NIGHTHAWKSI's custom turbo build progress thread
Old Dec 16, 2008 | 10:30 PM
  #41
Im|Inside|Fit's Avatar
thats super nice imma attempt fully building my side motor too my buddy ask me if i wanted all motor or FI but i told him.... ALL MOTOR BABY! cuss i want some custom ITB in this L15 motor LMAO! i know i know its not gonna be fast and im jsut wasting my time but hey at least im attempting it =P plus if its not fast enough my buddy got a few nitrous kit for me =D stright directly shot to the ITB all four of them LMAO! then i wont complain as much =P
edit: oh btw super nice setup let me know when you are done... unless you are already =P let me see some pictures and if possible video i want to see it in action! =D
Old Dec 16, 2008 | 11:16 PM
  #42
underdog's Avatar
not sure if it has an actually name at the moment. I do know it's the same style as a honda s2000. which generation i'm not exactly sure of though.
Old Dec 16, 2008 | 11:18 PM
  #43
underdog's Avatar
not to thread hijack but your going to want to get the compression up pretty high, and get a nasty cam made for itb's to work efficently.
Old Dec 17, 2008 | 05:19 AM
  #44
quangalang's Avatar
it doesnt matter what version it is, pretty much all jumper harnesses are different now you HAVE to get the vehicle specific harness!
Old Dec 17, 2008 | 05:29 PM
  #45
NIGHTHAWKSI's Avatar
since no one knew, i took some pics today after work...and as guanglang thought, it is difffernt than any other obd harness.
chances are i will make my own extension harness because to have one custom made will be about $200+ from boomslang. all i should need are male and female harness pins, wire and electrical potting resin...and alot of patience. lol
Old Dec 17, 2008 | 08:17 PM
  #46
explosivpotato's Avatar
Ohhh how I remember being under the glove box looking at that EXACT view...
Must have been under there for at least 3 hours all told, most of which with a soldering iron hovering over my head and a cramp in my wrist.
Damn I wish someone made a harness.. even just an extension harness so I could do the soldering NOT upside-down....
Old Dec 17, 2008 | 08:26 PM
  #47
Spooling's Avatar
ITB on a DBW L15?
Old Dec 17, 2008 | 08:52 PM
  #48
Originally Posted by 1WayFit
ITB on a DBW L15?
Well it wouldn't be DBW once he put the ITBs on...
Old Dec 17, 2008 | 11:40 PM
  #49
quangalang's Avatar
nighthawksi, you should just splice into the factory wiring making your own jumper is more work than it's worth.
Old Dec 18, 2008 | 08:07 AM
  #50
looks like a PITA to be under there splcing wires...maybe i can remove the glove box and get to the wires that way. id rather not be soldering upside down, lol.
does anyone have a ecu wiring diagram they can post?
Old Dec 18, 2008 | 11:44 PM
  #51
underdog's Avatar
Old Dec 19, 2008 | 12:26 AM
  #52
I sent you the diagram I had, let me know if you didn't get it.
I took out the glove box when I did my install. It worked out ok, actually. My E-manage is in my glove box so it's easy to get to when I need (or just feel like) tweaking my tune. It really isn't TOO hard to do, but make sure you've gotten enough sleep.. I did mine after working 22 hours straight through with no sleep on installing the turbo itself, and totally F!CKED my wiring. Took me damn near a week to sort through all my bull-ish under there.
I've still got solder stuck to my carpet too... Remember to put some tin foil or something down when you're soldering BTW
Old Dec 19, 2008 | 03:21 AM
  #53
yah my buddy has alot of connections with people to make cams and pistons so imma have to go mostly custom parts =/ but i guess itll all be well worth it were not attepting this yet cuss ofcouse nows not a really good time =P so start jan well see =]
ITB on a DBW L15?
imma leave most of the work to my buddy =P im not the machanic im just the one with the Fit =P
Old Dec 19, 2008 | 08:11 AM
  #54
got it. thanks for the quick reply and the diagram. it will be a while before i need it, but its nice to have it and see what im in for when it comes time.
i have this amazing mini wireless soldering iron that can fit in the area easily...hopefully hardwiring it in wont be too bad if before i start i tag each of the emanage wires with where it has to go
Old Dec 26, 2008 | 03:59 PM
  #55
so ive run into a wiring schematic issue.
i have the instructions of the t1r turbo kit wiring that includes a chart for the emanage wiring. it lists off the wires that are supposed to come from the emanage harness and where to go at the ECU.
