low. I'm getting anxiety about the rubbing just looking at it--up 2 inches please
Old Jul 5, 2018 | 01:06 AM
  #17908
connor55's Avatar
its on air, so I drive at a much more "practical" height.
Old Jul 5, 2018 | 02:30 PM
  #17909
Fit10's Avatar
Wow. you are really able to slam the car down to the ground with air. Looks really good.
Old Jul 7, 2018 | 04:30 PM
  #17910
Alfa38's Avatar
Fixed the hazy headlights on our 2011 Sport using the Sylvania headlight restoration kit. I followed the instructions, but added another stage in between the final prep with a fine machine polish, as I thought it still looks too scratched. This might not have been needed had they included another sanding stage between 400 and 1000 grit. I think it turned out pretty well. Waiting for the UV clearcoat to cure now. Not bad for $20 and about 4 hours of time.
(and it will get washed up and waxed, I have to wait until the coating cures, so nevermind all the runs..)
Attached Thumbnails What did you do to your GE fit today?-headlight-before.jpg   What did you do to your GE fit today?-img_9465.jpg   What did you do to your GE fit today?-img_9470.jpg   What did you do to your GE fit today?-img_9476.jpg   What did you do to your GE fit today?-img_9477.jpg
Old Jul 8, 2018 | 05:13 AM
  #17911
Black3sr's Avatar
I used a mix of baking soda and vinegar and lots of elbow grease using just a roll of shop towel. Then just waxed. Maybe half hour.
Funny my 2010 Dodge Caravan sitting right next to it has showroom lenses still.
Old Jul 8, 2018 | 01:25 PM
  #17912
Alfa38's Avatar
Yeah, that probably would have worked, but I wanted to remove the scratches, smooth the surface, and add a UV clearcoat, so that I won't have to do it again any time soon. The sun here is intense, and it will be parked outside most of the time.
Attached Thumbnails What did you do to your GE fit today?-img_9481.jpg   What did you do to your GE fit today?-img_9482.jpg
Old Jul 8, 2018 | 01:27 PM
  #17913
Alfa38's Avatar
Changed manual transmission oil, now back out to do polishing and waxing...
Old Jul 8, 2018 | 01:40 PM
  #17914
msbxiv's Avatar
How challenging is that? What special equipment do you use to get the new tranny fluid in? Do you have to lift the car or can it be done on the ground?
I've been having my manual tranny fluid changed every 10K miles because my shifter gets really notchy, and while it only costs about $65 at my dealer, it seems like something I should be able to do.
Old Jul 8, 2018 | 01:48 PM
  #17915
Alfa38's Avatar
That sounds too frequent to me, but I'm new to the Fit, so who knows. Good quality synthetic fluid should last 30k miles or maybe more, I assume they are using the Honda OEM stuff. It only takes about 1.5qts, I used Amsoil Syncromesh fluid (oil). You have to lift the front end, put it on jackstands, and to make the job a lot easier, remove the front wheel and drop the plastic undertray. Then its just: loosen fill plug, remove drain plug, drain oil, replace drain plug. Level the car by either jacking up the back end, or lowering the front end with the wheel back in place of course, and refill with 1.5 qt.
It is about as easy, and in some ways easier, than changing the engine oil. Somewhere on the forum there is a tutorial.
Old Jul 8, 2018 | 02:11 PM
  #17916
msbxiv's Avatar
I know it's too frequent, but it helps the shifting a lot. At about 12K miles on the car, the shifter would kind of do a popping thing between 1st and 2nd, and then got notchy going into 3rd. The dealer changed fluid under warranty and shifter when back to silky smooth. Notchiness got bad again at 22K at which point dealer replaced tranny fluid again, and I did a blackstone test to see if there was any evidence of the tranny disintegrating--there wasn't. After that I just started having it changed on 10K intervals--works out to every year and a half for me.
Old Jul 11, 2018 | 03:55 AM
  #17917
Goobers's Avatar
Whew.
Just got back from a trip down south in Lexington KY... 400 miles near nonstop, pushing the Fit all the whining SC way.
Old Jul 12, 2018 | 01:51 PM
  #17918
Bluepunk18's Avatar
Thumbs up
Love this look! Very clean!
Old Jul 12, 2018 | 06:21 PM
  #17919
Alfa38's Avatar
Replaced lower motor mount. Back to smooth idle and startup in 1st gear.
Old Jul 14, 2018 | 07:27 PM
  #17920
Alfa38's Avatar
Replaced struts on our 2011 with take-offs from a 2018, along with springs, new strut bushings, replaced sway bar end links, sway bar bushings (could only get to the pass. side), and tie rod ends. Big job, but worth it as it transformed the ride. The car is so smooth and quiet, no clunks, front end feels more planted as well.
