De36's GE8
Old Jun 28, 2014 | 11:06 AM
  #81
De36's Avatar
Originally Posted by and_des
Did the Civic 2004 cmc replacement yesterday, BIG improuvement from oem, took me around 2hrs,taking my time not stressing and over a couple of cold ones.
Thanks for sharing this with us.
That's great. Where and how much did you pick up he master for? I use to work in a dealership, so I work like I'm flat rate (I work fast). Any difficulties with the install?
Old Jun 28, 2014 | 04:10 PM
  #82
and_des's Avatar
It´s alway ´s more expensive here in Canada, got the Napa cmc for 62$ . Tried to undo the flare nut bottom of hard line going to the soft line, no way i was going to take it apart without braking something, so i took out the battery and K&N ram filter from there i took everything out in one piece from the cmc to the slave cylinder. Even after doing all this still took me just a bit under 2hrs from start to finish. Now i'm just waiting for my Koni Orange
Old Jul 4, 2014 | 10:27 AM
  #83
De36's Avatar
Front Control Arm Bushing Fill
I filled my front control arms. Stock these bushings can be moved around easily by hand. a couple days of drying in my hot/dry attic to cure urethane.
Old Jul 4, 2014 | 11:05 AM
  #84
and_des's Avatar
Nice, waiting for some feed back on that one. When replacing the ball joint by the buddy club ones i was thinking doing this mod at the same time.
Old Jul 4, 2014 | 04:00 PM
  #85
13fit's Avatar
Im very excited to hear what filling the front control arms does for you. Hopefully it does not echo again on bump steer
Old Jul 4, 2014 | 10:51 PM
  #86
De36's Avatar
Rear Diffuser
This is what happens when I am bored.
Old Jul 18, 2014 | 06:47 PM
  #87
De36's Avatar
Rear Diffuser
1st Prototype out of aluminium and acrylic in progress.
Old Aug 1, 2014 | 08:56 AM
  #88
De36's Avatar
Prototype MRK I
This is the first finished working prototype made out of aluminum.
Old Aug 1, 2014 | 09:55 AM
  #89
555sexydrive's Avatar
Where did you end up mounting it at on the chassis? Very nice DIY.
Old Aug 1, 2014 | 10:08 AM
  #90
De36's Avatar
I bought aluminum rods at Home Depot, Cut them to length, Threaded them with a tap and die kit, Bought hyme joints... I used "L" brackets that I riveted to the chassis:
Old Aug 7, 2014 | 09:00 AM
  #91
De36's Avatar
At the new Thompson Speedway, CT
This is an old track that has been shut down for years in Connecticut, the owners rebuilt the entire track. This is the first year it has been reopend in a long time.
Old Aug 10, 2014 | 03:01 AM
  #92
ray83's Avatar
Love the look of your honda fit
Old Aug 11, 2014 | 09:39 AM
  #93
De36's Avatar
Momo D30 (300mm)
Craigs list find, used but in good shape:
Old Aug 11, 2014 | 09:55 AM
  #94
De36's Avatar
DIY "Home Depot" Lip Chin Spoiler...
I have to tighten up the DIY-HD lip but I am happy with the over all finish product:
Here is what I used, it works well:
http://www.homedepot.com/p/ProFlex-N...-20C/204801467
Old Aug 11, 2014 | 10:02 AM
  #95
De36's Avatar
Wrapped Weapon R Header
Finally got around to my exhaust wrap for the Fit
Old Aug 11, 2014 | 07:07 PM
  #96
Not throwing a code with the primary cat removed? Sure glad we don't have that damn EGR piping coming off the upper exhaust.
Old Aug 12, 2014 | 08:03 AM
  #97
De36's Avatar
No codes are set for the cat, because I have (x3) spark plug defoulers that pull the O2 sensor out of the exhaust stream (upper right of the pic). The lower right sensor is my wide band.
The EGR is the first thing to go if Hondata ever makes a tuner for the GE.
Old Aug 12, 2014 | 11:21 AM
  #98
BMW ALPINA's Avatar
Hi,
Do you feel more power and response with the Weapon R Header,
compare to stock?
If there is improvement, is it on the low rpm or mid or high rpm?
Please give your review on the Weapon R Header.
Thanks
Old Aug 12, 2014 | 11:56 AM
  #99
13fit's Avatar
use the civic SI K20 factory EGR blockoff plate. Also block off the rear EGR port from exhaust with a 2 bolt wastegate cover from ebay. Many sizes, so measuring is of course key lol
EDIT if you need the part number, it is under water pump section for 2006-2011 civic si. dunno why its in that section, but last 3 digits are J00
Old Aug 12, 2014 | 01:37 PM
  #100
De36's Avatar
Hi,
compare to stock?
Thanks
There is a noticable gain through out the whole power power band. I've seen a posted dyno sheet of a 12 whp gain at 5900 rpm a while back. I don't know how accurate it is.