Purple / red ........................INJECTOR 4 IN .......................CUT / WIRE
Purple / Grey...................... INJECTOR 4 OUT....................CUT / WIRE
Yellow / Red....................... INJECTOR 3 IN .......................CUT / WIRE
Yellow / Grey.......................INJECTOR 3 OUT....................CUT / WIRE
Orange / Red ......................INJECTOR 2 IN........................CUT / WIRE
Orange / Grey......................INJECTOR 2 OUT....................CUT / WIRE
Blue / Red...........................INJECTOR 1 IN.........................CUT / WIRE
Blue / Grey .........................INJECTOR 1 OUT..................... CUT / WIRE
i understand that (for example on injector 1) i should take the wire that goes into the pin for injector 1, cut it and wire the greddy input injector 1 to the one side of the wire and the greddy output injector 1 wire to the other.
problem is, i only have 1 wire on my emanage blue harness....i assume this difference is because the instructions are for the t1r kit with emanage ultimate.
so on my greddy emanage blue harness i have 1 wire for each injector. so i simply splice (not cut) into the corresponding injector wire coming out of the ECU?
these are the wires in my harness. i depinned the ones that are in small font(since they werent needed), and the ones that are not bold, i know what to do with.
14................POWER........................... ..... RED
15............... GROUND............................. BLACK
16................RPM SIGNAL.................... BROWN
17.............. AIR FLOW METER ..........GREEN (ECU)
6 .................................................. ..............WHITE SENSOR)
5 ................THROTTLE SIGNAL....... GREY
9.................INJECTOR GROUND......BLACK/RED
4 ................INJECTOR #1.................. BLUE/RED
3 ................INJECTOR #2 .................ORANGE/RED
2 ................INJECTOR #3 ................YELLOW/RED
1 ................INJECTOR #4................ PURPLE/RED
11..............INJECTOR #5................ PINK/RED
10 .............INJECTOR #6 ................LIGHT BLUE/RED
13.............. EX. INJECTOR #1....... WHITE/RED
12 ..............EX. INJECTOR #2 ......GREEN/RED
19..............IGNITION #1................ BLUE/WHITE (ECU)
24................................................ ....... BLUE/BLACK (SENSOR)
20 .............IGNITION #2 ...............ORANGE/WHITE (ECU)
25 .................................................. ....ORANGE/BLACK (SENSOR)
26 .............IGNITION #3............... YELLOW/WHITE (ECU)
27 .................................................. ...YELLOW/BLACK (SENSOR)
21 .............IGNITION #4............... PURPLE/WHITE (ECU)
28 .................................................. ...PURPLE/BLACK (SENSOR)
22 .............IGNITION #5................PINK/WHITE (ECU)
29 .................................................. ..PINK/BLACK (SENSOR)
23 .............IGNITION #6...............LIGHT BLUE/WHITE (ECU)
30 .................................................. ..LIGHT BLUE/BLACK (SENSOR)
8 ...............VTEC SOLENOID..... LIGHT BLUE (ECU)
7 .................................................. .....YELLOW (SENSOR)
18...............VTM SIGNAL .............PURPLE (ECU)
if some one who is familiar with wiring, please confirm that all i need to do are splice wires 1, 2, 3, 4 into the injector wires at the ECU??? if not, what do i do with them?
Old Dec 28, 2008 | 09:30 AM
  #56
If you only have one wire for each injector, you should probably tap them. If you cut the wire and run it into the E-manage, but not to the harness, then you have no circuit, and therefore no injector.
The EMB can only add up to 20% fuel. I'm guessing this is because it has a capacitor it uses to extend the pulse on the injector circuit.
Old Dec 29, 2008 | 07:59 AM
  #57
thats what i was thinking.
as far as the 20% fuel,...since im using larger injectors (+50% larger), the amount of fuel injected for each pulse is more than OEM and then also to allow +-20% fore each pulse..i feel it shoudl work.
i have a good tuner in mind...im sure he will be able to do a very good job with the EMB.
Old Dec 29, 2008 | 09:08 AM
  #58
i have a few parts on order...
bov
intercooler, couplers and 2.5" piping (intercooler -> throttle body)
boost gauge
hopefully i will get this suff by the end of the week or middle of next week. i will post pics when i get them.
and most likely disect the BOV to see what makes an ebay knockoff different than a "real" one.
only things left to buy:
2" turbo->intercooler pipe
manifold parts
oil feed/return
Old Dec 29, 2008 | 10:20 AM
  #59
Zangoose GD3 Blue's Avatar
bov
boost gauge
manifold parts
oil feed/return
SHWEET dude... hopefully i can see them part soon
Old Dec 29, 2008 | 10:48 AM
  #60
^at my new years party..if you can make it.
