NIGHTHAWKSI's custom turbo build progress thread
Old Feb 3, 2009 | 09:23 AM
  #101
NIGHTHAWKSI's Avatar
Originally Posted by Zangoose GD3 Blue
Ian im wondering if i have the same thing also...
a CEL from a cat delete is VERY common. if you havent done anything to your car recently except for the cat delete, and then got a CEl. its most likely teh cause. nothing major to worry about. but im just suprised that the code is thrown with the o2 sensor "fix".
cars also all act differently to no cat. when i hade the DC header on the SI, i didnt have a CEL. sold it to kenny, he got a CEL a week later...it comes and goes.
my only concern is that i added a gaske to my test pipe yesterday (it didnt have one and was leaking) and also tapped the vacuum line for my boost gauge (boost gauge was already installed, just the line wasnt connected). if i hadnt touched the vacuum line i would just reset the ECU by disconnecting the negative terminal....but since i messed with the vacuum, i wan to make sure what it is before i go any further.
Old Feb 3, 2009 | 11:28 PM
  #102
underdog's Avatar
Originally Posted by NIGHTHAWKSI
somethings ive noticed since installing the a/f gauge and test pipe...
- the car idles at 14.9:1 - 15.0:1
- while driving it goes went as high as 16.5:1
- normally fluctuates between 14.9:1 - 16:1
- i got a CEL most likely from the cat delete. i will use a scan gauge soon to find out. if its not a lean/rich code, then it must be from a vacuum leak from hooking up the boost gauge.
alos, my oil life is down to 0%. i was hoping to ride this oil out until i install the turbo, but it looks ike i wont be able to. within the next week i will be drilling and tapping the oil pan and installing a plug temporarily. this way i dont have to waste all the oil a month form now when i install the turbo.
if anyone has any tips, it would be greatly appreciated. i was planning to try and drill ant tap the oil pan while its still on the car, then drain the oil with any shavings in it. the filter would catch anything that might be left.
however, im not sure if there is enough room for a drill to get to the oil pan, or if anyone would highly advise against doing it this way. i know its not the best, but it saves ALOT of trouble from dropping the pan.
the pan doesn't look hard to remove honestly. but if you must cut corners make sure you load the flutes of the drill bit with wheel bearing grease to catch a majority of the shavings.
Old Feb 11, 2009 | 09:39 AM
  #103
just a minor update....added a pic to the first post of my gauges mounted.
will be drilling and tapping the oil pan on sunday. will take plenty of pics.
Old Feb 11, 2009 | 11:38 AM
  #104
Zangoose GD3 Blue's Avatar
S!ck are you going to be there later...
Old Feb 11, 2009 | 11:48 AM
  #105
of course. i might even wash my car later if the weather is good.
Old Feb 11, 2009 | 11:52 AM
  #106
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
it's looking really good!!
nice to see a lot of progress.
so cheap for a turbo!
it's insane.
Old Feb 11, 2009 | 01:59 PM
  #107
it's insane.
yea i know! i couldnt beleive it when i won the auction. i havent tested it or anything, and without knowing much about turbos, i dont really know what can go wrong. all i know is it has no in/out shaft play and VERY minimal side shaftplay. a few friends of mine that know more about turbos said the shaft play is acceptable and as long as the fins arent touching anything it should be good.
Old Feb 15, 2009 | 11:49 AM
  #108
underdog's Avatar
a little trick that your welder will love you for is rather than using duck tape use hvac duct tape. looks like aluminum foil and leaves virtually no residue and is strong as hell. also put a sharpie mark accross both pipe and mark the pipes a and a then another pipe b and b or numerically in case he accidently mixes them up.
Old Feb 15, 2009 | 11:45 PM
  #109
redrumm's Avatar
Old Feb 15, 2009 | 11:48 PM
  #110
Old Feb 16, 2009 | 12:03 AM
  #111
redrumm's Avatar
thats what im saying!!!!
upgrade the turbo and a few things and it would still be cheap
Old Feb 16, 2009 | 10:02 AM
  #112
Old Feb 16, 2009 | 10:03 AM
  #113
DAMN!!
why don't more people do these?
sarcasm?
ill admit to using a few parts off ebay such as
BOV, IC piping and Intercooler.
an ebay turbo..no way! thats a hit or miss item...mostly miss. price for a new turbo...$400+ (i got VERY lucky and found one for cheap). or you could go and get the REAL version of that turbo... for $1150
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
i am expecting to have to replace my BOV in the near future. $200
there is no manifold in that kit. manifold will be expensive to have made unless you can DIY. axpect another $400+
there is no oil return included. $60
and another point to justify how horribly a ebay kit is, that turbo requires an external wastegate. none is included with the auction. $200
so add at least another $1200 to that auction and you have a complete kit that requires alot of welding and fabrication that will cost $1000 unless you DIY.
Old Feb 16, 2009 | 10:06 AM
  #114
sarcasm?
damn it look too good to be true..
Old Feb 16, 2009 | 10:20 AM
  #115
updated my first post with drilling and tapping my oil pan while on the car.
Old Feb 16, 2009 | 10:28 AM
  #116
damn how much do you have to... btw keep them pictures coming lol
are you still going to install the the turbo at your house ?
Old Feb 16, 2009 | 10:41 AM
  #117
im waiting on manifold parts, 2" IC piping and the emanage ignition harness.
once i get the emanage harness, i will install that and the injectors.
i will be building the manifold/DP in spair time after work.
and within a week i will design the rest of my IC piping. bring it to be welded and then everything is pretty much done.
when it comes time to install everyhting, it will be as simple as bolting on the IC, peicing together the piping, and bolting on the turbo. besides that its 1 fitting for the oil feed and a few hose clamps for the oil return and coolant.
then TUNING
gonna try it myself.
Old Feb 16, 2009 | 11:18 AM
  #118
redrumm's Avatar
my friend welds so that wouldnt be a problem and it wasnt sarcasm, he was just saying for the money. but yes they are too good to be true.
it says after 20K miles the turbo will need to be rebuilt.
how did you get a manifold? DIY?
Old Feb 16, 2009 | 05:31 PM
  #119
suketoborudo00's Avatar
wow awesome progress man, i'll never be able to do this but thanks for logging your work; very interesting! good luck
Old Feb 17, 2009 | 12:34 AM
  #120
sy11580's Avatar
Sound like your project almost done!!! Cannot wait to see in the summer meet
