for those that dont already know- Hondata
Old Nov 14, 2012 | 08:55 AM
  #61
FitStir's Avatar
Thumbs up
Originally Posted by TPColgett
Yes it's out there and yes I finally have mine!
Such a beautiful pic, I had to quote it again.... what a sight, the Hondata box with "US Fit 2007+" on it.
Enjoy it & have fun!
Can't wait till they come out with the GE version... if ever.
Old Nov 14, 2012 | 08:58 AM
  #62
Hootie's Avatar
I'd find a GE and try it just for shits and giggles. If it doesn't work, it just doesn't work... If it does... ^.^
Old Nov 14, 2012 | 09:02 AM
  #63
FitStir's Avatar
I know what I'm buying myself for Xmas...
highly doubt it though with the differences in ECU's, but if Santa's listening.......
Old Nov 14, 2012 | 11:26 AM
  #64
jazzman's Avatar
This is only for the 1.5??
For the 1.3
Old Nov 14, 2012 | 11:41 AM
  #65
DiamondStarMonsters's Avatar
You have less displacement, different ignition system, Factory DMEs may not support US OBD2 .. I would put money down that the EUDM ECU is different to begin with.. so it's highly unlikely this is going to work for you.
Feel free to give Hondata a call to clarify though.
Old Nov 14, 2012 | 12:49 PM
  #66
dewthedew's Avatar
YESSSSSSSSSSS!!!!!1
FINALLY!!!!!!! has anyone tuned their fits yet?
Old Nov 14, 2012 | 01:13 PM
  #67
TPColgett's Avatar
YESSSSSSSSSSS!!!!!1
See my post on page 2... Still having trouble scheduling Dyno time this week...
Old Nov 14, 2012 | 01:45 PM
  #68
Mine is in the air coming from Hawaii still lol
Old Nov 14, 2012 | 01:48 PM
  #69
TPColgett's Avatar
When it happens, the car is going to the most reputable local(ish) shop: BlackTrax - Dynotuning to be dyno'd on a Dynapack 3000. I should be able to have plenty of pretty graphs from the data
Old Nov 14, 2012 | 01:52 PM
  #70
TPC.. please note weather info for us (humidity/temp, DA, etc.) and correction factor they used when you go.
Old Nov 14, 2012 | 01:55 PM
  #71
TPColgett's Avatar
I am 100% new to the electronic tuning game, can you give me a full detailed list of the ideal measured factors?
Humidity
Temp
I am doing my best to document EVERYTHING for the sake of the community
Oh, and I just noticed that my serial # ends in "0000" ... did I get the first one?!
Old Nov 14, 2012 | 02:01 PM
  #72
Basically record atmospheric conditions (Temp, Baro, Humidity, Density Altitude and actual altitude) and make sure they data-log the runs so we can see your AFR, MAP, IAT, IDCs, etc.
Old Nov 14, 2012 | 02:04 PM
  #73
TPColgett's Avatar
Will do! I was trying to get the time off work to be present and film the runs.... but my job just changed again... if I don't work, I make no $
ESPECIALLY after buying this I need the $$$
Old Nov 14, 2012 | 03:44 PM
  #74
08purplefit's Avatar
You should really check out etunez.com to get your fit tuned. Its cheaper and you tune at your own pace.
Old Nov 14, 2012 | 10:09 PM
  #75
TPColgett's Avatar
Red face
So this didn't work out lol. They're booked up until next week... So found another place that's got time tomorrow...now the car will be on a Dynojet 248H...
Old Nov 15, 2012 | 06:06 PM
  #76
TPColgett's Avatar
OK, getting some preliminary responses back from my tuner. I am really waiting to see the data before I comment though.
Also, if you have not seen this article, please go read it: Honda Fit Power Pages - Import Tuner Magazine
The above article is the ONLY published side by side dyno information that I have ever seen for a GD Fit. They also used the exact same exhaust as mine
Just want to make sure people have realistic expectations for what they are going to see from the standard "bolt on's" and a tune
Old Nov 15, 2012 | 08:35 PM
  #77
I'm installing the kw high boost sc all I need is my flashpro then I'm going to tune it.
Old Nov 16, 2012 | 01:46 PM
  #78
TPColgett's Avatar
DSM, you have a PM...
Old Nov 16, 2012 | 01:53 PM
  #79
Replied
Old Nov 16, 2012 | 10:56 PM
  #80
Well good news everyone!
Tyler's base tune and dyno runs are in!
Feast your eyes on this:
Yes, that is an 11whp bump from an extremely rudimentary tune!
"So what?" you say "For $600+ I only get 11whp?
Lets put that in perspective.. that is a 12.4% gain in power from merely adjusting the fuel trims and NOTHING ELSE
Compared to the T1R turbo kit, for example that is a better dollar/whp ratio.
A&J Racing :: Engine :: Turbo :: T1R Type-S Turbo Kit - Honda Fit/Jazz 06-08 (GD3/GD4) (USDM)
T1R 145whp @ 4.5psi = 62.9% increase over stock for a 5MT GD3
FlashPro Base Tune = 12.4% increase
Now lets look at this in terms of "bang for your buck" ... The T1R turbo kit makes 5 times the power, but 7 times the cost.
Who remembers this article?:
Where they spent $1050 for 9whp? And what they don't mention in the article is how the gains get pulled back into the fold by the stock ECU when left to make up its own mind.
Very few opportunities like this in the tuning world, especially on such a small displacement motor, that is so well optimized from the factory to begin with.
Now this shop and their tuner, who shall remain nameless, was not the shop he initially intended to go to.
They dropped VTEC activation too low (~2500rpm) which is why there are two dips early in the rev range and they leaned it out a bit too far, almost 13.7:1 AFR under full load in a couple spots. No knock was detected, and no knock retard was shown in the calibration so it is a safe tune, but not ideal.
Meaning that there is still more to be had.
Updates to come.
When I said, that like ECMLink for DSMs, VAGCom for VWs, Pro EFI/FAST for the V8 folks.. this should be the first proper mod you do for your Fit.
Otherwise all that money you would spend on I/H/E is for nothing because the ECU will adapt to it and bring your power back down.
FlashPro makes it permanent, and then when its time for emissions, you can revert back to your stock maps and have all your monitors ready to go.
This is a giant leap forward.
