K20 Fit How To Discussion
Old Sep 24, 2007 | 12:39 AM
  #181
gotfitted's Avatar
Are you worried that there is going to be contact when the motor's running and vibrating?
Old Sep 24, 2007 | 07:12 AM
  #182
Wave's Avatar
Unhappy You can literally thank the President of Iran...
for me not being able to help this weekend(and most of this week).
But your car is slowly but surely gonna be awesome! Can't wait!
Old Sep 24, 2007 | 07:53 AM
  #183
gettinafit's Avatar
YES! But Brian from Hasport said that the differential comes extremely close so I see what he means now! The only thing for the future would be urethane mounts! Stop engine movement. Hasport is developing them as we speak I hope....
Wave, no prob. You are protecting NYC and doing a fine job! I don't think that it will be done by the end of the week, I don't think that I'm gonna find any time to work on it really... We'll see!
Old Sep 24, 2007 | 04:50 PM
  #184
gettinafit's Avatar
I had a few minutes to work on the fit today, and so I installed the A/C compressor, the midshaft and Axles and MT fluid, and the Starter/battery cable. I also adjusted the shifter cables since they were binding a bit before and now the switch like butter!
Stay tuned, I hope to start this thing up by the weekend!
Old Sep 25, 2007 | 11:52 PM
  #185
gotfitted's Avatar
can you get a shot of the A/C pulley? Does it get dangerously close to the frame too?
I had a K swap in an EK and the 1-2 shift was kinda sloppy when i did hard shifts at WOT...if you still remember this question when your car is running, can you test to see if you have that problem also?
Old Sep 27, 2007 | 07:47 PM
  #186
gettinafit's Avatar
As of last night I put on the belt, hoses, radiator and condensor, and custom mounted the pusher-type fans in front with electrical modification.
It's getting there! It's starting to look like a car again!
Still about another solid 4 hours of work until first crank!
Old Sep 29, 2007 | 09:41 PM
  #187
gettinafit's Avatar
** Update**
It's pretty much all back together. I need to top off fluids, get the header and install it, fabricate an intake, and just check everything over once again!
The good news is it fired right up! Check out the video!
YouTube - Honda Fit K20A First Startup!
Here's the ALMOST finished product!
Old Sep 29, 2007 | 09:46 PM
  #188
Wave's Avatar
Exclamation Dope
Kick @ss! Can't wait to see you stalking the highways!
Old Sep 29, 2007 | 10:47 PM
  #189
nexus4400's Avatar
Congratulations. The biggest test is getting it to start... it should be done hill from here to getting it road worthy.
Old Sep 30, 2007 | 12:36 AM
  #190
thane's Avatar
MAD PROPS. I can't wait to see some track slips(promise?). Should clear a whole lot up. Hope the header fits nicley.
FIRST GARAGE K20 HONDA FIT SWAP FTMFW!!!!
Old Sep 30, 2007 | 01:28 AM
  #191
sy11580's Avatar
OMG............everything back on together and it started. Can not wait to have a ride. Congratulations & See you in 2 weeks!!!
Old Sep 30, 2007 | 02:52 PM
  #192
SpoonSportFit's Avatar
Wow looks great i can't wait to see it get rolling great work
Old Oct 2, 2007 | 12:02 AM
  #193
downest's Avatar
Do the gauges and AC and stuff work (ie did the harness work)?
Old Oct 2, 2007 | 02:05 AM
  #194
gotfitted's Avatar
hollllllllly mother of Honda, Batman! good job! can't wait till she's complete! are you going to make any in motion videos? I"d like to see how she runs from the cockpit view
Old Oct 2, 2007 | 08:33 AM
  #195
gettinafit's Avatar
In a couple of weeks, I should have her all perfected and done. Yes I will have an in car motion video.
As for the dashboard and stuff, the check engine light is on and flashing! I have to look into that. There is no header nor o2 sensor hooked up b/c of no header, so I'm hoping it's that. I need to borrow my buddy's scanner to look futher. But hey it started!!!
Old Oct 2, 2007 | 09:02 AM
  #196
vtecdreamer's Avatar
this is awsome dude... I suprised your not a member of b20vtec.com?? alot of long island guys are there..
Old Oct 2, 2007 | 01:54 PM
  #197
downest's Avatar
But do the gauges and stuff work fine?
Old Oct 4, 2007 | 11:46 AM
  #198
EXWRX's Avatar
Since you have your old engine out, could you weigh the L15? I'm curious to know how much the original engine weighed for us potential swappers.
Old Oct 4, 2007 | 11:40 PM
  #199
ComposiMo's Avatar
Interested in hearing the response to this as well
Old Oct 5, 2007 | 09:14 AM
  #200
gettinafit's Avatar
Yes they work. That is why the wiring took so long ! And that is why I'm required to run the Fit ECU still on top of Kpro.
