NIGHTHAWKSI's custom turbo build progress thread
Old Feb 19, 2009 | 10:35 AM
  #121
NIGHTHAWKSI's Avatar
received 2" silicone couplers yesterday.
i should have everything else delivered to my house today...downpipe parts, manifold parts, t3 inlet flange, 2" intercooler piping, o2 sensor bung. ill take pictures wither later today or tomorow.
Old Feb 23, 2009 | 12:50 PM
  #122
pics of all IC piping have been added to first post. just waiting to be welded now.
installation of emanage blue and injectors to come next. i would like this to go without problems...only thing im nervous about it having the incorrect jumper settings. if some one happens to know what they should be for either the emanage untimate or emeange blue, it would be a great help.
Old Feb 23, 2009 | 01:14 PM
  #123
quangalang's Avatar
yo yo yo! where can i buy heat tape for cheap yo?
Old Feb 23, 2009 | 01:21 PM
  #124
Summit SUM-350104 - Summit® Heat Tape - summitracing.com
works great. i ordered 1 roll....should have ordered 2. i would have liked to cover more or have double layers in some places, but i was running low. now i cant get myself to spend as much on shipping as it costs for the tape
Old Feb 23, 2009 | 06:49 PM
  #125
Spooling's Avatar
Nice progress man, the work looks clean and well planned. The T3 turbo is oil cooled only? I don't see any coolant tappings. can't wait to see the top mount turbo
Old Feb 23, 2009 | 10:17 PM
  #126
its both oil and coolant cooled. i am going to use the coolant that feeds the throttle body and then use the return that the throttle body would have used.
ive had the throttle body coolant bypass done to my car for a few weeks now, so i know the car will run fine without collant through it.
Old Feb 23, 2009 | 10:54 PM
  #127
i wired up my emanage tonight (except for the ignition wires...not necessary now and will only complicate things if there is a problem)and all went well. easy to get to the ECU connections and all went well. i started the car and it ran fine........for about 15 minutes/10 miles. i am now in limp mode.
i am assuming this has to do with jumper settings. it defiantly has to do with the maf input/out. the car will not go over 3k RPMS, rpms will fall to about 300 when i clutch in and come to a stop and if i press on the gas quickly to about 2.5k RPMS i have a poping sound out of the exhaust (but its not a backfire).
Old Feb 24, 2009 | 08:55 AM
  #128
Zangoose GD3 Blue's Avatar
well that not good...
Old Feb 24, 2009 | 01:26 PM
  #129
i just got the emanage working properly.
emanage blue jumper settings:
JP1 1-2
JP2 1-2
JP3 OPEN
JP4 1-2
JP5 OPEN
JP6 OPEN
JP7 OPEN
rotary switch settings:
4-8-A
Old Feb 26, 2009 | 09:52 AM
  #130
added a couple pictures of the start of my downpipe on the first page as well as a few emanage install pics.
and just an update...the car is still running without a CEL since the emanage install. a/f ratio somtimes touches 16.0 inbetween shifts, besides that it is usually 14.9 - 15.8
Old Feb 26, 2009 | 03:05 PM
  #131
Spooling's Avatar
what are you studying?
Old Feb 26, 2009 | 03:16 PM
  #132
studying? you mean college?
Old Feb 26, 2009 | 03:33 PM
  #133
yeah im confuse too, but im pretty sure what college you go too...
Old Feb 26, 2009 | 03:37 PM
  #134
if thats the case...none..i never finished. i went to NYIT for architecture and hated the school. i went for 2 semsters and never went back. i need to get back into it and finish my degree though.
why do you ask?
Old Feb 27, 2009 | 02:23 AM
  #135
Spooling's Avatar
take pictures on how to change the injectors please.
Old Feb 27, 2009 | 07:12 AM
  #136
dewthedew's Avatar
werd on the injectors because im going to be changing my soon too
Old Feb 27, 2009 | 08:05 AM
  #137
i am planning on following htis DIY
https://www.fitfreak.net/forums/fit-...ce-gasket.html
it is exactly what needs to be done, except for one step....there is a bolt on the right side of the head that holds the fuel line in place. remove that bolt and the fuel rail will be able to be removed and the injectors unclipped.
i will take pictures of my install as well. i might do it today...depending how much time i have.
also, i spent a few minutes with the emanage yesterday since i was running a little leaner than i wanted. i never changed the TPS or injector settings that the previous owner had. it was set for me running 240cc injectors....
all fixed now and im getting no readings over 15.8.
Old Feb 27, 2009 | 09:45 AM
  #138
maybe i should do that before mine explode...
Old Feb 27, 2009 | 10:15 AM
  #139
do what?
change injectors? lol...you don tneed to
Old Feb 27, 2009 | 11:36 AM
  #140
do what?
lol i kid i kid...
