Old Jan 4, 2017 | 12:22 AM
  #16501
FitIsGo85's Avatar
Originally Posted by Xtina
May as well post up the retrofit I did over the Christmas break. From the Retrofit Source. Morimoto d2s 4.0 with apollo 2 shrouds. lenses are wrapped in Xpel Ultimate ppf.
Have any output pictures. I have the same setup waiting to be installed except I got the apollo 3.0 shroud.
Old Jan 4, 2017 | 10:02 AM
  #16502
shinjari's Avatar
Wow, I always want to enter either Aerospace/Defense sector or Robotic Sector... I should take Mechanical Engineering Major 25 years ago but somehow I choose Chemical Engineering
In the end, to have a better braking performance,
you will need:
a. Larger Tire (wider contact patch and more grip) so you can have higher braking threshold before locking up DONE, running 15x8's on 205s
b. Larger Caliper (more brake pad surface area) Need to verify the OEM caliper replacement will fit my 15's
c. Larger Rotor (better heat capacity and faster heat release / heat sink capability) Need to verify the Large caliper replacement will fit my 15's
d. Better suspension (read firmer and lower suspension) to prevent too much weight transfer to the front while braking and unload the rear resulting in loss braking power from the rear brake... Swifts currently with potential Bilsteins in my future
oh, and another extra advantage is,
The Wilwood Red Caliper and larger rotor will look so sexy behind your wheel spoke I'd probably go black for a more discrete approach. Figure red car with red calipers is a bit too red haha
That alone worth the extra effort and money for me
On serious note,
about few weeks after I upgrade my brake to Brembo,
I was forced to brake very hard when a car in front of me on the freeway abruptly change lane and cut me because he is avoiding another car in front of him...
This is I think about 70 to 80mph...
That is a very close call... and I am sure I would not be able to avoid it if I don't have my Brembo brake... (and my larger tire/better suspension)
I am just centimeters away from hitting that car in front of me... that is how close it is...
That is what I think about brake upgrade... Thanks for the info and glad you're ok after that close call
Originally Posted by Boostedtaco
I'd just change pads/rotors/SS lines. A big braking improvement will require upgrades down the line IMO.
I went to Type-R caliper/mini cooper rotor upgrade with Hawk HPS pads. It overworked the oem tires instantly. That's on koni orange/swift springs.
I ran some star specs and found out the swift springs were too soft for hard braking and rear would get squirrely.
just do pads/rotors/ss lines then toss on some swift springs and call it a day.
Got the swifts and 205 width wheels/tires already just debating on brakes.
Both great sets of info!
Need to verify caliper/wheel clearance and if they wont fit that'll make it easy to just go rotors/pads only haha. 3D printing a template to the dimensions Wilwood provided to verify wheel clearance.
Old Jan 4, 2017 | 10:39 AM
  #16503
Shinjari,
If anything beyond pads/disks, I'd do ITR calipers. A few dudes in my area track their Fits & all have gone with ITR setups.
Old Jan 4, 2017 | 10:43 AM
  #16504
What exactly does a retrofit with these entail? The projectors themselves seem affordable.
Old Jan 4, 2017 | 11:04 AM
  #16505
shinjari's Avatar
Originally Posted by mike410b
Shinjari,
Is that similar to the s2K upgrades people were doing?
Big unanswered question right now is whether I can even fit a larger rotor with the 15's I'm running.
Old Jan 4, 2017 | 11:43 AM
  #16506
All of them run 15's.
Not sure how they compare to S2000 calipers. AFAIK S2000 brakes don't clear 15's, EDIT: S2000 brakes fit within 15's.
Old Jan 4, 2017 | 01:30 PM
  #16507
shinjari's Avatar
Originally Posted by FamilyWagon
Put my new winter tires on. These wheels and tires will serve as winters. Hopefully within the next year or so I can afford a nice summer wheel/tire setup.
But anyways the ride is so much more comfortable with 15's vs 17's. I will never do another set of 17" wheels ever again.
Need side profile pic! =)
Thats good to know. Currently considering hawk (less dust) or ebc green (more bite/dust) and some blank rotors like EBC or brembo. Can get (2) rotors and pads for under $120 which seems more feasible than dumping $400+ especially when I'm trying to get some bilsteins haha.
Old Jan 4, 2017 | 02:38 PM
  #16508
Hawk HPS have crap bite. They're OEM replacements & not impressive ones.
Old Jan 4, 2017 | 07:14 PM
  #16509
shinjari's Avatar
I've heard that Hawks need to warm up...which makes me lean towards the EBC's. Or hell maybe I should just get some duralast ceramics from Vatozone and take advantage of that lifetime warranty.
Old Jan 4, 2017 | 11:50 PM
  #16510
Mr.Hollow's Avatar
I have EBC Green stuff pads and EBC Slotted rotors with ATE type 200 brake fluid.
I don't remember what I paid but it was reasonable. Shop around for a deal.
They bite a lot harder than stock. They don't really need to warm up and they don't fade after a heavy day of AutoX. The only downside is they produce a lot of brake dust! Thankfully I have bronze wheels so its not that noticeable, but any other color will show up significantly.
Old Jan 5, 2017 | 08:58 AM
  #16511
shinjari's Avatar
This is definitely something I was considering. I dont think I'd benefit from the slotted besides the aesthetics/visual of them peeking thru my Gram lights. SO maybe I'll save myself $50ish and just buy blanks.
