De36's GE8
Old Jan 25, 2017 | 04:00 PM
  #221
De36's Avatar
Originally Posted by Dxs
...after your comment about them I am now thinking about it.
The Apexi has 8 modes.
4 Gas Freindy
1 Normal (Turn off controller)
3 Performance
Boost 2 Mode is a little intense for the street Boost 1 might be my daily mode.
Old Jan 25, 2017 | 04:10 PM
  #222
BMW ALPINA's Avatar
4 Gas Freindy
3 Performance
Is the wiring plug and play or have to solder?
Thanks
Old Jan 25, 2017 | 04:17 PM
  #223
De36's Avatar
T1R Header from A&J Racing
A&J have a couple headers left for the GE8. Just ordered one from Ben. After the Weapon R header, this a welcome change. It looks like I still need a MIL Eliminator with the T1R header, it eliminates the front cat but retains the rear cat.
Exhibit 1 :: Type1Racing Header
Exhibit 2 :: Stock Cats
Old Jan 25, 2017 | 04:18 PM
  #224
De36's Avatar
Thanks
Plug and Play
You will need these two parts for the install:
Controller Part #: 410-A001 ($123 - Amazon)
GE8 Harness Part #: 417-A020 ($59 - Ebay)
Old Jan 27, 2017 | 02:00 PM
  #225
De36's Avatar
SPOON Sport Key Cover
Just for fun:
Old Feb 3, 2017 | 03:06 PM
  #226
De36's Avatar
This just in.
Old Feb 3, 2017 | 04:13 PM
  #227
BMW ALPINA's Avatar
This just in.
Do you plan to ceramic coated them?
I ceramic coated mine and help with blocking the heat since we can't use
the original heat shield from the original cat converter unless you want to tap/drill the 2 holes needed for the bolts and if I am not mistaken, you also have to cut a bit of the factory heat shield in order for it to fit with the T1R.
Old Feb 3, 2017 | 04:34 PM
  #228
De36's Avatar
No. I may Wrap the header, but unlikely.
NOTE:
The purpose of the OEM heat shields are to help the Cats warm up quicker on start-up. Not reduce under-hood temps. It's for emissions.
Notice, the secondary cat (under the floor board) has a heat shield, same concept.
Old Mar 22, 2017 | 05:34 PM
  #229
De36's Avatar
My Cusco roll cage is coming in this week from Japan. I'm starting to get antsy. Its at the dock as I speak....
Old Mar 22, 2017 | 11:07 PM
  #230
FamilyWagon's Avatar
Yesssss! Loving everything you're doing. I had a Cusco cage in my S2000, it's very appealing to the eyes.
Old Mar 23, 2017 | 09:45 AM
  #231
De36's Avatar
Thanks.
Its quiet ridiculous, I should just buy a proper track car like a Miata. But The FIT is too far gone.
Old Mar 27, 2017 | 12:31 PM
  #232
mikes-ge's Avatar
Who do you through to get the Japanese parts?
Old Mar 27, 2017 | 02:50 PM
  #233
De36's Avatar
Depends what you are looking for? Spoon, Cusco, ect.. are Japanese MFGs.
There are USA/ Canadian distributors that can import it, like AJ Racing.
Old Mar 27, 2017 | 04:02 PM
  #234
mikes-ge's Avatar
The Beatrush, spoon, J's racing and Cusco.
Old Mar 28, 2017 | 11:21 AM
  #235
De36's Avatar
Distributors:
RHD Japan - Beatrush, Spoon, J's
THMotorsport - Cusco
AJ Racing - Spoon, T1R, Cobb
Get the part number you want from Cusco, Js, etc... and these distributors can import it for you.
Old Apr 2, 2017 | 06:51 PM
  #236
De36's Avatar
Honda Fit GE8 Cusco Safety 21 4 Point Cage
Weekend project complete boys... relish.
Old Apr 2, 2017 | 06:52 PM
  #237
That looks awesome!
How much weight did it add?
Old Apr 2, 2017 | 06:55 PM
  #238
De36's Avatar
That looks awesome!
Shipping weight was 38 lbs, so slightly less than that.
Old Apr 2, 2017 | 06:56 PM
  #239
Ohh not to bad at all
Old Apr 5, 2017 | 03:56 PM
  #240
De36's Avatar
Muteki SR48 Forged Steel X-Long Lug Nuts M12 x 1.5
I have locking lugs for my street wheels/tires, which require a special key to remove. This key is a pain on track days, I purchased these Muteki Steel Lugs for my track wheel set (RPF1).
