**Official K-Fit Pictures Thread** (no BS)
I live in Calgary Alberta Canada and it does snow here most of the year. One guy said why would you want to put that much money into the car and then drive it in the winter? And the second fit would be here during the swap. Since I still need a bunch if parts like the to get the wire harness made and a new shifter and to actually rebuild the k20z3 that I have, there is a thrust bearing that is shot. And there is still a hundred things that I will still need. And then either build it myself or find a shop that will do it for me.
I always said the last thing the Fit needs is a traction control system. This though is a whole different ball park then a OEM traction control system, plus I am sure when you are all said and done you will defiantly need that traction control.