Dust isnt that big a deal as my wheels are mag/dark blue...practically black. Thanks for the info Mr. Hollow.
Old Jan 5, 2017 | 02:58 PM
  #16512
Mr.Hollow's Avatar
Slotted do have performance benefits though. The slots actually help to even out the pads when they rotate so you get a clean flat pad surface which is ideal because it creates a smoother contact area. Normal pads/rotors get grooves in them over long time use.
Drilled/ cross drilled rotors have no benefit. It reduces the braking contact patch area as well as as makes the rotor more susceptible to cracking because it loses some of its rigidity.
Although feel free to just use a good blank rotor too. Experts say its the best type, while others argue for slotted due to the slight performance factor.
Old Jan 5, 2017 | 03:14 PM
  #16513
Xtina's Avatar
This is the kit I got black Friday. comes with everything you need. all you do is bake the headlight open and screw in the projector, aim and seal back up. took me a day start to finish
https://www.theretrofitsource.com/co...s-stage-3.html
Old Jan 5, 2017 | 03:44 PM
  #16514
shinjari's Avatar
All points I've recently read about =). Use blanks and save $50 or spend extra $50 to get slotted and possibly go thru pads slightly faster. This is a DD so leaning towards blanks.
Thanks for the resource! I was just looking at my headlights today and how they are getting punished by the sun and in dire need of a polishing...maybe a retrofit AND polish are due.
Old Jan 5, 2017 | 10:43 PM
  #16515
Mr.Hollow's Avatar
Thanks for the link. It's nice that everything is all bundled. Might have to take a closer look at this in a few months.
Old Jan 5, 2017 | 10:56 PM
  #16516
BMW ALPINA's Avatar
Inspired by Mr. Hollow J's Racing Yellow Tow Hook
but J's Racing no longer sell it in Yellow color but only Red now...
and
Can't resist the 2017 yen promo discount from Rakuten Global.
So...
Ordered Laile/Beatrush Front Yellow Tow Hook for Honda Fit GE8
and Front Yellow Tow Hook for Honda N-One (I hope this one is shorter so it will fit my modified Reinforcement Bar where it thread in relation to the JDM RS Rear Bumper better)...
Order directly from Laile/Beatrush shop at Rakuten,
They just email me, they are out of stock, will be available middle of this month.
Attached Thumbnails What did you do to your GE fit today?-80-s104206tffs_4_c46202178b805aa5470d47d5e2385bed53c5fd86.jpg   What did you do to your GE fit today?-80-s104900tffs_1_561d7f65350b27effbe0189c6fe47597dc35399a.gif
Old Jan 6, 2017 | 01:45 AM
  #16517
FamilyWagon's Avatar
I like yellow tow hooks, i wanted one, but dont track my car and dont want it for street use.
So it didnt happen lol i do have an itch for something, i want to add something to the Fit. Just dont know what.
Old Jan 6, 2017 | 02:30 AM
  #16518
BMW ALPINA's Avatar
ohhhhh... I don't track my car
tooo old
I just have this yellow fetish
Old Jan 7, 2017 | 12:57 AM
  #16519
Mr.Hollow's Avatar
tooo old
I track my car!
Nice purchase, those Beatrush Tow hooks are expensive!
It will look great! Did you try going through j's racing US site? I think on their website it's still listed as yellow...?
J'S RACING USA
Although their online shopping cart is down so you have to call them. They are located in California.
Old Jan 7, 2017 | 03:08 AM
  #16520
BMW ALPINA's Avatar
I track my car!
J'S RACING USA
Hi Mr. Hollow,
Yes, I did look at J's Racing USA, but when I see there is no way to add to cart and have to call, I figure it must be because they never updated their website anyway and I lose hope they even have yellow, so I decide not to bother calling them hahaha...
oh, there is discount at Rakuten up until yesterday for 2017 yen (like year 2017) if you buy above 15,000 yen...
so my total before shipping is 18,000 yen... so most likely I paid around $190 total with shipping... and I buy directly from Beatrush...
It is about the same price if I buy the red one from J's Racing...
You got a good deal on yours for the front yellow J's Racing one because that guy on fitfreak classified just want to get rid of his...
I did PM that guy before I order from beatrush for the rear one, but he never respond so he must have sold the rear one too...
Anyway... I really hope my gambling of buying the Honda N-One for the rear tow hook pay off because I know for sure the front Beatrush one will be too long for the rear bumper but at the same time the Honda N-One beatrush might be too short for my bumper since my Mugen Lower Under Spoiler stick out like 3/4 inch...
if that is the case, then I will be forced to buy the Front Beatrush for GE and cut the stud a bit... but that mean buy again...
if that happened, I will have to sell the Honda N-One tow hook at discount here on fitfreak classified
by the way, I just return from 1.5 hour road tuning session with my wife handling the laptop...
I have this knocking around 2,500 to 3,000 rpm at 0.2 bar of boost (part throttle)... I had retard the timing to -2.63 at that point and increase the fuel on my AEM F/IC-6 which reduce the knocking but it still exists...
I can't continue more tonight because my wife is tired plus my laptop is almost run out of battery...
I wish I win lottery so I can buy my own dyno
